Classifieds » Engines, Accessories and other Mechanicals » 18rg custom water pump pulley for AIRCON
brett_celicacoupe
townsville NQLD
18rg custom water pump pulley for AIRCON Mon, 25 April 2005 10:24 Go to next message
hi,
im sellin a custom made water pump pulley to suit a 18rg.
i made this pulley when i was going to put the air con compressor on my 18rg.
it is basically one of the big pulleys from a water pump pulley put onto another water pump pulley.
so; there are two big pulleys which are the same width apart as the 2 big pulleys on the crank pulley
this allows for the aircon compressor to be put up on the exhaust side; above the alternator
pics will come soon
asking $50 + freight at buyers expense
brett
TA-022
Glenmore Park, NSW
Re: 18rg custom water pump pulley for AIRCON Tue, 26 April 2005 10:51 Go to previous messageGo to next message
what aircon were you planning to use with this...?
Nathan
people100
Rocklea qld
Re: 18rg custom water pump pulley for AIRCON Tue, 26 April 2005 12:31 Go to previous messageGo to next message
i dont understand why u need a custom pulley. the compresser if used with the correct bracket should sit above the exhaust and run from the extra pully on the fan.
brett_celicacoupe
townsville NQLD
Re: 18rg custom water pump pulley for AIRCON Thu, 28 April 2005 10:09 Go to previous messageGo to next message
i made it to suite a 18rc air con compressor that sits above the exhaust
people100 wrote on Tue, 26 April 2005 22:31
the two pulleys that are on the water pump (behind the fan) are different sizes. because the air con is to run of the 2nd cranshaft pulley (same size as 1st pulley), if you run them over 2 different sized pulley they will fight and wear out the belt.
it would be like putting your can in 1st and 2nd at the same time Razz
and the pulley i made has got 2 pulleys of the same size spaced the same width as the two inner pulleys on your crank. i have 3 grooves on my crankshaft pulley.
BUMP!!
brett_celicacoupe
townsville NQLD
Re: 18rg custom water pump pulley for AIRCON Sun, 01 May 2005 10:02 Go to previous message
bump Smile
Previous Topic:The famous 1370mm hilux G series diff & housing
Next Topic:HKS BOV
Current Time: Sun Nov 1 23:26:47 UTC 2026
Total time taken to generate the page: 0.0051710605621338 seconds
