Toymods » General Car Talk » best injectors to use on 4age
pazhon
tas
April 2005
best injectors to use on 4age Sun, 17 April 2005 10:03 Go to next message
want some opinons onthe best cc injectors to use on a standard 4age ?
Re: best injectors to use on 4age Sun, 17 April 2005 10:12 Go to previous messageGo to next message
I'm willing to bet, the standard ones
duh.
ae86drift
sydney.au
Re: best injectors to use on 4age Sun, 17 April 2005 10:15 Go to previous messageGo to next message
hahaha
ahh draven u funny cunt
the best injectors are the ones that match the ECU you ae using
ie, if its an ae82 ecu get the std injectors for that ecu
if its an ae92 get the green injectors for that ecu
if its got an aftermarket ecu get the biggest ones you can find
Very Happy
pazhon
tas
April 2005
Re: best injectors to use on 4age Sun, 17 April 2005 10:16 Go to previous messageGo to next message
ill think u will find u can probally go a lil bigger with extractors for better preformanc just asking if anyone has tried any others?
Big T
uhhhh, the ones that come standard on your 4age perhaps??? Unless you have an issue with not enough fuel being supplied there's no need to upgrade your injectors.
It also depends on which particular 4age you have if you want to check the flow rates.
Eddie.
pazhon
tas
April 2005
Re: best injectors to use on 4age Sun, 17 April 2005 10:18 Go to previous messageGo to next message
so leave the injectors stock ok
Big T
Re: best injectors to use on 4age Sun, 17 April 2005 10:22 Go to previous messageGo to next message
pazhon wrote on Sun, 17 April 2005 20:18
I think that's the best idea. I'm upgrading to turbo so needed larger injectors but if you're keeping it stock, there's simply no need
Eddie.
ae86drift
sydney.au
Re: best injectors to use on 4age Sun, 17 April 2005 10:50 Go to previous messageGo to next message
no performance upgrade is given by upgrading injectors with a stock ECU anyhow
shit its probably not even possible with the impedance differences and such
sideshow
Re: best injectors to use on 4age Sun, 17 April 2005 11:25 Go to previous messageGo to next message
all u do is maybe gain 5% up top if yr lucky and then fuck up the other 95% of rev range
say it so many times but not many listen
toyota spend many many hours perfecting the tune for good fuel economy and good power
so if u keep a std ecu keep the std injectors
full out power is shit if u get shit fuel economy or performance below 5000 on an everyday street car
Re: best injectors to use on 4age Sun, 17 April 2005 12:17 Go to previous messageGo to next message
hence my initial post.
stock engine = stock injectors.
hell, I've cranked another 30% power out of my baby and still running stock injectors.
Re: best injectors to use on 4age Sun, 17 April 2005 14:03 Go to previous messageGo to next message
Big enough to flow your power requirements. Considering you're not suggesting any major mods, standard is best.
September_Squall
Melbourne, Australia
March 2005
Re: best injectors to use on 4age Sun, 17 April 2005 18:08 Go to previous message
pazhon wrote on Sun, 17 April 2005 20:16
What you're suggesting is that more airflow (achieved by improved exhaust efficiency and better cylinder scavenging) will require more fuel delivery in absolute terms to maintain optimal AFRs.
This is technically correct, however standard injectors will be specced with a significant reserve, ie. at max fuel demand of the standard motor you'll only achieve 75%** duty cycle. So by increasing fuel demand slightly by increasing exhaust efficiency, you'll perhaps push the injectors to 78%** duty cycle now? They are still not in need of replacement with larger injectors.
Hope this is informative.
** this is a randomly selected figure used as an illustrative example only
shit, it's 4am... no wonder
Previous Topic:need as much 18RG info as possible
Next Topic:Buddy club wheels?
Current Time: Sat Oct 24 05:43:54 UTC 2026
Total time taken to generate the page: 0.0055618286132812 seconds
