Toymods » Tech & Conversions » 6m-ge performance bits
Allan
6m-ge performance bits Tue, 19 April 2005 10:16 Go to next message
Anyone know if any mildly exciting 6m-ge camshafts exist in australia? and / or specs? also does anyone have pics of acl replacement 5m-ge pistons? ( ie are they the same as 6m-ge ones? )
Re: 6m-ge performance bits Tue, 19 April 2005 10:20 Go to previous messageGo to next message
could you get someone like ivan tighe <http://www.tighecams.com.au/> to grind custom cams?
BlackSupra
Re: 6m-ge performance bits Tue, 19 April 2005 10:23 Go to previous messageGo to next message
i gave ed a scan of a 6mge cam grind that was a copy of a HKS cam
EDIT:
http://www4.tpgi.com.au/users/loats/technical/7mge/images/camshafts/6mcamspecsIN.jpg
http://www4.tpgi.com.au/users/loats/technical/7mge/images/camshafts/6mcamspecsEX.jpg
Copies of HKS camshafts from a guy in the states.
[Updated on: Tue, 19 April 2005 10:29]
Allan
Re: 6m-ge performance bits Tue, 19 April 2005 11:20 Go to previous messageGo to next message
thanks... see what happens if i end up mucking around with this engine
ZZT231
melbourne.vic.au
Re: 6m-ge performance bits Tue, 19 April 2005 11:45 Go to previous messageGo to next message
Allan,
You need to finish your 5M-E hybrid first Razz
Cheers.
Allan
Re: 6m-ge performance bits Tue, 19 April 2005 13:08 Go to previous messageGo to next message
ZZT231 wrote on Tue, 19 April 2005 21:45
Allan,
Cheers.
not if this 6m works out better value Razz
thetoyman75
Club President
Re: 6m-ge performance bits Tue, 19 April 2005 13:20 Go to previous messageGo to next message
Allan,
If your actually serious about the 6M-GE project and going to shell out some $$$ the speak to Graham Wilkins from Wilkins Performance Engines in Seven Hills. He used to build the Racing 5M-GE engines for one the the MA61 Supra racing teams, Can't remember which one.
Rod
Allan
Re: 6m-ge performance bits Tue, 19 April 2005 13:33 Go to previous messageGo to next message
nah im not going to shell out major $$$ i have a mate at a mechine shop that spins stuff up for me for a pack of smokes and bottle of coke so stuff like adjustable cam gears etc are on the cards!
maybe stretch it get some cams ground up somewhere but other then that it will be budget performance Razz unless i get some fantastic job! so i wont go tire kicking Graham Wilkins just yet Smile thanks for the tip tho master Rod (never did see your 5m-ge on the dyno Razz ) apparently 5m-ge's in race trim pushed out ~300hp!!!
~200hp in an ma45 should be fun
still looking for confirmation 5m-ge pistions available from acl are the same as 6m-ge ones (dont want any less then 9.2:1CR )
Re: 6m-ge performance bits Tue, 19 April 2005 14:31 Go to previous messageGo to next message
There are two versions of 5M-GE pistons, one is the same as the 6M-GE the other is a little different. Can't remember which is which, but check on the CelicaSupra forums, it's a frequent topic of discussion so you'll find the answer somewhere.
Re: 6m-ge performance bits Tue, 19 April 2005 14:42 Go to previous messageGo to next message
All Aus 5MGE's are the same as the 6MGE (bar the crank, rods, pistons etc)
I'm 90% sure the MX73 Cressida was the only Aus delivered car to have the 5MGE (Supras, Crowns, Soarers were all imports or 5ME's)
There are many ways of telling early 5mge and late 5mge apart, and I've typed it at least a dozen times on this forum, so if you want to know, you know how to find it.
Allan
Re: 6m-ge performance bits Wed, 20 April 2005 01:40 Go to previous messageGo to next message
Norbie wrote on Wed, 20 April 2005 00:31
CrUZsida wrote on Wed, 20 April 2005 00:42
i know theres differences im looking for someone that has got replacement pistons from ACL to tell me what ones ACL have, im guessing that the 6m-ge 9.2:1 piston is the same as lower 8.8:1 compression 5m-ge ones? (some 9.2:1 5m-ge ones could be fun Very Happy)
Re: 6m-ge performance bits Wed, 20 April 2005 01:44 Go to previous messageGo to next message
I'd be using the 9.2 5MGE pistons.
Should get about 9.8:1 in the 6MGE.
But yes, the 8.8 5MGE pistons are the same as the 9.2 6MGE pistons.
bbaacchhyy
Re: 6m-ge performance bits Wed, 20 April 2005 03:18 Go to previous messageGo to next message
CrUZsida wrote on Wed, 20 April 2005 00:12
MS123 Crowns had the 5M-GE as well didn't it ?
Re: 6m-ge performance bits Wed, 20 April 2005 03:22 Go to previous messageGo to next message
I've never been sure as to which crowns are imports, and which crowns are aus delivered.
And which ones have had conversions, and which ones are stock.
Allan
Re: 6m-ge performance bits Wed, 20 April 2005 06:10 Go to previous messageGo to next message
CrUZsida wrote on Wed, 20 April 2005 11:44
thats the whole idea Smile
thetoyman75
Club President
Re: 6m-ge performance bits Wed, 20 April 2005 12:58 Go to previous messageGo to next message
The series 2 MS123 Crown (1987) was sold local and had the 5M-GE as factory fitment Smile. Its the series 2 digital 5M-GE.
Allan
Re: 6m-ge performance bits Thu, 21 April 2005 00:37 Go to previous messageGo to next message
thetoyman75 wrote on Wed, 20 April 2005 22:58
and what compression ratio is it??? Smile
Re: 6m-ge performance bits Thu, 21 April 2005 00:40 Go to previous messageGo to next message
Series 2 digital 5MGE is just a fancy way of saying later model 5MGE.
ie, 9.2:1
Allan
Re: 6m-ge performance bits Thu, 21 April 2005 00:43 Go to previous message
ok rod all your pistons belong to me!!!!
Previous Topic:Leaf to Coil Conversion????????
Next Topic:removing rear swaybar ae112
Current Time: Thu Oct 22 22:39:07 UTC 2026
Total time taken to generate the page: 0.0065970420837402 seconds
