Toymods » Tech & Conversions » Boost problems in st185 gt4
WantaTurbo
Boost problems in st185 gt4 Fri, 22 April 2005 04:43 Go to next message
Hey guys i need your help cause im stumped as to why my car is behaving as it is atm Confused My car is running smooth for general driving around and doesn't seem to have any issues but when im on boost it wont go past 5psi it has a boost controller in it and when i try and turn it up it gets to 5psi then gets jerky and wont go any further. I know its not the boost controller cause i have used a mates one and it does the same thing Confused it used to work fine and this was with the boost controller set to 8 psi, any ideas what the hell is goin on? i have no idea....
spectral
Re: Boost problems in st185 gt4 Fri, 22 April 2005 05:33 Go to previous messageGo to next message
is your turbo VSV disconnected?
WantaTurbo
Re: Boost problems in st185 gt4 Fri, 22 April 2005 05:48 Go to previous messageGo to next message
i dunno Rolling Eyes is it the thing that controls the standard boost ?
silvi
February 2005
Re: Boost problems in st185 gt4 Fri, 22 April 2005 08:00 Go to previous messageGo to next message
Its behind the engine, faces the fire wall. Mine in anodised blue.
My GT4 did the same and it was one of these small bore hoses had come lose. The one on the drivers side if momory serves me right.
I think most people ditch these any way. Dont ask me how, my boost controler was on the car when I bought it and I havnt had to worry about it.
Pretty sure SPECTRAL will have an idea.
Good luck, MIKE. Very Happy
spectral
Re: Boost problems in st185 gt4 Fri, 22 April 2005 08:40 Go to previous messageGo to next message
you'll need to disable it prior to boosting the car.
Unplug the second line coming off the wastegate actuator (the one leading behind the engine. And cap it off tightly.
Stick another cap on that second outlet off the wastegate actuator and tighten it with a small hoseclamp.
Now you boost controller taps into the line that runs between your compressor housing and the wastegate actuator.
Done.
cycleofabuse
Re: Boost problems in st185 gt4 Fri, 22 April 2005 09:32 Go to previous messageGo to next message
I'm pretty sure that's how it's setup now (i have the same setup too and mine works fine except for the 1psi spike almost everytime). Any other ideas?
SilverGhost
Re: Boost problems in st185 gt4 Fri, 22 April 2005 09:40 Go to previous messageGo to next message
could be the wastegate itself is jammed partially open/closed which will allow it to boost to a certain point only.
Either that or you have a leak in your intake between your turbo and the throttle body
Or your boost guage is stuffed and wont read anything past 5 cause of some internal mechanical problem...
Hope this helps, but that is what I would be checking
[Updated on: Fri, 22 April 2005 09:40]
spectral
Re: Boost problems in st185 gt4 Fri, 22 April 2005 09:42 Go to previous messageGo to next message
if thats all setup properly. and the car stills stutters at 5psi or so, then its going to be an air leak under pressure most likely.
Check all hoses for splits. The prime candidate is the rubber joiner between intercooler and throttlebody. But basically check all intake pipework after the AFM.
Other possibilities included your intake manifold bolts being slightly loose. Thats happenned to me and the car wouldn't go past 3psi because the pressure pushed the manifold separate to the head and let the air escape.
[Updated on: Fri, 22 April 2005 09:43]
opasan
Syd
Re: Boost problems in st185 gt4 Sat, 23 April 2005 11:46 Go to previous messageGo to next message
I have this problem atm aswell...
it looks like its pretty common, but its a pain in the ass...
edit*
i know its not my thread an all, but is it bad to drive around like this... with it not boosting properly...
[Updated on: Sat, 23 April 2005 11:48]
ralfross
On Probation
April 2005
Re: Boost problems in st185 gt4 Sat, 23 April 2005 12:31 Go to previous messageGo to next message
its prob the inake hose before the turbo. They split and it will suck air after the AFM a bad thing. I have a straight intake if ya want it. It has room for the AFM and the a K&N air filter.
WantaTurbo
Re: Boost problems in st185 gt4 Mon, 25 April 2005 23:31 Go to previous messageGo to next message
Thanx heaps guys that gives me alot of things to check out. Sounds like its probably some sort of air leak or as spectral says it could be my intake manifold bolts being loose. Also as opasan says is it bad to drive the car when its not boosting properly? Also ralfross will the straight intake fit if the battery is in the stock position because its a very tight fit in the engine bay atm. Thanx for all the suggestions guys Very Happy
spectral
Re: Boost problems in st185 gt4 Tue, 26 April 2005 09:08 Go to previous messageGo to next message
its not going to do terminal damage to the engine, no. But it certainly isn't doing it a lot of good. Since you'd be running pig rich, things like the O2 sensor can suffer long term. Plus your fuel consumption won't be crash hot.
And no, the straight intake won't fit without:
(a) A pod filter
(b) Relocating the battery
(c) Extending the AFM loom and plug.
(d) Buying new breather/PCV hoses
WantaTurbo
Re: Boost problems in st185 gt4 Tue, 26 April 2005 23:23 Go to previous message
Thanx Spectral Very Happy i didn't think it would.... Hopefully i can find the source of the problem maybe this weekend if i get some time.
Previous Topic:1JZ Gearbox
Next Topic:T series conrods
Current Time: Sat Oct 24 01:02:39 UTC 2026
Total time taken to generate the page: 0.006101131439209 seconds
