Toymods » Tech & Conversions » 4age short sump
RouwT
holland
4age short sump Wed, 20 April 2005 08:01 Go to next message
Hey all,
I destroyed my sump last night on a speed hump, As you can see I drive a kitcar fitted with a 4age engine, and the sump sticks out some 4-5 cm (about 2") underneath the chassis rails, That's to much, the engine can't go higher, as the bonnet then wil not close again. overall chassis ground clearance is about 8cm, so it's LOW.
anyway I thought up this picture of a short sump, but the problem is I don't know if this ould work because I've never seen one. it's easiest for me to lengthen the sump instead of widening, because of the engine-mount arrangement (non Toyota)
here it is. so tell, me would this work? Rolling Eyes
http://venixjr.student.utwente.nl/thomas/gallery/albums/album09/4age_short_sump_eng.jpg
regards Thomas
http://www.jwkoelewijn.nl/thomas
[Updated on: Wed, 20 April 2005 08:10]
Re: 4age short sump Wed, 20 April 2005 08:13 Go to previous messageGo to next message
Have you considered converting to dry sump?
Re: 4age short sump Wed, 20 April 2005 08:15 Go to previous messageGo to next message
http://www.hasselgren.com/id29.htm
http://www.hasselgren.com/0f3d34d0.jpg
http://www.hasselgren.com/0f4a5420.jpg
http://www.hasselgren.com/0f5dd730.jpg
RouwT
holland
Re: 4age short sump Wed, 20 April 2005 08:25 Go to previous messageGo to next message
Far to bloody expensive!
a system like that use lower grade pumps would cost about the priece of 10 engine's over here(europe Holland), so not an option.
and as far as space alows, I need to realy look hard to find a place for the pumps and drysump tanks to be fitted. in this car
here's a piccie of the engine bay finnished, you've got to agree IT'S FULL!
http://venixjr.student.utwente.nl/thomas/gallery/albums/album10/DSCF0122.sized.jpg
zoom
So the best option for me is to design a good short sump, and build that.
regards Thomas
[Updated on: Wed, 20 April 2005 08:30]
IRA11Y
Club Member
Re: 4age short sump Wed, 20 April 2005 08:59 Go to previous messageGo to next message
the design you made seems feasable the only concern i see with it is that by extending the length of the sump further you may get a bit of surge around the pickup on accel ( the time when you least want it!), it might provide a better design by keeping rougly the same dimensions around the pickup and merely shortening both the pickup length and then cut the bottom of the pan in just the pickup area to suit the new length, I cant see any reason why doing it that way wouldnt work just as well. And seeing as the rest of the original sump is fairly tightly packaged theres no need to totally refabricate... ill do a quick drawing in the next few minutes and post it up.
RouwT
holland
Re: 4age short sump Wed, 20 April 2005 09:25 Go to previous messageGo to next message
Hey all,
I would expect I would suffer minor oil starvation at accel because of the trap door. the door can only let oil in the sump pan not out. the windage tray and original horizontal baffle would provide sufficient backflow into the oilpan intself under accel, and the horizontal baffle would hopefully also keep oil from sloshing around and out of the oil pan.
looking forward to you picture though, because the less welding's be done the stronger the end result will be.
grtz Thomas
ps here's a revised version of the oil pan
http://venixjr.student.utwente.nl/thomas/gallery/albums/album09/4age_short_sump_2nd.jpg
[Updated on: Wed, 20 April 2005 10:21]
IRA11Y
Club Member
Re: 4age short sump Wed, 20 April 2005 09:35 Go to previous messageGo to next message
my drawings not as pretty as yours Razz
but if you only need 2" then the stock pickup point has plenty of room to adapt, run slightly less oil but a thinner grade and it should be fine
http://ira11y.qnix.com.au/2inch.JPG
RouwT
holland
Re: 4age short sump Wed, 20 April 2005 10:29 Go to previous messageGo to next message
Hey,
I think that's not going to make my engine happy, I need to get the same volume of oil in the sump, so the sump needs to be lengthened\, but then you'll get starvation under accel, so A trap door needs to be made.
the latest version has got a hirozontal end-to-end baffle, to keep oil from crawling up the walls when cornering..
the overall height of my sump needs to be about 7-8 centimeters.
So I might end up extending the sump from front to rear to get enough volume in there, filling up comes close because there's no more room between Full and Low, because the level raising above the windage tray, which would be very bad.
would the latest version do any good?
grtz thomas
[Updated on: Wed, 20 April 2005 11:08]
towe_001
Somewhere on a dirt bowl ...
Re: 4age short sump Wed, 20 April 2005 15:16 Go to previous messageGo to next message
My idea would be to have the trap door about half the size or even about 1/4 in size. The idea being less oil to slosh around. Think of it as a pet door.
Or even keep that big one and place, say, four more around the pickup point. Four 1/4 size ones that is. Have the trap doors at the bottom of the sump and make them like baffles
http://img120.echo.cx/img120/7227/4agesumpredesign1uq.jpg
With the baffles they don't go all the way up only, say 3/4 of the way up. Its so that the oil can flow over the top but the oil thats already around the pickup won't move by much.
I've got a couple of pix around somewhere in a mag if i can ever find it
RouwT
holland
Re: 4age short sump Thu, 21 April 2005 05:22 Go to previous messageGo to next message
Also A very nice idea.
If making the little trap doors is easi enough I'll do that one. but 5 of them could get very crowded in there, The sump can't be higher than 7.5 cm overall else it will be in able to tough the tarmac again. ()glad my exhaust is on the side if the car)
I had allready thought of, making one small round/vertical baffle (serpentine belt) around the oil pickup tube, just like the ones ford uses in their fuel tanks as anti surge pot.
so here's version 3 (or 5)
http://venixjr.student.utwente.nl/thomas/gallery/albums/album09/4age_short_sump_2nd_001.jpg
grtz Thomas
81LOWLUX
BRAY PARK BRISBANE
March 2005
Re: 4age short sump Thu, 21 April 2005 05:54 Go to previous messageGo to next message
remember you need to allow for the sweep of the crank.
you wold be limited by that
just a thought
RouwT
holland
Re: 4age short sump Thu, 21 April 2005 06:10 Go to previous message
No I'll be not limited by cranck travel because the oil windage tray under the cranck will offcourse stay in. so as long as the assembly does nottouch the tray then I would be fine I think.
Man it would be good to have a short sump, cause every bump I need to take needs to be done diagonaly and SLLLLOOOOOWWWWWW now, I've got this car for almost 3 years now, and with the Kent engine I destroyed about 2 to 3 sumps a year.
Grtz Thomas
and NO I won't set the suspension a mm higer Laughing (UGH)
Previous Topic:1g-gte oil sensor
Next Topic:lsd for RA celica
Current Time: Thu Oct 22 16:51:16 UTC 2026
Total time taken to generate the page: 0.097985029220581 seconds
