Toymods » Tech & Conversions » Guage Help
Malicia
Guage Help Sun, 17 November 2002 03:46 Go to next message
I just replaced the Oil/Charge gauge in my RA40 coupe with the guage out of a liftback, it worked when it came out of the liftback but doesn't seem to work in my coupe i'e checked the wirering an it looks all good so i can't see the problem.
Has anyone done this swap b4?
Could it just be the guage has died while swapping it?
Re: Guage Help Sun, 17 November 2002 05:15 Go to previous messageGo to next message
You can't just swap the gauge, you also need the oil pressure sensor on the engine. The sensor you have now is just a switch which goes closed circuit below a given pressure, so obviously it won't work with a gauge.
Malicia
Re: Guage Help Sun, 17 November 2002 09:40 Go to previous messageGo to next message
Will it be the same for Charge, Fuel and Temp???
juzzo84
Hornsby, N.S.W
icon12.gif  Re: Guage Help Sun, 17 November 2002 12:19 Go to previous messageGo to next message
there is a little bit of wiring modification that you need to do, but for the oil you can use a sender from a 2tg-eu, thats what im running my oil pressure with in my 22, it works great.
JUZZO
Malicia
Re: Guage Help Mon, 18 November 2002 05:43 Go to previous messageGo to next message
Juzzo What wiring needs do to bo done??
Malicia
Re: Guage Help Tue, 19 November 2002 10:57 Go to previous messageGo to next message
Ok what does the oil pressure sensor look like?? is it iside the head? i've had a quick look but all i can see are the bolts on the head some with wires on them, is this what i'm looking for?
What wiring need to be done as i've checked both plugs and all wiring looks the same.
juzzo84
Hornsby, N.S.W
icon14.gif  Re: Guage Help Tue, 19 November 2002 11:13 Go to previous messageGo to next message
NO, the send screws into the drivers side of the block, just in front of the engine mount.
Yes the plugs are the same but the wiring configurations are different.
JUZZO
Malicia
Re: Guage Help Tue, 19 November 2002 11:18 Go to previous messageGo to next message
Ok i'll replace the sender tomorrow, any tips on the wiring?
juzzo84
Hornsby, N.S.W
icon14.gif  Re: Guage Help Tue, 19 November 2002 11:25 Go to previous messageGo to next message
i will organise the pics and a GT wiring diagram, whats your email and i will FLING them your way.
JUZZO
0413461518
Malicia
Re: Guage Help Tue, 19 November 2002 11:35 Go to previous messageGo to next message
If you could that would be great.
lynden16@hotmail.com
juzzo84
Hornsby, N.S.W
icon14.gif  Re: Guage Help Wed, 20 November 2002 01:17 Go to previous messageGo to next message
when i get home i will look for the digi picks and stuff.
JUZZO
juzzo84
Hornsby, N.S.W
icon4.gif  Re: Guage Help Wed, 20 November 2002 20:55 Go to previous messageGo to next message
Laughing YOU GOT MAIL, MR OLD SCHOOL FOOL..
JUZZO
Malicia
Re: Guage Help Fri, 22 November 2002 05:42 Go to previous messageGo to next message
Ok so now i have the Oil working, Temp seems to be running high but i'm not sure this is correct, But Volts and Fuel still don't work, Volts doesn't move and fuel seems to goes as far down as it can.... Past empty.
Is this wiring?
juzzo84
Hornsby, N.S.W
icon12.gif  Re: Guage Help Sat, 23 November 2002 02:29 Go to previous message
votls is an easy one to fix, all you have to do is run the voltage gauge input wire to a power source and you will have a working volts gauge.
JUZZO
Previous Topic:20 valve owners
Next Topic:2tg in kexx???
Current Time: Sat Nov 21 05:38:16 UTC 2026
Total time taken to generate the page: 0.004572868347168 seconds
