Toymods » Tech & Conversions » sv21 st162 gearbox
chrisss
melb
sv21 st162 gearbox Mon, 25 April 2005 15:27 Go to next message
is it the same model gearbox in the sv21 camry 3sfe as the st162 3sfe and 3sge...
is the sv21 3sfe and st162 3sge gearbox the same thing???
anyone, anyone????
-==L=a=N=c=E==-
Brisbane, Queensland
Re: sv21 st162 gearbox Mon, 25 April 2005 21:19 Go to previous messageGo to next message
There not the same, but they are interchagenable. If that helps.
acreese
Re: sv21 st162 gearbox Tue, 26 April 2005 06:25 Go to previous messageGo to next message
Tomayto, Tomarto,
Both are S-53 transmissions Razz
starter motors in different locations however.
-Adam
smashed_wombat
Re: sv21 st162 gearbox Tue, 26 April 2005 08:16 Go to previous messageGo to next message
Yeah, what he said. Razz The S53 found on the ST162 3SGE has the starter motor mounted on the block side of the flywheel, whereas the Camry and Celica 3SFE ones has the starter on the other side. Because of this, the Celica 3SGE gearbox isn't compatible with any other 3S motor unless you perform dicey modifications to the flywheel. I believe final drive ratios are also different.
berad
Re: sv21 st162 gearbox Tue, 26 April 2005 08:20 Go to previous messageGo to next message
yer the sv21 camry box 5th gear is a bit taller... pushs u out to 270k's an hour not that i know lol
cycleofabuse
Re: sv21 st162 gearbox Tue, 26 April 2005 08:42 Go to previous messageGo to next message
berad wrote on Tue, 26 April 2005 18:20
is that so.... Rolling Eyes might have to give it a go... Very Happy
chrisss
melb
Re: sv21 st162 gearbox Tue, 26 April 2005 13:30 Go to previous messageGo to next message
right so i could attach camry gearbox in st162 as long as I changed flywheel and starter as well....what about the driveshafts...
are they interchangable between the S51 and S53....
also do the st162 have all the same hubs or r the hubs different on the 3sfe...
ps anyone know the ratios of the gearboxes?
from digging around heres what ive found....
camry 3sfe : celica 3sfe : celica 3sge
1 - 3.285 : ?????? : 3.285
2 - 2.041 : ?????? : 2.041
3 - 1.322 : ?????? : 1.322
4 - 1.028 : ?????? : 1.028
5 - 0.820 : ?????? : 0.820
fd - 3.944 : ?????? : 4.176
would the st162 3sfe gearbox be the same as the camry?
[Updated on: Tue, 26 April 2005 14:12]
Johnny Blade
Sweden
Re: sv21 st162 gearbox Tue, 26 April 2005 19:54 Go to previous message
chriss - You don't have to change flywheel.The driveshafts will fit.
Previous Topic:Problem Drivers front caliper - Pics Inc (56k Beware)
Next Topic:n00bie question
Current Time: Sun Oct 18 05:23:02 UTC 2026
Total time taken to generate the page: 0.0084249973297119 seconds
