Toymods » Tech & Conversions » need help on 100kw ecu connection!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
pkt-rkt
March 2005
    vz
need help on 100kw ecu connection!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Sun, 17 April 2005 10:50 Go to next message
Has anyone here done a ae82 100kw conversion, if so i need help!!!! i got the 100kw in all working but its got the 86kw ecu in still.
i need help on what and how to change to the 100kw as my car is stalling on idle with the 86kw ecu.
i will pay anyone around sydney to come out and wire it up properly for me.
i got the 100kw loom and the ecu so all i need is to get it in there
This is bad as its my daily driver.
sideshow
Re: need help on 100kw ecu connection!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Sun, 17 April 2005 10:53 Go to previous messageGo to next message
where r u located
pkt-rkt
March 2005
    vz
Re: need help on 100kw ecu connection!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Sun, 17 April 2005 12:16 Go to previous messageGo to next message
sydney fairfield
hey is it possible to use the 86kw loom and just repin the wires to the new 100kw ecu using a electrical diagram
we are trying it now since we go the diagram
FASTFOO
melb
February 2005
100kw will run on the 86kw elecs just use 86 kw dizzy and injectors
MATT.
pkt-rkt
March 2005
    vz
Re: need help on 100kw ecu connection!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Sun, 17 April 2005 12:21 Go to previous messageGo to next message
yer its all working man but i wanna chane this ecu as the 100kw doesnt work properly wit hthe 86ecu
the electricals are all fine just need change the ecu and to do that u need wire it up the way its meant to be ?
Hunty
Re: need help on 100kw ecu connection!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Mon, 18 April 2005 00:33 Go to previous messageGo to next message
dude
the 100kw motor will run fine on the 86kw ECU. But you just gotta use the 86kw sensors.
if its already wired up then swap the sensors to the 100kw ones and swap the ecus. the plugs on the bottom of the ECU are the same.
pkt-rkt
March 2005
    vz
Re: need help on 100kw ecu connection!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Mon, 18 April 2005 07:08 Go to previous messageGo to next message
u guys are great help
pkt-rkt
March 2005
    vz
Re: need help on 100kw ecu connection!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Tue, 19 April 2005 06:14 Go to previous messageGo to next message
hey hunty
the i got the 86kw sensors wit hte 86kw ecu running the 100kw engine and it has problems , like stalling on idle , and running rich.
the plugs are not the same ae82 are 14 16 18
and the ae92 are 10 12 26
LAA.80E
The realist ghetto area P...
April 2005
Re: need help on 100kw ecu connection!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Wed, 20 April 2005 00:20 Go to previous messageGo to next message
im pretty sure the 86kw ecu is different to the genuine 100kw , they way to tell is if the spark leads have a cover running over the top of them and if they do then your computer would be different the 86kw plugs are fluro in colour the 100kw ecu plugs are grey/black, also im pretty sure the map setting would be different but not all that much , but if you do change the sensors around what good is running a genuine 100kw??
pkt-rkt
March 2005
    vz
Re: need help on 100kw ecu connection!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Wed, 20 April 2005 06:51 Go to previous message
the 86kw plugs are yellow and the 100kw plugs are grey
i only reason i got the car running on the old ae82 stock loom is because i changed the engine loom plugs to fit the 100kw engine the ae82 were square and the 100kw ones are circle
Previous Topic:Bearings r shot, rebuild or new motor?
Next Topic:More "K" queries
Current Time: Thu Oct 15 12:38:36 UTC 2026
Total time taken to generate the page: 0.005659818649292 seconds
