Toymods » The Outhouse » USB - IDE Adapter, Need Help.
Malicia
USB - IDE Adapter, Need Help. Sun, 24 April 2005 10:06 Go to next message
Ok I got a USB - IDE Adapter so I can try fix my old HDD and so I can put PS2 games onto another HDD without opening this comp everytime I want to do so,
My problem is that I can't find where to view the HDD that has been connected through the USB, there is power to the HDD and I get the connection sound when I plug it in, and it registers USB MASS STORAGE DEVICE when plugged in, but I can't find it.
Any ideas?
Toobs
Re: USB - IDE Adapter, Need Help. Sun, 24 April 2005 13:43 Go to previous messageGo to next message
It should appear in "my computer"
If it doesn't then you might need to setup a partition on it.
In Windows XP go to Control panel -> Administrative Tools -> Computer Management
Then under storage click on Disk management.
Its all fairly easy to work out.
Malicia
Re: USB - IDE Adapter, Need Help. Mon, 25 April 2005 05:48 Go to previous messageGo to next message
Nope nothing in my computer,
And can't see anything on Disk management.
And don't see how to add anything, I might have to do it the long way.
faulksy
Re: USB - IDE Adapter, Need Help. Mon, 25 April 2005 06:04 Go to previous messageGo to next message
does your motherboard support usb2?
im not sure what happens if plug in a usb2 device into a normal usb port but imagine it doesnt detect like this
Re: USB - IDE Adapter, Need Help. Mon, 25 April 2005 06:06 Go to previous messageGo to next message
It usually backward supports stuff, but Windows has a bitch that it's not running optimally.
faulksy
Re: USB - IDE Adapter, Need Help. Mon, 25 April 2005 07:43 Go to previous messageGo to next message
justcallmefrank wrote on Mon, 25 April 2005 15:36
thats what i would have though but never used usb2 stuff on regular usb
what about jumper settings when connecting an external enclosure do these need to be in master, slave etc. or shouldnt it matter
just throwing around a few ideas
also is there anything device manager with 'X' '!' '?' etc. ?
clubagreenie
1st street on the right
Re: USB - IDE Adapter, Need Help. Mon, 25 April 2005 07:48 Go to previous messageGo to next message
I'm running an external HDD in a case. Set to master and runs fine on both usb (case is 2, system is 1) and firewire. Mind you it's a mac so I just checked and it runs on any setting. Very Happy
Malicia
Re: USB - IDE Adapter, Need Help. Mon, 25 April 2005 12:51 Go to previous messageGo to next message
yeah its USB2, and the HDD i'm trying to connect is set up as slave,
Although I'm abuot to try another HDD and see if it works, if it does I think the one I'm trying now might be rooted.
inertia
Re: USB - IDE Adapter, Need Help. Tue, 26 April 2005 15:38 Go to previous messageGo to next message
Make sure the drive isn't set to cable select. Set it to single drive or master... actually it depends on the IDE-USB convertor u have... we had some at work that required setting up as above
Malicia
Re: USB - IDE Adapter, Need Help. Wed, 27 April 2005 07:11 Go to previous message
I tried the other HDD and it worked like it was supposed to, I think the HDD i was trying is buggered
Previous Topic:jamster frog must die
Next Topic:watch out for those killer monorails
Current Time: Wed Oct 28 03:52:52 UTC 2026
Total time taken to generate the page: 0.0056641101837158 seconds
