Toymods » General Car Talk » Modifying 7MGTE Internals
hamgatan
Modifying 7MGTE Internals Wed, 20 April 2005 06:51 Go to next message
My Head Gasket is still fine, but id rather blow the head off the snake from 100m away before it comes to bite me if you get my drift. Thus im going to get the whole thing done properly..
Mind you with the pain that its going to cause my by decking the block and machining it and all the rest. Ive decided that i only ever want to pull the block out once in the next 5 years so any internal modifications i want to make are going to get done at the same time that i do my Head Gasket.
So..
This is the list of what ive got in mind to chuck into it (I'll order it from the US next month)
- JE Forged Pistons (.020 Over) - $750ish USD (Rings Included)
- Crower Forged Billet Rods - $980ish USD
- GReddy 2mm MHG (85mm Bore) - $175 USD
- ARP Head Studs - $119 USD
My question here is what else should i be ordering to change internally so that i dont need to pull the head apart again for literally the life of the car... Valves? Etc..?
Recommendations?
Re: Modifying 7MGTE Internals Wed, 20 April 2005 07:15 Go to previous messageGo to next message
My question here is, why spend $3000 on a 7MGTE when you can just drop a 2JZGTE in there and get more power and more reliability?
hamgatan
Re: Modifying 7MGTE Internals Wed, 20 April 2005 07:25 Go to previous messageGo to next message
Because its hardly ever $3000 at the end of the day.. it'll be double that.
Also because im happy with the 7M.. besides a few issues i know need fixing. Once youve done the MHG theyre literally bulletproof anyway. Im not looking to get anymore than 500hp out of it anyway (at the flywheel). I do however want to run a reasonable T04 setup later on thus the requirement i have to make the internals rock hard in case i fiddle too much with the AVC-R and screw something up..
Last but not least, the transplant was engineered and i have a compliance plate on the firewall to stick up any coppers arse that tries to get smart with me. I might have a harder time explaining a 2JZ..
hamgatan
Re: Modifying 7MGTE Internals Wed, 20 April 2005 07:30 Go to previous messageGo to next message
Oh and four.. i cant afford to have it off the road for more than a few days at a time. I need it for Work.. 2JZ Transplant = too much unreliability based on teething issues to constitute the effort..
Re: Modifying 7MGTE Internals Wed, 20 April 2005 07:32 Go to previous messageGo to next message
A copper will sticker you whether you can prove something or not, so don't expect it to be all good just coz its legal.
And a 2jz conversion would have to be engineered anyway.
By the time you do all that to the motor, plus the turbo, and the ecu, and the injectors, etc etc etc, you'll be about $1000 cheaper, than if you bought a 2jzgte and did the same (bar the internals).
Plus you'd be able to sell a good condition 7mgte will full loom and ecu.
I'm not talking you out of it, I'm just trying to offer, what I see as, a more sensible solution.
Re: Modifying 7MGTE Internals Wed, 20 April 2005 07:33 Go to previous messageGo to next message
hamgatan wrote on Wed, 20 April 2005 15:30
But you expect to remove a 7mgte, deck the block, hone the bores, and rebuild it all in a few days?
hamgatan
Re: Modifying 7MGTE Internals Wed, 20 April 2005 07:42 Go to previous messageGo to next message
say anywhere up to a week. not me doing it of course.. too busy at work, but ive got a mechanic onhand to do it for me..
the other thing is that everyone does the 1JZ/2JZ option and noone really gives the 7M the love it deserves. apart from the hg, its a good engine. i reckon i'll give it a chance and see what i can make out of it. The MA70 is a Freeway Cruiser.. not a 400m Bullet..
[Updated on: Wed, 20 April 2005 07:45]
Re: Modifying 7MGTE Internals Wed, 20 April 2005 07:50 Go to previous messageGo to next message
A lot of people are doing the JZ series because its a better motor.
The whole fact that the block isn't design back in the mid 70's is a plus.
I just think for the small extra outlay, the returns will be much greater thats all
hamgatan
Re: Modifying 7MGTE Internals Wed, 20 April 2005 07:55 Go to previous messageGo to next message
i suppose.. but its a pain in the arse to do as well Smile fact is im going to keep the supra as a powerful cruiser and get a JZZ30 early next year as well as an initial family car (yeah its 2 door but least its roomy as all hell).. so yeah ill have a JZ series to pump the crap out of then. problem is that im fussy and i want a JZZ30.. but i want the interior that usually only comes with the UZZ's.. (the GTL Leather)
BlackSupra
Re: Modifying 7MGTE Internals Wed, 20 April 2005 07:58 Go to previous messageGo to next message
CrUZsida wrote on Wed, 20 April 2005 17:32
Put a 1uz in a cressida, its a cheap conversion!
oh hang on.......
Re: Modifying 7MGTE Internals Wed, 20 April 2005 08:27 Go to previous messageGo to next message
BlackSupra wrote on Wed, 20 April 2005 15:58
oh hang on.......
It could have been cheap, and I was still way under 3k when I drove it out of the garage under its own steam...
hamgatan
Re: Modifying 7MGTE Internals Wed, 20 April 2005 09:13 Go to previous messageGo to next message
still doesn't tell me though what else i should be looking to upgrade/replace while the blocks out.. Confused
Re: Modifying 7MGTE Internals Wed, 20 April 2005 09:20 Go to previous messageGo to next message
Any part that moves.
Or is in contact with a moving part.
bbaacchhyy
Re: Modifying 7MGTE Internals Wed, 20 April 2005 22:45 Go to previous messageGo to next message
hamgatan wrote on Wed, 20 April 2005 18:43
It seems that you are intent on keeping with the 7M, so here goes what I would be doing...
Forget about the Rods unless you want to go for really high HP. Evidence from the states (for what it is worth) and others that the rods are good for about 500HP plus.
One thing that seems to be an issue is the oil pump. Buy a NEW one from Toyota and make sure the clearances are really good. There are NO High Volume pumps available off the shelf for 7M's despite claims.
Personally, I have been thinking of going down the route that you are heading (albeit with a spare engine), but the costs of doing a decent job, and the pics of the V8 nestled in the bay of a MA61 are proving very appealing. And when you add the results of JustenGT4 with the TT1UZ, it gets even more appealing.
I have a spare head (actually 2 in the shed) and some gaskets, but if they go, a quick swap job and some investnment in 1UZ gear may be the go....
Good luck and keep us informed of what the costs and results are
Michael B
OH, and BTW, be aware of customs and GSt on getting things from the states. They even apply GST to the postage !!!!
hamgatan
Re: Modifying 7MGTE Internals Thu, 21 April 2005 00:45 Go to previous messageGo to next message
Thanks Michael,
Some US States apparently have huge Tax Levies on top of like 20% (New Jersey for Example). I'll have to ask the fellas over there if they have any tax exemptions for it leaving the country etc..etc.. Like when i was looking at the Erebuni kits before they said that i can have 20% off because its going international. Some states have offered me 5%
Else i'll get them to EMS them in 4 separate packages marke 'Gift' and separately mail the receipt Smile
Should i just clean the stock rods up then yeah?
What else have i missed internally that i should be changing if i want to put 500hp through it max and for it to be literally bulletproof..? Valve Springs? Cams? Etc..
Reason im asking that is im not sure exactly whats inside the block.. besides the pistons, cams, rings & rods..
Re: Modifying 7MGTE Internals Thu, 21 April 2005 00:55 Go to previous messageGo to next message
Michael has already suggested to get a new oil pump.
Also looking into bearings.
While the engine is out, get the crank balanced, as well as all the rods/pistons/bigends etc.
If it moves get it balanced.
Anything in the head (besides the valves) can be done with the motor in situe.
bbaacchhyy
Re: Modifying 7MGTE Internals Thu, 21 April 2005 01:05 Go to previous messageGo to next message
Cams can be had, but they are expensive (over $1k each).
Depending on what computer you are using, cam gears might be an option.
Not many people have installed/run bigger valves in a 5/6/7M, so they may not be worth it.
Look at Ed's page for tips and tricks re porting the head.
You can try marking things as gifts, but customs people are not that silly. They have an idea of what is going on, and a USD$1k (?) body kit will be hard to convince that it is a gift, but go for it !!!
The main bearing that the states people use is Cleveite (i think that is the correct spelling).
As I mentioned before, when adding up the costs, the 1UZ seems VERY appealing.
BTW, I have a MHG (Cometic) that you can grab off me if you want Very Happy
Allan
Re: Modifying 7MGTE Internals Thu, 21 April 2005 01:14 Go to previous messageGo to next message
contact specialised piston services down here in victoria might be better then importing!
other then that i am also of the view that rebuilding the 7m and keeping the factory engine has advantages over a swap unless you have lots of money or a cheap 2jz and lots of time
hamgatan
Re: Modifying 7MGTE Internals Thu, 21 April 2005 01:24 Go to previous messageGo to next message
How much do you want for the MHG Mike? Also youve got those ARP's as well dont you? Computer, id be sticking with the stock 7M one right now because im unfortunately stuck with the Auto trannie and theres no point me changing the ECU with that thing in place till i do an R154 swap, but thats waaaay later down the track. Besides, keeping the Auto trannie is a good sure-fire way to resist the temptation to drive her too hard.
Allan - Thanks, Might give them a bell. Just heard good stories about the JE's thats why they were my first stop.
Allan
Re: Modifying 7MGTE Internals Thu, 21 April 2005 06:18 Go to previous messageGo to next message
nothing wrong with the auto get a shift kit and a 3000rpm stall be quicker then any manual... also looking at disconneting the brake switch from the auto trans ecu (only when pwr buttion is pressed ((ie not interested in saving fuel mode))) so it keeps the torque converter locked when the brakes are applyed until the low rpm point is reached, should help with those unstable moments thru twisties where it feels like someone put there foot on the clutch
Re: Modifying 7MGTE Internals Thu, 21 April 2005 06:28 Go to previous messageGo to next message
3000rpm stall? ON a street driven car?
pffft, just get a manual.
EDIT: ON
[Updated on: Thu, 21 April 2005 06:28]
Allan
Re: Modifying 7MGTE Internals Thu, 21 April 2005 06:31 Go to previous messageGo to next message
CrUZsida wrote on Thu, 21 April 2005 16:28
EDIT: ON
yep on a car with a shift kit and a lock up torque converter it just drives nice and smooth under light throttle openings and then locks up so no insane slipping while cruising Smile
Chris Davey
sunny coast, qld
Re: Modifying 7MGTE Internals Thu, 21 April 2005 12:09 Go to previous messageGo to next message
Allan wrote on Thu, 21 April 2005 16:31
EDIT: ON
Sounds like a plan to me Smile
If I were in your position, I would rebuild the engine as well. A 1uz would be nice but that is not going to be cheap to make 500hp. Conversions aren't cheap especially if you are paying for labour so I would stick with the 7m.
bbaacchhyy
Re: Modifying 7MGTE Internals Fri, 22 April 2005 03:05 Go to previous messageGo to next message
[quote title=Chris Davey wrote on Thu, 21 April 2005 21:39
[/quote]
Labour would be by me, even rebuilding the engine, but it is all of the sundry parts in rebuilding an engine that can add up very quickly.
I'll be keeping my options open, but will keep an eye on Hamgatan to see what his final total is
hamgatan
Re: Modifying 7MGTE Internals Fri, 22 April 2005 03:36 Go to previous messageGo to next message
I would like to avoid unneccessary things obviously, so yeah if the Rods aren't neccessary then fudge em. Avoid unneccessary things, without cutting Corners is what i mean to say..
HKS_TRD
Re: Modifying 7MGTE Internals Fri, 22 April 2005 17:50 Go to previous message
The standard rods are fine. I've managed 302kw at the wheels with them so far and I'll be looking to make more soon. One important point with regards to your rebuild the 7M plan versus engine swap. If you rebuild the 7M you have a fresh motor as opposed to a secondhand motor. This was one major factor that made me decide to rebuild mine, that and all the 7M parts I had around. A tip if you go with JEs get them machined to take standard Toyota rings the JE rings are thinner and engine life will be shorter. Don't worry about cams unless you run a big turbo.
Dan
Previous Topic:Motorkhana
Next Topic:consult stuff
Current Time: Thu Nov 19 00:30:46 UTC 2026
Total time taken to generate the page: 0.010382890701294 seconds
