Toymods » General Car Talk » what goes into a high hp lightly gone over 4agte
kingmick
Banned by his request
moved to tamworth
what goes into a high hp lightly gone over 4agte Mon, 18 November 2002 11:05 Go to next message
just thought id tell you abit about what goes into making a very high horsepower 4gte{from a gze motor}.
started by stripping the motor again{only rebuilt it 40k ago} just to make sure everything is running how it should be. clean and debured block of all dags{especially the bottom of the oil returns}with die grinder plus other race prep things. then clean every part to a nice shine. stip down the oil pump and modify it a bit, but this is only for a awhile as i have a three stage dry sump pump on its way from the states.had every thing balanced with the exedy ceramic button clutch. the block is o-ringed so had a recieve machined into head, while i wait for the billet cams and buckets then drilled and tapped a drain in back of head in a similar place to the small port as i tossed the small port head. dummy fitted crank to check clearances of new bearings. fitted ARP rod bolts and fitted crank make sure of end float{there a trick to it}. fitted arp main cap bolts and torqued. then checked ring gap clearances and fitted piston and torqued rod bolts. then welded two fittings to sump, one a dash 8 for turbo oil retun and one for oil temp. then welded dash 12{from memory} to rear of water pump housing so i can run braided hose instead of factory solid water pipe and to suit the billet inline thermostat housing that is o-ringed and held closed with ten cap screws. this has a high flow race thermostat in it to keep things cool. made one of our trick catch cans for the two rocker cover breathers. put ARP stub bolts in ready for the head and aneiled copper head gasket. fitted dash fitting were oil sender used to be to feed turbo and got rid of the water bleed beside it and replaced it with cap plug. made a set of slide ajustable vernier pulleys. worked out were to put the header tank for the cooling system. made a short shifter by heating and raising the pivot point then made a space block with t7{haha bit over board but it was the closes piece at hand}. machined two brake mounting brackets out of t7 for the outlaw four spot race caliper for the rolla shopping trolley.
and this is just some of the work that goes into it. still going it takes awhile even with a race workshop.
mick
p.s just started making stainless turbo manifold, im making a jig so will make them when ordered but they wont be cheap.
p.p.s my budget is still under $500! haha just kidding
[Updated on: Mon, 18 November 2002 11:09]
Re: what goes into a high hp lightly gone over 4agte Mon, 18 November 2002 11:36 Go to previous messageGo to next message
So do you do brake setups?
FLY PSI
icon4.gif  Re: what goes into a high hp lightly gone over 4agte Mon, 18 November 2002 11:39 Go to previous messageGo to next message
roughly how much will the exahust manifolds cost? and what car is this going into?
Sounds like a killer setup Very Happy Very Happy what sort of power are you expecting?
kingmick
moved to tamworth
Re: what goes into a high hp lightly gone over 4agte Mon, 18 November 2002 11:44 Go to previous messageGo to next message
no dont do the brake setups on street cars as the insurance hasles are a nightmare.
and the turbo manifold is going in a ae93 and would be about $1300 as a guess as i can tell you till its finish and work out labour and materials.
kingmick
moved to tamworth
Re: what goes into a high hp lightly gone over 4agte Mon, 18 November 2002 11:54 Go to previous messageGo to next message
just thought id add a parts list for the engine so far.
autronic sm2{3bar map sensor and data logging}
ARP bolts and studs
rx7 oil cooler
power steer cooler
800cc injectors
custom inlet manifold
billet cams
cam buckets
race valve springs
stainless valves
dry sump pump{ ill see how the factory one holds up before bolting on}
vernier cam gears
billet thermo housing
high flow themostat
braided hosing and fittings
aurtonics ignition setup
4x v8 holdern coils
10mm race leads
machine work on head and block
copper head gasket
8x autronic pick up sensors
cnc timing wheel
thats all i can remember sitting here at home!
mick
[Updated on: Mon, 18 November 2002 11:57]
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: what goes into a high hp lightly gone over 4agte Mon, 18 November 2002 13:37 Go to previous messageGo to next message
Hehe, I bet you wouldn't put up a corresponding pricelist!
One thing though, I don't get this bit.....
The stick's gotta be chopped & lengthened don't it?
FLY PSI
Re: what goes into a high hp lightly gone over 4agte Mon, 18 November 2002 13:42 Go to previous messageGo to next message
What about adjustable cam gears? wont they help you dial in the cams for peak performance? or did you just forget to list them?
Youngy
Eskilstuna, Sweden
Re: what goes into a high hp lightly gone over 4agte Mon, 18 November 2002 23:52 Go to previous messageGo to next message
kingmick wrote on Mon, 18 November 2002 22:05
No he did not forget to mention them.
FLY PSI
Re: what goes into a high hp lightly gone over 4agte Tue, 19 November 2002 10:07 Go to previous messageGo to next message
oops Embarassed i didnt read it to well Rolling Eyes , i had a couple of ale's last night....
kingmick
moved to tamworth
Re: what goes into a high hp lightly gone over 4agte Tue, 19 November 2002 11:18 Go to previous messageGo to next message
wish i got to have a few beers! seems to be no time for it lately{and before someone says make time, i wish i could!!}.
best way to describe moving the pivot point up is to grab a pen and start at the middle of it with a finger and thumb holding it and move it back and forth. as you go up you have to move the pen less to make the bottom travel the same distance.
mick
BigWorm
Turramurra, Sydney.
Re: what goes into a high hp lightly gone over 4agte Wed, 20 November 2002 00:31 Go to previous messageGo to next message
I understand how a quickshifter works, & what a pivot point is (I made my own quickshifter for the same 'box) I just don't understand how you can "heat & raise" the pivot point.
I had to cut mine, then weld in an extra peice of rod to make it longer. If there's an easier way to do it though, I've love to hear it.
kingmick
moved to tamworth
Re: what goes into a high hp lightly gone over 4agte Wed, 20 November 2002 10:34 Go to previous messageGo to next message
the ae92 is front drive so has a remote shifter. the shifter pivots on a metal ball that is heated and or pressed on over splines. if you heat it you can put it in a vice and wack it and move the ball up. sorry didnt think to say on an ae92 ect.
mick
BigWorm
Turramurra, Sydney.
Re: what goes into a high hp lightly gone over 4agte Wed, 20 November 2002 14:15 Go to previous messageGo to next message
Ah, thanks mate. I wondered if it was FWD but then assumed it was RWD when I saw you were sourcing busted T50s.
I don't suppose you wanna take a few pics of the shifter & give a bit of a how to description for the article section do you? I was saying to Rolla Boy it couldn't be too hard to make a quickshifter for a FWD, but I wasn't exactly sure how a FWD shifter assembly worked.
kingmick
moved to tamworth
Re: what goes into a high hp lightly gone over 4agte Thu, 21 November 2002 09:59 Go to previous message
the t50's are for another race car. it has a atmo 7age putting out 240hp, very big dollar engine. yes i can take a few picks and do a how to but it will have to wait until the new year as i have to go to sandown with our three sport sedans for the supercar meeting, so ill be leaving on wensday and then ill be finishing my shopping cart.
mick
Previous Topic:bug's and paint.......
Next Topic:Formula Atlantic audio or video!
Current Time: Fri Nov 20 18:53:38 UTC 2026
Total time taken to generate the page: 0.0061261653900146 seconds
