Toymods » Tech & Conversions » The good oil ??
Levin4Kevin
Sydeny
The good oil ?? Sun, 24 April 2005 10:55 Go to next message
Well my car is nearly back on the with 1JZ and 5 speed. I was filling the gearbox oil when a friend droped in and he stated that some Japanese gearbox's use engine oil rather than gearbox oil. Can you please confirm which oil type I should put in my 5 speed W58.
Thanks, Kevin
P.S. I think I know the answer, just nead to confirm it.
EldarO
Perth, WA
Re: The good oil ?? Sun, 24 April 2005 11:49 Go to previous messageGo to next message
i know diff and gearbox oil is the same... not always, but usually
as for engine oil in a gearbox, i cant imagine thats very good for it...
its a gearbox, use gearbox oil.
Eldar.O.
Toobs
Re: The good oil ?? Sun, 24 April 2005 13:14 Go to previous messageGo to next message
The specs call for an API GL4 (or better) oil at 75W/80.
If you want to go synthetic use something like Gulf Western Ultra Clear Low Vis API GL5 75W/90.
http://www.gulfwestern.com.au/category.asp?Categor yID=11
HyDrA
Adelaide, SA
Re: The good oil ?? Mon, 25 April 2005 01:27 Go to previous messageGo to next message
Honda's often use motor oil in their gearboxes, my mates ED6 civic does.
Seems to work ok... but he seems to change it more often than most people do!
ChuckLandwehr
Re: The good oil ?? Mon, 25 April 2005 05:52 Go to previous message
All gearbox and diff oils, have an Extreme Pressure additive, this ensures that the oil is not wiped/squeezed from the gears.
75/80 is the correct weight oil for the W series boxes.
The use of engine oils in Honda's, is what necessitates the frequent changes.
cheers Chuck.
Previous Topic:ST Head, 16v block, twin carbies
Next Topic:4age cooling system Help
Current Time: Mon Oct 26 13:47:33 UTC 2026
Total time taken to generate the page: 0.014959096908569 seconds
