Toymods » Tech & Conversions » Help needed: car starts but goes off right away.
dingaling
tas
icon8.gif  Help needed: car starts but goes off right away. Sat, 16 November 2002 09:04 Go to next message
i really need someone's advice with this, the car is a corona 78'
and just today it wasn't starting properly, you turn the key and the car will start but as soon as you let go of the key the car goes off, i'm thinking it might be electrical, or something to do with the ignition coil, but i'm not sure, has anyone else had this problem? what wouold be the likely culprit? any help will be greatly appreciated.
cheers,
chris
cjdoolan@yahoo.com.au
Bugman
Re: Help needed: car starts but goes off right away. Sat, 16 November 2002 09:12 Go to previous messageGo to next message
sounds like the main fuse.
is the red 'charge' light coming on?
from memory it should be about a 20amp fuse or there abouts.
dingaling
tas
Re: Help needed: car starts but goes off right away. Sat, 16 November 2002 09:21 Go to previous messageGo to next message
yes the red light comes on, any other suggestions?
Bugman
Re: Help needed: car starts but goes off right away. Sat, 16 November 2002 09:22 Go to previous messageGo to next message
did you check all the fuses? all of them.. you never know whats happened with the wiriing in the past or who has worked on it
dingaling
tas
Re: Help needed: car starts but goes off right away. Sat, 16 November 2002 09:29 Go to previous messageGo to next message
i'll have to check, i'll get back to u soon on that.
i woulda thought that if the fuse was blown that it wouldn't work at all, as it still starts, it just doesn't stay on unless you hold the key on.
Bugman
Re: Help needed: car starts but goes off right away. Sat, 16 November 2002 10:01 Go to previous messageGo to next message
I once did that while driving.. took a while.. I checked everything.. then I thought... hmm.. checked fuses, ended up being the one makred "engine"
I could turn the key it'd crank and start.. I could even rev it while I had the key fully turned, but as soon as I relesed the key it would shut off.
AbaddonGZE
Re: Help needed: car starts but goes off right away. Sat, 16 November 2002 10:36 Go to previous messageGo to next message
hehe "engine"
dingaling
tas
Re: Help needed: car starts but goes off right away. Sun, 17 November 2002 00:12 Go to previous messageGo to next message
bugman your a legend, works perfectly now, about 3 fuses replaced, had to roll start it as the battery was flat, but it started perfect and stayed on. :)-
cheers,
chris
Bugman
Re: Help needed: car starts but goes off right away. Sun, 17 November 2002 00:15 Go to previous message
go through and change all the fuses, them glass fuses are shit.. just change em all to be on the safe side
Previous Topic:4AGZE prob: oil residue in intercooler piping.
Next Topic:Getting air ?
Current Time: Wed Oct 28 22:42:51 UTC 2026
Total time taken to generate the page: 0.0055701732635498 seconds
