Toymods » Tech & Conversions » 2tgeu questions
lilcrash
ipswich queensland
2tgeu questions Fri, 15 April 2005 22:53 Go to next message
how big are the standard injectors and wat pressure is the fuel regulator??
thanx
thetoyman75
Club President
Re: 2tgeu questions Tue, 19 April 2005 13:59 Go to previous messageGo to next message
2T-GEU injectors are refered to as 195cc. The workshop manual actually lists there flow at 45cc +/- 5cc @ 15sec
Both those are at open flow of course Smile
Can't be as certain with the base pressure tho sorry mate. I can't read Japanese Sad Best guess lists it as 34-40 PSI opperating range. Don't take that as gospel tho its a guess as like I said. I can't read Japanese.
lilcrash
ipswich queensland
Re: 2tgeu questions Tue, 19 April 2005 21:59 Go to previous messageGo to next message
thanx for that.
do u think that my na enigne should have a turbo regulator on it?? would this be good or bad?? the only na regulator i have is too small and i got it from perth as a 2tgeu one. do u think it is possible that i might have a 3tgte or similar fuel rail on my car??
thanx again for the help
laterdays
thetoyman75
Club President
Re: 2tgeu questions Wed, 20 April 2005 10:54 Go to previous messageGo to next message
The 3T-GTE fuel rail won't easily fit onto a 2TGEU manifold so its very unlikly thats what you have. Not sure if I have a spare fuel reg out there ? I canhave a look if you like. Otherwise a good quality Sard fuel pressure reg is an option but not real cheap, Hell any reg will work fine as long as it has the right base fuel pressure Smile.
lilcrash
ipswich queensland
Re: 2tgeu questions Thu, 21 April 2005 00:29 Go to previous message
i think the one im using is about 60psi, im getting it tuned on wednesday to try to get rid of my hicup but i dont think much is going to slow my fuel enough to stop that, i think its got sumthin to do with the accelerator pump setting. thats y i was considering a forced induction setup to use the excess fuel but idk nemore.
thanx for the help
Previous Topic:removing rear swaybar ae112
Next Topic:keep rebuildn 4age b/p or blacktop 20valve???
Current Time: Fri Oct 23 02:57:32 UTC 2026
Total time taken to generate the page: 0.0060229301452637 seconds
