Toymods » Tech & Conversions » 1jz - Looking for simple answer
kyler
1jz - Looking for simple answer Wed, 20 April 2005 03:32 Go to next message
Hi guys.
I hope someone has a simple answer to this problem.
My brother just got a 1994 TT Soarer. Now after a nice cruise, he'll pull into the driveway, go over a dip (not sure if this is part of the problem) and then the temp guage will jump from 1/2 (where it should be) up to full and make warning beeping noises. Then all of a sudden, it will drop back down to half. Sometimes it stays up on full for a while.
My brother was concerned that his car was overheating but I assumed it may just be a faulty temperature sensor or wiring for the the sensor as I didn't think it possible for a car to increase its heat this fast while at about 1000rpm pulling into a carpark. It has all new fluids.
Does this sound right or should he have the car looked at?
-==L=a=N=c=E==-
Brisbane, Queensland
Re: 1jz - Looking for simple answer Wed, 20 April 2005 03:34 Go to previous messageGo to next message
Check the wire going to the water temp sensor, it maybe loose.
This happened on my car, the wire was loose (actually broke off when i was looking at it) and my temp gauge was all over the shop.
Danners
Central Coast, NSW
Re: 1jz - Looking for simple answer Wed, 20 April 2005 04:18 Go to previous messageGo to next message
Could also be an air bubble floating around in the cooling system. I suggest "burping" the car by parking it facing upwards on a hill and flushing the system out, then refilling with coolant
Dan
indian
south east - melbourne
Re: 1jz - Looking for simple answer Wed, 20 April 2005 04:54 Go to previous messageGo to next message
might help replacing the thermostat too while ur flushin the system
sideshow
Re: 1jz - Looking for simple answer Wed, 20 April 2005 05:32 Go to previous message
its a bad earth for the temp gauge
if the temp sender is connected but the earth for the gauge isnt
then the gauge will read hi
no amount of air pocket will make the temp jump so hi
i have fix probs like this before and its a bad earth for the temp gauge
Previous Topic:More "K" queries
Next Topic:Making sense of dyno reading
Current Time: Sun Oct 18 03:17:35 UTC 2026
Total time taken to generate the page: 0.0073840618133545 seconds
