Toymods » Tech & Conversions » using 16r rods to stroke a 18r
ra_28
using 16r rods to stroke a 18r Thu, 21 April 2005 03:12 Go to next message
does this sound about right using 16r rods with 22re pistons into an 18r block would make it 2.4L because 22re pistons are 94mm but sit abot 2mm below 18r deck hight so i heard by using 16r rods it pushes the piston back up to deck height.
81LOWLUX
BRAY PARK BRISBANE
March 2005
Re: using 16r rods to stroke a 18r Thu, 21 April 2005 03:19 Go to previous messageGo to next message
go to this and read the third paragraph
http://www.autospeed.com.au/cms/A_1042/article.htm l
hope this helps
Re: using 16r rods to stroke a 18r Thu, 21 April 2005 03:29 Go to previous messageGo to next message
ewww... 7:1 Freak
i would hate to think what his off boost response was like.
ra_28
Re: using 16r rods to stroke a 18r Thu, 21 April 2005 03:40 Go to previous messageGo to next message
LIKE A WORN OUT 18RC
81LOWLUX
BRAY PARK BRISBANE
March 2005
Re: using 16r rods to stroke a 18r Thu, 21 April 2005 03:45 Go to previous messageGo to next message
if you are not turbo charging then dont use the dish down pistons that he uses use flattops to give you the comp back
Mr DOHC
Re: using 16r rods to stroke a 18r Thu, 21 April 2005 07:34 Go to previous messageGo to next message
22R pistons are 92mm, and only go to 93mm {acl tho}
using the 22r crank and a 92mm bore is 2366.55cc.
by the way, i'm picking up a 92mm bore block on monday Very Happy , sparie
ra_28
Re: using 16r rods to stroke a 18r Thu, 21 April 2005 10:10 Go to previous messageGo to next message
i looked at using the 22r crank but foud the bearing width on either the mains or the conrods was different. thats what i noticed when looking in acl book.
Mr DOHC
Re: using 16r rods to stroke a 18r Thu, 21 April 2005 11:23 Go to previous messageGo to next message
i shall do some sluething at work for u tomorrow
barned01
Re: using 16r rods to stroke a 18r Thu, 21 April 2005 14:45 Go to previous messageGo to next message
i have the bearings sitting here, they are suitable for:
conrod bearings - 6r, 7r, 8r, 16r, 18r, 18rg, 20r, 21r, 22r
main bearings - 16r, 18r
so the main bearings must be the different ones, could get it machined down though, i was quoted 280 odd to fix the conrod journals for an 18rg crank but i don't know if it is cheaper for the main journals.
Re: using 16r rods to stroke a 18r Thu, 21 April 2005 21:46 Go to previous messageGo to next message
i wouldnt dare dream of stroking an 18R with a 22R crank, or any crank for that matter.
If you want an unrevable tractor motor, start with a 22R, dont bastardise an 18RG Sad
ra_28
Re: using 16r rods to stroke a 18r Fri, 22 April 2005 00:15 Go to previous messageGo to next message
oh no i would stick with the 18rg crank but i'm still iterested in trying a 2.4L 18rg turbo if it fails then i'll make use of my many spare 18rg motors, thats the fun of having a toy if it dies start again.
barned01
Re: using 16r rods to stroke a 18r Fri, 22 April 2005 00:21 Go to previous messageGo to next message
is bastardising an 18r-c accepted?
possibly with an 18rg head Smile
Mr DOHC
Re: using 16r rods to stroke a 18r Fri, 22 April 2005 06:59 Go to previous message
mmmmmmmmmm, 16R has a 73.5mm stroke, that means the piston speed at 9000rpm would equal an 18RG at 8000rpm
DOOOOOOOOOOOOOOOOOOO IT
Previous Topic:Dyno shop
Next Topic:Removing Supercharger
Current Time: Sat Oct 31 14:21:47 UTC 2026
Total time taken to generate the page: 0.0062770843505859 seconds
