Toymods » Tech & Conversions » How Loooooooow Can you Go !!!!!!
Les
How Loooooooow Can you Go !!!!!! Thu, 30 May 2002 23:56 Go to next message
Ok guys - how looooooooow can you go ?
We are talking how low the belly of your car sits, and exhausts and mufflers BUT not bodykits and shit ! Very Happy
  1. 1 "
  2. 1.5 "
  3. 2"
  4. 2.5"
  5. 3"
  6. 3.5"
  7. 4" (mine currently)
How low so YOU think is safe to drive
[Updated on: Thu, 30 May 2002 23:58]
Norm
Re: How Loooooooow Can you Go !!!!!! Fri, 31 May 2002 00:01 Go to previous messageGo to next message
My ute will be on the chassis rails soon Nod
Cheers Norm.
wyrd
Re: How Loooooooow Can you Go !!!!!! Fri, 31 May 2002 00:30 Go to previous messageGo to next message
mine is on the rails now Laughing has had the sills cut off and is sitting on the rockers hehehe and should be driving again tonight Very Happy
before this the lowest part was the sump which was 2" (50mm) from the ground.
you can never be too low
Assailant
"Cørønå ƒreåk"
Kellyville, Sydney
icon10.gif  Re: How Loooooooow Can you Go !!!!!! Fri, 31 May 2002 00:37 Go to previous messageGo to next message
Norm,
Are you getting hydraulics for your ute?
If so where from? whast type?
and how much is it costing you?
Norm
Re: How Loooooooow Can you Go !!!!!! Fri, 31 May 2002 03:08 Go to previous messageGo to next message
Wyrd, Would you be the owner of the WYRD rodeo Question
Assailant, I am getting airbags Nod
Cheers Norm.
wyrd
Re: How Loooooooow Can you Go !!!!!! Fri, 31 May 2002 04:06 Go to previous messageGo to next message
dat's me!
wait for an update on the oz minitruck forum
jza70-mel
Perth WA
Re: How Loooooooow Can you Go !!!!!! Fri, 31 May 2002 11:07 Go to previous messageGo to next message
Good to see guys!
Just a question (or few) about height adjustable suspension though - does it help the handling of the car, or is it for looks? Does it put out the alignment every time you raise the ride height? It certainly would be good to be able to go over speed bumps without scraping the exhaust.
LiL_MiC
Melb
Re: How Loooooooow Can you Go !!!!!! Fri, 31 May 2002 11:27 Go to previous messageGo to next message
i'm not too sure of mine..but it has been dumped over 3.5 inches Razz
Apollo
Brisbane, QLD, Australia
Re: How Loooooooow Can you Go !!!!!! Fri, 31 May 2002 11:57 Go to previous messageGo to next message
Queensland transport:
Quote:
The road clearance of a motor car must not be less than 100mm
measured at any part of the vehicle other than the wheel rim
or brake backing plates. (This does not apply where a lesser
clearance has been specified by the manufacturer.)
When lowering or raising a vehicle body (front or rear):
• the suspension travel in the bump or rebound mode must
not be altered by more than one-third of that specified
by the manufacturer;
• coil springs are to remain in locating seats on full
suspension droop without forcibly being removed.
In addition, the normal relationship between the front
and rear suspension heights must not be unduly affected.
Suspension coil springs must not be shortened by cutting.
Leaf spring suspensions must not be raised by the use of
extended shackles or adjustable metal plates. If lowering
blocks are used, they must be either steel or aluminium.
RA23_Sean
Western Sydney
Re: How Loooooooow Can you Go !!!!!! Sun, 02 June 2002 07:59 Go to previous messageGo to next message
It's the same in NSW.
Redline
Shellharbour
Re: How Loooooooow Can you Go !!!!!! Sun, 02 June 2002 08:54 Go to previous messageGo to next message
ill have to ask my cy couz how low his soarer is, u cant fit ur finger between the top of the wheel ( low profile 18" wheels) and the tyre arch, so its pretty damn low!
wyrd
Re: How Loooooooow Can you Go !!!!!! Sun, 02 June 2002 09:04 Go to previous messageGo to next message
jza70-mel - i have only driven mine for a couple of hours, but i would say that the handling isnt as tight as it used to be (torsion bars wound down and reset, riding on the bump stops in the front; 3" blocks, reset leaves, c-notch in the back)because it isnt as stiff anymore. Altho you can make the ride stiffer with bags just by putting more air into them.
Now it rides smooth like a limo, instead of bouncing around and jarring your back over any bump (i have a female friend that used to complain about having to wear a sports bra)
-Matt
AE86_Sprinter
Perth, WA
Re: How Loooooooow Can you Go !!!!!! Thu, 06 June 2002 04:40 Go to previous messageGo to next message
Hey guys,
I am thinking on building a lo-lux very soon, can you guys direct me to a decent forum? I would be interested especially in ozzie sites
Mike
showtime
Castle hill / Campbelltown
icon10.gif  Re: How Loooooooow Can you Go !!!!!! Thu, 06 June 2002 05:55 Go to previous messageGo to next message
I would love to drop my van another inch but it's so fkn stiff at the moment that it hurts ur kidneys after a while anyone got any ideas and where canu buy lowering blocks from as repco don't stock them no more ???? Up To Something
Pube
Camden
Re: How Loooooooow Can you Go !!!!!! Thu, 06 June 2002 06:50 Go to previous messageGo to next message
It all depends on how many bags of cement i can fit in the boot and back seat or how many rocks i can find or even bricks. It also depends on how siiik i want to be, but i always know i am fully siiik wheni get good bounce happening when i go over bumps.
Les
Re: How Loooooooow Can you Go !!!!!! Thu, 06 June 2002 06:58 Go to previous messageGo to next message
hmm im suprised u did not say that your car is a pube's width from the ground..... Evil or Very Mad
Flem
cambo
Re: How Loooooooow Can you Go !!!!!! Sat, 08 June 2002 12:18 Go to previous messageGo to next message
used to be 600mm from the headlight to the ground
[mikey]
Re: How Loooooooow Can you Go !!!!!! Sat, 08 June 2002 23:20 Go to previous messageGo to next message
Sure low looks good....but for a car you drive everywhere its not practical.....mine sits around 1 1/2" and thats so my exhaust doesnt make love to the ground anymore....it will depend on your driving style and where she is taken....but i surely couldn't enjoy driving a car dumped 3" from factory just to look good....you would have to worry about every bump on the road. show cars that don't get driven dont have to worry about it this...
michael
LowRollaBoy
Melbourne.
Re: How Loooooooow Can you Go !!!!!! Thu, 01 May 2003 01:17 Go to previous messageGo to next message
WYRD! Hey man, i bought TOY.SLD off Pete a while back Wink
Saw ur Truck and SIRLUX at F.T! I love em!
-blown20v-
Re: How Loooooooow Can you Go !!!!!! Thu, 01 May 2003 05:55 Go to previous messageGo to next message
hey guys..
my mate had an ae82 rolla hatch that had stock rims on it(13' i think) anyways it was low enuff to have all four rims up in the guards.. Shocked Shocked
DannyGT4
Toymods Board Member
Re: How Loooooooow Can you Go !!!!!! Thu, 01 May 2003 07:07 Go to previous messageGo to next message
LowRollaBoy wrote on Thu, 01 May 2003 11:17
...and the award for reviving a long dead thread goes to....
*drum roll*
LowRollaBoy!!
Congratulations dood... a 1yr old post
Rolla Boy
Club Member
Sydney, NSW
Re: How Loooooooow Can you Go !!!!!! Thu, 01 May 2003 09:36 Go to previous messageGo to next message
DannyGT4 wrote on Thu, 01 May 2003 17:07
*drum roll*
LowRollaBoy!!
Nice one Danny...
LowRollaBoy
Melbourne.
Re: How Loooooooow Can you Go !!!!!! Thu, 01 May 2003 09:43 Go to previous messageGo to next message
Good on ya smartass.
LadySX
Re: How Loooooooow Can you Go !!!!!! Thu, 01 May 2003 13:34 Go to previous messageGo to next message
Wow I hadn't even noticed how old the thread was!!
Must take some major boredom to bother looking at the dates!! Rolling Eyes
LowRollaBoy
Melbourne.
Re: How Loooooooow Can you Go !!!!!! Fri, 02 May 2003 01:13 Go to previous messageGo to next message
ITs called the "Search" feature u moronic rude bastards.
Cant a fellow Toyota Trucker search for minitruck topics?
Farkn hell ur all knobs.
LadySX
Re: How Loooooooow Can you Go !!!!!! Fri, 02 May 2003 01:41 Go to previous messageGo to next message
I wasnt referring to you Jon, I was referring to DannyGT4
DannyGT4
Re: How Loooooooow Can you Go !!!!!! Fri, 02 May 2003 02:21 Go to previous messageGo to next message
LadySX wrote on Thu, 01 May 2003 23:34
lol... i'd like to think that i was being efficient Razz
but things were pretty quiet at work Smile
lol... dood... i was hardly rude about it...
reviving dead threads is ok if you have something significant to add but don't make a habit of doing it to say hello to someone as the forums are clutterred enough as it is
and um... *coughs* i wouldnt make a habit of calling moderators "knobs"
Wink
LadySX
Re: How Loooooooow Can you Go !!!!!! Fri, 02 May 2003 02:26 Go to previous messageGo to next message
I wasn't being rude or saying my last post with attitude either. Just wanted to say that Smile
I am never rude, and don't even know what attitude is Very Happy
St3ve_AE92
South of Wollongong
Re: How Loooooooow Can you Go !!!!!! Fri, 02 May 2003 05:38 Go to previous messageGo to next message
Well now that this thread has come back to life...i may aswell share these pictures. this isnt my car, and i forget whos car it is...i thought it was pretty low. Enjoy Very Happy
DUMPED ae92 seca...
http://homepages.ihug.com.au/~combe/Images/DSC0004 7.JPG
http://homepages.ihug.com.au/~combe/Images/DSC0004 8.JPG
http://homepages.ihug.com.au/~combe/Images/DSC0005 0.JPG
Quote:
DannyGT4 wrote:
and um... *coughs* i wouldnt make a habit of calling moderators "knobs" Wink
Laughing Laughing Laughing
i agree
manipulate
Re: How Loooooooow Can you Go !!!!!! Fri, 02 May 2003 09:50 Go to previous messageGo to next message
LadySX u better watch that mouth of yours
Rolla Boy
Club Member
Sydney, NSW
Re: How Loooooooow Can you Go !!!!!! Fri, 02 May 2003 10:06 Go to previous messageGo to next message
Grass doesn't count Steve... Especially grass on a mound Twisted Evil Twisted Evil Twisted Evil ...
Get some pics of it on tar and then post them...
LadySX
Re: How Loooooooow Can you Go !!!!!! Fri, 02 May 2003 16:20 Go to previous messageGo to next message
Manipulate: And why is that??????
manipulate
Re: How Loooooooow Can you Go !!!!!! Fri, 02 May 2003 23:56 Go to previous messageGo to next message
Heh just stirring
u werent being a smartass b4 but ppl thought u were...so i thouuhght id add to the confusion
Smile
LadySX
Re: How Loooooooow Can you Go !!!!!! Sat, 03 May 2003 09:36 Go to previous messageGo to next message
Aaahhh o.k then Smile
I got scared for a minute and thought you were going to be waiting for me outside the milkbar late at night with a gun Sad
I can put my grenade away now Laughing
manipulate
Re: How Loooooooow Can you Go !!!!!! Sat, 03 May 2003 11:08 Go to previous messageGo to next message
LadySX wrote on Sat, 03 May 2003 19:36
Haha...if you're being serious, sorry about that
Razz
pro_ke
adelaide
Re: How Loooooooow Can you Go !!!!!! Sun, 04 May 2003 10:31 Go to previous messageGo to next message
not sure how far off the deck mine is but i think it would be less than 3 inches at the lowest point. its a fucking bitch to drive, every little bump in the road sends a huge jolt through the car and it gives me a sore back after a while.
ab
LadySX
Re: How Loooooooow Can you Go !!!!!! Sun, 04 May 2003 12:26 Go to previous messageGo to next message
thats o.k manipulate. Usually I can take a joke to almost any extreme, but not knowing who the hell you are, well I didn't really know which way to take it. From now on I will take all your posts as an invitation to laugh Very Happy
TheStitt
Membership Secretary
Re: How Loooooooow Can you Go !!!!!! Sun, 04 May 2003 22:55 Go to previous messageGo to next message
If any one is still around that started this thread what are air bags worth.
Also I droped my car 6" at the front and between 4 and 5" in the rear. If anyone can tell my they dropped anything bar a 4wd lower I would be mighty surprised. My car still is legal the lowest point is still well above the 100mm and it has been dropped that far.
pro_ke
adelaide
Re: How Loooooooow Can you Go !!!!!! Mon, 05 May 2003 11:59 Go to previous messageGo to next message
TheStitt wrote on Mon, 05 May 2003 08:55
i reckon my corolla is close to 5 inches down in the back and about 4 in the front, maybe more
ab
Hunty
Re: How Loooooooow Can you Go !!!!!! Mon, 05 May 2003 12:28 Go to previous message
5 inches in the rear?? i'd like to see that, mine is 2.5 inches and its a massive pain in the ass the ride is so stiff there is only like another inch, inch and a half of travel left in the rear shocks
Previous Topic:turbo manifolds
Next Topic:removing front wheelbearings
Current Time: Mon Oct 26 07:32:38 UTC 2026
Total time taken to generate the page: 0.0065388679504395 seconds
