Toymods » Tech & Conversions » 4agze problem
krayzie
4agze problem Fri, 15 April 2005 10:50 Go to next message
This afternoon i started my car and the idle was very erratic ... then I drove it down the road and it seems to be misfiring badly. Its hard to explain so i know its going to be difficult to answer. All im after is what kind of things it could come down to.
The engine has about 105000kms on it and i service every 5000km. Last service which was about 2 months ago i changed plugs ... I used the platinum plugs. I haven't changed the leads but I'm not sure if its just the leads or its a coil thats not working properly. The fuel pump is working fine so its not a fuel problem.
Any suggestions
Andrew
retro
Re: 4agze problem Fri, 15 April 2005 14:44 Go to previous messageGo to next message
If you kept your old plugs i would replace them as a comparison.....if it does it under load it could be a number of things /Leads/coil/plugs/ etc, it is a process of elimination
goodluck
krayzie
Re: 4agze problem Fri, 29 April 2005 07:06 Go to previous messageGo to next message
Update -
I have changed the leads,coils and plugs and there is no improvement it still misfiring.
Any other suggestions?
4agte
Toronto, Downtown
Re: 4agze problem Fri, 29 April 2005 07:11 Go to previous messageGo to next message
which 4agze is it map or afm and have you checked the adjustment on the tps?
drift86levin
brisvegas
Re: 4agze problem Fri, 29 April 2005 08:05 Go to previous messageGo to next message
weired thing happened to me..the exact same thing..it was doing it for a few days and it annoyed the shit out of me..also being bad for the motor..then i realised that i blew a rad hose the day befor, and it wasn't running right since..reason..water in the spark plug wells..dosn't have to be much..or in everysingle one..a bit of compressed air, and unpluging all the the leads after the motor has come up to operating temp (hot) so the water can evoporate away..also wouldn't hurt to silicone spray your leads.. Razz
drift86levin
brisvegas
Re: 4agze problem Fri, 29 April 2005 08:06 Go to previous messageGo to next message
read it in a hurry..just notice that it has been going on for 2 weeks..it might not be that after all Rolling Eyes
krayzie
Re: 4agze problem Fri, 29 April 2005 08:57 Go to previous messageGo to next message
its a map sensored 4agze...
cooter
perth
Re: 4agze problem Fri, 29 April 2005 09:09 Go to previous messageGo to next message
sorry if this isnt any help but could it be the water temp sensor. my water temp sensor was fuked in my 2tgeu. it idled up and down, would stutter and misfire when i put my foot down etc. fixed it when i put a new one in.
is this happening when its cold?
craig
4agte
Toronto, Downtown
Re: 4agze problem Fri, 29 April 2005 10:14 Go to previous messageGo to next message
cooter wrote on Fri, 29 April 2005 19:09
craig
yes this could be the cause
boog
campbelltown
April 2005
Re: 4agze problem Fri, 29 April 2005 11:13 Go to previous messageGo to next message
hi all !!!!!! just thinking bout your problem did the motor get hot i mean to hot like over heated......... ???????? that would give you a hell of a missfire is the motor standard or modifyed ??? hope i can help just need a little more background
krayzie
Re: 4agze problem Fri, 29 April 2005 12:43 Go to previous messageGo to next message
The engine misfires pretty much all the time whether it is cold or hot. Its has a misfire when just left idling and when I accelerate.
The engine is standard with the standard computer. All i have done is front mounted the intercooler and that about it.
Im totally lost with this one.
4agte
Toronto, Downtown
Re: 4agze problem Fri, 29 April 2005 12:55 Go to previous messageGo to next message
have you tried checking to see if the ecu is spitting out an error code. May be a faulty sensor of some sort.
krayzie
Re: 4agze problem Fri, 29 April 2005 22:03 Go to previous messageGo to next message
How do I check for an error code from the ecu?
4agte
Toronto, Downtown
Re: 4agze problem Fri, 29 April 2005 23:07 Go to previous messageGo to next message
you get the diagnostic plug and use a paper clip to short two of the terminals i forget which 2 its on the club4age website from memory you can also search 4age error codes in google and you should find what you need.
Once you have jumped the terminals you turn the ignition to accessories and count the amount of times the check engine light flashes.
krayzie
Re: 4agze problem Sat, 30 April 2005 03:05 Go to previous messageGo to next message
[Updated on: Sat, 30 April 2005 03:57]
taitran
Melbourne, West Suburbs
April 2005
Re: 4agze problem Sat, 30 April 2005 08:53 Go to previous messageGo to next message
I think your engine needs a second throttle body to lengthen the intake,the erratic idle seems to be a problem with most 4agze's.
As for your misfiring,your probably using crap low octane fuel, Try a bottle of octane booster with some 98 octane and c how it goes.
HOPE I HELPED
TAI TRAN
krayzie
Re: 4agze problem Sat, 30 April 2005 10:59 Go to previous messageGo to next message
I have been filling up at the same petrol station for five years and always have used premium. I used it in my wrx which was modded to shithouse and never had any sort of problem. I ruled this out as I filled up a new tank with premium and everything is still the same.
I had a mechanic mate come over today to have a look and well he was as stumped as I was. After the engine was running for about 30mins the problem seemed to disappear and later that afternoon I started it and the same thing happened again.
How do I run a diagnostic if I'm using the sprinter dash? Is there any way of finding the code another way?
Andrew
boog
campbelltown
April 2005
Re: 4agze problem Sun, 01 May 2005 01:44 Go to previous messageGo to next message
normally the diag plug is on the n/s/f of passenger strut tower the two terminals you need to bridge are TE and E1 then turn the ignition on and the engine light should flash eraticly if it flashes constantly with no changes then it is all ok. is it running the map sensor or the airflow meter ???????? if they go out of sink they will put all the other sensors out my first thaught would be sumthing has gone out of sink and fould up the o2 sensor that will giv you that simtem.... remove it see if it has heaps of black shit (carbon) all over it ???????? clean it then disconnect the battery to reset the basic settings then see how you go....... very interested to see what the cause is
tankrolla
cranbourne
April 2005
Re: 4agze problem Sun, 01 May 2005 04:28 Go to previous message
hi
Previous Topic:alternator not working (4agze)
Next Topic:Undoing crank pulley bolt??
Current Time: Sat Nov 21 04:38:35 UTC 2026
Total time taken to generate the page: 0.011496067047119 seconds
