Toymods » General Car Talk » 2tgeu upgrades??
lilcrash
ipswich queensland
2tgeu upgrades?? Sun, 17 April 2005 22:56 Go to next message
i am considering turbo/supercharfing my 2tgeu but wat super charger would i use and wat would get the best results??
i have found these options
3tgte turbo??
4agze charger??
1ggze charger??
wat would be a better option?
i have also heard that u can actually turn the supercharger off is that right or is it just constant boost??
thank you
September_Squall
Melbourne, Australia
March 2005
Re: 2tgeu upgrades?? Mon, 18 April 2005 06:20 Go to previous messageGo to next message
Supercharger has an electromagnetic clutch. In the factory application this clutch is controlled by the ECU in response to throttle input, etc.
CT20 turbo isn't much chop.
lilcrash
ipswich queensland
Re: 2tgeu upgrades?? Mon, 18 April 2005 11:39 Go to previous messageGo to next message
since the ct20 turbos are not much chop as u put it, does this make them easier/cheaper to obtain??
thanx again
p.s i only want maximum of 5psi boost
so i can run a supercharger off a switch to turn it on and off??
Re: 2tgeu upgrades?? Mon, 18 April 2005 14:13 Go to previous messageGo to next message
running a SC (like the 4agze or 1ggze) would also entail the ABV (air Bypass valve) and programable ecu to turn off/on the SC as well enabling the ABV when required. plus you'd have all manner of fabricated bracketry and piping. ABV is used to bypass the SC when you're not under boost.
Don't forget that going boosted SC or turbo would entail larger injectors and ECU. your factory hardware will not be up to the task of feeding and controlling a boosted engine.
probably (slightly) easier to go turbo, your main costs would be:
zorst manifold & dump
turbo
slightly larger injectors
programable ECU
get a cheap T25 turbo (ex RB20DET or similar) from ebay or similar - will cost you between $200-400. consdering you're only after 5psi, then a CT20 might do the job anyway.
manifold & dump from someone like exotic exhausts - $500-600
injectors - $100-150
ECU - pick a number between $500 and $1500
ann another $1k for things to fix/upgrade/improve while you're there.
An RB20 turbo is cheap enough to be a consumable item, plus it's a T3 flange making replacements easy to find and attach to the manifold.
lilcrash
ipswich queensland
Re: 2tgeu upgrades?? Tue, 19 April 2005 02:08 Go to previous messageGo to next message
hmmm. so the abv just puts the air away from the intake wen off boost??
would it be worth puttin a forced induction setup on??
like say i can get 120hp atw do i really need more??
120hp:900kgs = a pretty good ratio
idk, laterdays, thanx for the help
Re: 2tgeu upgrades?? Tue, 19 April 2005 03:49 Go to previous message
the ABV bypasses the supercharger so air flows straight from the throttle body to the intake instead of thru the charger.
turbo is always fun - but never cheap - how much fun do you want to spend?
Previous Topic:DRIFT AUSTRALIA Round 2 Mallala *Results*
Next Topic:(WTB) 18RG Manual in canberra
Current Time: Tue Oct 27 00:10:27 UTC 2026
Total time taken to generate the page: 0.016059875488281 seconds
