Toymods » Tech & Conversions » Adjustable Cam Gears
Big T
Adjustable Cam Gears Sun, 17 April 2005 23:53 Go to next message
Hey all. Just a simple question. If I were to get a stand alone ecu and have it properly tuned, is it redundant to get a set of adjustable cam gears as well? Don't cam gears retard/advance the ignition but isn't this what a tuned ecu would do anyway? Cheers guys.
Eddie.
RobertoX
Re: Adjustable Cam Gears Sun, 17 April 2005 23:58 Go to previous messageGo to next message
No cam gears retard/advance the cam timing not the ignition timing... (although I think that they will inadvertantely change the ignition timing as you will be putting dizzy out when you adjust the cam's Smile )
Big T
Re: Adjustable Cam Gears Mon, 18 April 2005 05:24 Go to previous messageGo to next message
ahh so it can create mechanical overlap of the cams that an ecu can't do then? Would people recommend using both aftermarket ecu and cam gears together then?
RobertoX
Re: Adjustable Cam Gears Mon, 18 April 2005 05:28 Go to previous messageGo to next message
I think you are on the right track there Smile
berad
Re: Adjustable Cam Gears Mon, 18 April 2005 05:29 Go to previous messageGo to next message
adjustable cam gears arent nessacery they will help with the right tuning and power. but you dont need them. id spend the cash on something else
Chris Davey
sunny coast, qld
Re: Adjustable Cam Gears Mon, 18 April 2005 06:34 Go to previous message
berad wrote on Mon, 18 April 2005 15:29
same. They just move the power band.
Previous Topic:1UZ measurements
Next Topic:thicker head gasket
Current Time: Sun Nov 1 19:38:10 UTC 2026
Total time taken to generate the page: 0.053874969482422 seconds
