Toymods » Tech & Conversions » will advancing cam by 1 tooth work?
corbet01
April 2005
will advancing cam by 1 tooth work? Sun, 24 April 2005 03:06 Go to next message
Hi All,
I have read about advancing the inlet cams timing. I can not afford or make some vernier cam wheels at the moment. So my question is,
What kind of gain will i get by advancing the cam wheel by 1 tooth?
What degrees does this represent?
and My cams are std in a small port GTI 4ag.
Thanks,
Ty
wilbo666
Re: will advancing cam by 1 tooth work? Sun, 24 April 2005 04:55 Go to previous messageGo to next message
Work out how many degrees a shift of one tooth will advance your timing by...then look at how many degrees adjustable cam wheels are generally used to adjust by (+- 3deg seems to ring a bell to me?)....
I think you'll find a whole tooth is way too much.
Smile
Allan
Re: will advancing cam by 1 tooth work? Sun, 24 April 2005 04:58 Go to previous messageGo to next message
you will notice there are differnt dowl pin holes on the cam gears... use your imagination
Fr3aK
Wollongong
January 2005
Re: will advancing cam by 1 tooth work? Sun, 24 April 2005 04:59 Go to previous messageGo to next message
This sounds like a great idea!
Has anyone actually done this? What could go right/ wrong? What's the general idea for twin cam settings for top end gains? Advance inlet, retard exhaust?
"corbet01 wrote"
What degrees does this (one tooth) represent?
Count how many teeth you have, and divide 360 by that number. That's how many degrees each turn of a tooth will give you.
kewp
wollongong
Re: will advancing cam by 1 tooth work? Sun, 24 April 2005 05:25 Go to previous messageGo to next message
It will probably just make it sound different, and run bad, and not make any noticable power increase. I accidently put the cam 1 tooth out on my old datto, and it sounded like a tractor and wouldn't idle.
Fr3aK
Wollongong
January 2005
Re: will advancing cam by 1 tooth work? Sun, 24 April 2005 05:43 Go to previous messageGo to next message
Yeah one tooth on a Datto... single cam etc..... No wonder it ran rough. Smile
That's 9 degrees on my L-18! Shocked
Was the actual cam stock or aftermarket?
[Updated on: Sun, 24 April 2005 08:39]
ed_ma61
Lost in the K hole
Re: will advancing cam by 1 tooth work? Sun, 24 April 2005 08:29 Go to previous messageGo to next message
1 tooth = 12degrees... Rolling Eyes
Allan
Re: will advancing cam by 1 tooth work? Sun, 24 April 2005 08:31 Go to previous messageGo to next message
ed_ma61 wrote on Sun, 24 April 2005 18:29
fully sik you need a few more teeth then coz everyone knows its not thorpy stilezzzz unless its >45deg angle
Bill Sherwood
Brisbane / Gold Coast
Re: will advancing cam by 1 tooth work? Sun, 24 April 2005 10:18 Go to previous messageGo to next message
I'm pretty sure there's 36 teeth on a 4AGE cam pulley so one tooth there is 10° on the cam or 20° on the crank.
That's a lot!
corbet01
April 2005
Re: will advancing cam by 1 tooth work? Sun, 24 April 2005 10:51 Go to previous messageGo to next message
Thanks for the replys. I haven't actually removed the cam belt cover yet so i will check out the dowel pins. Still learning, always had rotaries and 2 strokes.
Thanks,
Ty
IRA11Y
Club Member
Re: will advancing cam by 1 tooth work? Mon, 25 April 2005 01:11 Go to previous messageGo to next message
hey Ed im not positive but afaik 1 tooth = 10deg , from memory there are 36 teeth on a 4ag cam gear so 360deg/36 = 10deg per tooth
will have to find a spare cam gear and check to be 100%
oops just read bills post and I agree Smile
[Updated on: Mon, 25 April 2005 01:12]
ed_ma61
Lost in the K hole
Re: will advancing cam by 1 tooth work? Mon, 25 April 2005 03:22 Go to previous messageGo to next message
10? 12?... whos counting... Laughing
"its a lot"
drift86levin
brisvegas
Re: will advancing cam by 1 tooth work? Wed, 27 April 2005 02:01 Go to previous messageGo to next message
Bill Sherwood wrote on Sun, 24 April 2005 20:18
That's a lot!
exactly right..i advanced my inlet cam 1 tooth..sounded a bit deeper..no bottom end..more top end..did my exhaust cam also..not realising i needed to move the dizzy to suit..i started it up, and it sounded lie a 9 sec 13B turbo drag car..
Brap!..Brap!..bur bur..Brap!
so i changed it back quick smart...any half arsed engeeneering workshop place should be able to make yours adjustable for next to nicks.. ($50 or so) also the inlet cam will give you the most noticeable increase..
84supra
myrrhee
Re: will advancing cam by 1 tooth work? Wed, 27 April 2005 03:57 Go to previous messageGo to next message
I think the old twin cam alfa's use to move a cam around one tooth and get heaps more top end, but suffer in both low RPM power and drivability.
My idea would be to drill more dowel holes in the cam wheel, each slightly more off set to the tooth above it than the next.
Do this accurately, drill 4 more holes and have timing increments of 2deg.
Good luck with your experimenting and let us know how it goes.
c2888
Re: will advancing cam by 1 tooth work? Wed, 27 April 2005 04:10 Go to previous messageGo to next message
I had one of my cams out by one tooth when i first put my engine back together, it ran fine. i didn't notice till some old vw mechanic fixing my dads kombi told me. wound it back a tooth, and found a whole stack of power, mostly down low. i always thought it was my carbs just being shitty for low end.
i don't think you'll find much power over the stock settings. toyota spend a few hours getting the engine to a very drivable state, ie, no big holes in the powerband. start messing with it and you may be going slower. it'll feel more powerful, only because you've made a dip and climbing out of the dip, the car feels fast.
dodgydan
Fr3aK
Wollongong
January 2005
Re: will advancing cam by 1 tooth work? Wed, 27 April 2005 08:29 Go to previous messageGo to next message
Hmmm,
I agree that Toyota spent alot of timing working out cam timing, but not soley for 'better drivability'. Rather, emissions (or the lack of) would be their key goal, with most of the performance focus aimed at acceptable all round drivability.
If adjusting the cam position was no good, there wouldn't be an aftermarket for adjustable cam gears, now would there?
I do agree that fiddling would probably result in less power (or even engine problems), and only a dyno tune would show the gains.
Starfire
Re: will advancing cam by 1 tooth work? Thu, 28 April 2005 08:22 Go to previous message
Advancing the inlet cam timing will give you gains in the top end but will drop the bottom end. Toyota uses this in the VVT, VVTi and VVTLi systems, but changes it while the engine is running so that you get the best of both worlds.
Adjusting the cam timing on an otherwise stock engine isnt going to give you a hell of a lot of a performance increase and it would be fair to say that the engineers at Toyota have spent a fair amount of time determining the optimum settings for the cams.
If the car is highly modded then you do stand to make quite a difference, but you really should splurge on some adjustable wheels (they look cooler too) and spend some time and money getting it properly tuned on a dyno.
Previous Topic:1G Part numbers
Next Topic:sr20det conversion
Current Time: Sat Nov 21 05:23:33 UTC 2026
Total time taken to generate the page: 0.0057549476623535 seconds
