Toymods » Tech & Conversions » Problem Drivers front caliper - Pics Inc (56k Beware)
ZZT231
melbourne.vic.au
icon4.gif  Problem Drivers front caliper - Pics Inc (56k Beware) Tue, 26 April 2005 04:35 Go to next message
Hey All,
I just changed my master cylinder and rebuilt left and right caliper but I get this on the right caliper... Does anyone have an Idea what the problem could be?
I have also replaced the pads (the old ones did the same as the new ones), bled the system (well Allan did it for me)
http://img.photobucket.com/albums/v466/CelicaSupra/244ddfa4.jpg
http://img.photobucket.com/albums/v466/CelicaSupra/845e71dc.jpg
Cheers.
[Updated on: Tue, 26 April 2005 04:36]
gr8r-x
Vic, AU
Re: Problem Drivers front caliper - Pics Inc (56k Beware) Tue, 26 April 2005 08:02 Go to previous messageGo to next message
ZZT231 wrote on Tue, 26 April 2005 14:35
Hey All,
Can't speak for anyone else, but I can't really tell what the problem is from those photos. Please explain what exactly the problem is, maybe then we can help. Smile
Is something sticking? Wearing unevenly? What?
Yian
Lwr Templestowe, Melbourne
Re: Problem Drivers front caliper - Pics Inc (56k Beware) Tue, 26 April 2005 08:09 Go to previous messageGo to next message
The pad contact is not even. You can see the inside bit of the rotor is rusted over -- meaning the pads arent contacting it. I think hehe.
Allan
Re: Problem Drivers front caliper - Pics Inc (56k Beware) Tue, 26 April 2005 08:29 Go to previous messageGo to next message
hmmmmmm warped rotor maybe, ill have a look at it later in the week if you want tim
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: Problem Drivers front caliper - Pics Inc (56k Beware) Tue, 26 April 2005 08:38 Go to previous messageGo to next message
Those pads look like the ones I put on my ma61 a couple o' weeks ago Smile
Does the other side of the disc share a similar or inverted wear pattern??
I'd be guessing its new rotor time.
ZZT231
melbourne.vic.au
Re: Problem Drivers front caliper - Pics Inc (56k Beware) Tue, 26 April 2005 08:57 Go to previous messageGo to next message
Thanks all for the reply,
Allan, I'll yap to you on Messenger Smile
Viper, it's just that one side (outward facing) of the rotor... before the brake caliper rebuild/swap all was good and currently the otherside of the rotor the pad is making 100% contact Sad
*Me think I got a stuffed caliper but how? Nod
It's to late now to fart around with the brakes, I'll play with it more tomorrow...
Cheers.
4agte
Toronto, Downtown
Re: Problem Drivers front caliper - Pics Inc (56k Beware) Tue, 26 April 2005 09:10 Go to previous messageGo to next message
agreed warped rotor or stuffed caliper im leaning towards warped caliper
Scorpion
Menai area of Sydney
Re: Problem Drivers front caliper - Pics Inc (56k Beware) Tue, 26 April 2005 13:51 Go to previous messageGo to next message
If the inside is contacting properly try swapping the inner and outer pads - might have a faulty one. Also check that the pad is sitting properly in the caliper on faulty side. Then try swapping the rotors over and see if you still get the problem. That'll tell you whether it is a pad or a rotor problem.
Ta22lover
February 2005
Re: Problem Drivers front caliper - Pics Inc (56k Beware) Tue, 26 April 2005 22:04 Go to previous message
Look at the back of the caliper, it has two rubber thingies sticking out there.
if u take off the rubber thingies, u will see two bolts that the caliper is sliding on, if the pads dont bite on both sides of the rotors, it simply means the bolts are rusty or have no lube on them. lube them up, force the caliper to slide sideways, it should slide fairly easy, but its takes a lot of force to get them to slide when their either rusty or out of lube.
Previous Topic:7MGTE radiator cap
Next Topic:sv21 st162 gearbox
Current Time: Sat Oct 17 11:09:33 UTC 2026
Total time taken to generate the page: 0.014247179031372 seconds
