Toymods » Tech & Conversions » HELP! STEERING ROOOOTED!
V8_MA61
icon9.gif  HELP! STEERING ROOOOTED! Fri, 22 April 2005 06:30 Go to next message
Ok so i go to turn the car to go out the driveway today....as soon as i turn the steering wheel, the thing started wobbline back and forth like a bastard! Both steering wheel and front wheels are doing it!
Anyone know WTF is wrong? And yes the lines are hooked up correctly as far as we can see. Also the belt is tight.
Skip
Re: HELP! STEERING ROOOOTED! Fri, 22 April 2005 06:33 Go to previous messageGo to next message
Are you using a ford power steering pump or the 5mge one?
V8_MA61
Re: HELP! STEERING ROOOOTED! Fri, 22 April 2005 06:36 Go to previous messageGo to next message
5me one...
Re: HELP! STEERING ROOOOTED! Fri, 22 April 2005 06:55 Go to previous messageGo to next message
Disconnect the belt, see what happens.
Skip
Re: HELP! STEERING ROOOOTED! Fri, 22 April 2005 07:07 Go to previous messageGo to next message
Sometimes if you have air in the hydraulic lines you will get feedback like this. Try bleeding the system, the pump should do this automatically so check the oil level again.
V8_MA61
Re: HELP! STEERING ROOOOTED! Fri, 22 April 2005 07:14 Go to previous messageGo to next message
we seem to think it might be restriction in the high pressure line when they made the new one for us...so we have drilled it out...wait n see tommorow if it does the same thing or not...
HyDrA
Adelaide, SA
Re: HELP! STEERING ROOOOTED! Fri, 22 April 2005 07:34 Go to previous messageGo to next message
Make sure the belt is tight enough... mine is doing this atm because I didn't tighten the belt enough, I can hear it slip.
Allan
Re: HELP! STEERING ROOOOTED! Fri, 22 April 2005 07:46 Go to previous messageGo to next message
belt is slipping or it has air in it check fluid level and watch the belt/pully while someone turns it lock to lock while idling
V8_MA61
Re: HELP! STEERING ROOOOTED! Sat, 23 April 2005 09:41 Go to previous messageGo to next message
ill try all this n tell ya tommorow....
sideshow
Re: HELP! STEERING ROOOOTED! Sun, 24 April 2005 02:38 Go to previous messageGo to next message
if the wheel goes left anf right violently back and forth it means u have the power steering hoses on wrong at the rack/steerign box
there are the 2 metal lines that goto the rack
swap them round
u have the pressure goin into the return
V8_MA61
Re: HELP! STEERING ROOOOTED! Sun, 24 April 2005 03:32 Go to previous messageGo to next message
i just worked out thats what is wrong. those two small lines...makes it easier seeing them in daylight!
sideshow
Re: HELP! STEERING ROOOOTED! Sun, 24 April 2005 07:44 Go to previous message
yer i had it happen on customers car when they did conversion and i started car
nearly ripped my hands off hehe
Previous Topic:1s efi onto 2s carby?
Next Topic:2tg hi rev ving when hot
Current Time: Sat Oct 17 06:47:29 UTC 2026
Total time taken to generate the page: 0.0044889450073242 seconds
