Toymods » Tech & Conversions » What Gearbox for a 12r
Darola
Taree, 4h nth of syd
What Gearbox for a 12r Fri, 22 April 2005 08:14 Go to next message
Hey there all, just need to know what 5speed gearbox will go behind a 12r Hilux 76model rn25
also what clutch to use and anything else that may need to be changed
Eddie
clubagreenie
1st street on the right
Re: What Gearbox for a 12r Fri, 22 April 2005 09:50 Go to previous messageGo to next message
Probably based on engine series a w5X box with the appropriate WtoR bellhousing.
If you find one get two (one for me)
TA22-3SGTE
MACKAY
Re: What Gearbox for a 12r Fri, 22 April 2005 11:08 Go to previous messageGo to next message
The box from a RT81 Corona will bolt in .
Trevor
stradlater
Arthurs Creek, Victoria
Re: What Gearbox for a 12r Sat, 23 April 2005 00:09 Go to previous messageGo to next message
I have a 4 speed behind one that I'll sell you for cheap if you want.
Darola
Re: What Gearbox for a 12r Sat, 23 April 2005 10:21 Go to previous messageGo to next message
hey there all, i have already got a 4speed corona box in it, im just looking at a stronger 5speed as we will be wacking a spare charger we have onto the motor
eddie
Re: What Gearbox for a 12r Sat, 23 April 2005 12:15 Go to previous messageGo to next message
You'd have to ask someone more knowledgable about this, but perhaps a W57 from an RA60 or a W55/W58 from an RA65 would be suitable.
Darola
Re: What Gearbox for a 12r Thu, 28 April 2005 01:04 Go to previous messageGo to next message
hey there, if i use a W50/57/58 box, do i have to change clutch or anything else????
thanks for your help
Eddie
Re: What Gearbox for a 12r Thu, 28 April 2005 01:20 Go to previous message
Is it a 3 or 5 bearing mains 12R?
We need to know this before we can proceed.
If it is a 3 main bearing engine, mate a W50 (or L50 if you wish to remain column shift) gearbox to your current bellhousing. Use the current clutch. Forget about all other gearboxes.
If it is a 5 main bearing engine, you could mate a W50/L50 using your current bellhousing or use an appropriate bellhousing to mate a W56/7/8/9. You will find the right bellhousing behind a 21R.
Personally, I'd just use the W50. Very cheap and will last forever and a day behing a 12R.
If this is a 3 mains bearing 12R, you might want to be a little careful about modifying this motor. The crank is obviously less well supported and, whilst I have never seen it, they are prone to breaking cranks.
[Updated on: Thu, 28 April 2005 01:23]
Previous Topic:Jaycar's performance car kits
Next Topic:Gearbox Oil for 3SGE gearbox
Current Time: Sat Nov 21 04:22:33 UTC 2026
Total time taken to generate the page: 0.054098844528198 seconds
