Toymods » Tech & Conversions » thicker head gasket
kewp
wollongong
thicker head gasket Mon, 18 April 2005 01:07 Go to next message
If you get a thicker metal head gasket, how much will it reduce the compression by? On 20v for example, stock CR 11.5:1 how much lower could you get that will a thick head gasket?
ed_ma61
Lost in the K hole
Re: thicker head gasket Mon, 18 April 2005 01:09 Go to previous messageGo to next message
its worst way evah to reduce compression...
seriously
find another way to lower your comp
wagonist
Toymods Club Treasurer
Re: thicker head gasket Mon, 18 April 2005 02:13 Go to previous messageGo to next message
I agree with Ed, not the best way.
I've heard of people using a sandwich plate of metal between 2 head gaskets to reduce the compression, but then there's twice the chance of blowing one.
The only reason I can think of that you'd want to lower the CR on a 20V is for forced induction.
The 20V pistons aren't made for this & you'd be pulling them out shortly after you've broken them.
If you're going forced induction, either use the ZE pistons or get forged ones suited to the forced induction purpose which will already be made to make a lower CR.
gearb0x
Re: thicker head gasket Mon, 18 April 2005 03:42 Go to previous messageGo to next message
or u could keep the stock pistons, run low boost and get aftermarket tuning and make sure its spot on
would be fun Smile
kewp
wollongong
Re: thicker head gasket Mon, 18 April 2005 04:22 Go to previous messageGo to next message
Would the SAFC be ok to tune a turbo 20v. Also what injectors have higher flow and do not need modifications to fit?
berad
Re: thicker head gasket Mon, 18 April 2005 06:07 Go to previous message
id buy a whole standalone ecu not just safc etc... i thought about boostin my n/a engine a few years ago.. best bet is to save the cash and do it properly youll be running into problem every day otherwise i run into enough with an engine built for boost
Previous Topic:Adjustable Cam Gears
Next Topic:ignition barrel RA-23
Current Time: Mon Nov 2 06:06:06 UTC 2026
Total time taken to generate the page: 0.13530397415161 seconds
