Toymods » Tech & Conversions » custom injection
Meat_rack
East Maitland NSW
custom injection Wed, 27 April 2005 11:25 Go to next message
If i was to Put a custom set of throttle bodies on my engine 3k..
Could i use say 4age efi parts to make up the rest of the system eg. tps, rails, pump, parts or the loom etc..
I know someone will say use 4age 20v throttle bodies but i don't want to because i already have custom ones..
stay classy
Andrew..
Re: custom injection Wed, 27 April 2005 13:00 Go to previous messageGo to next message
you will need a fuel rail with spacing to fit the throttle bodies.. where are the injectors mounting?
TPS? get the one the ECU wants..
make new wiring, it's easy (depending on ECU). pump, holley/walbro/any stock EFI pump (only need 50-60L/hr). injectors-around 200cc is plenty..
Meat_rack
East Maitland NSW
Re: custom injection Wed, 27 April 2005 13:04 Go to previous messageGo to next message
It is for methanol
The injectors will be top feed of the inlet manifold.
stay classy
Andrew..
[Updated on: Wed, 27 April 2005 13:05]
Re: custom injection Wed, 27 April 2005 13:05 Go to previous message
if it's for methanol, you will need pump, fuel lines and injectors that have been prepped for it.
TPS? whatever ECU you use will require a certain type of TPS, ie switch of variable..
methanol on 3K with quads? hardly seems worth it?
Previous Topic:2ac question !
Next Topic:Respraying 18R-C rocker cover and block
Current Time: Thu Oct 15 17:45:26 UTC 2026
Total time taken to generate the page: 0.072957038879395 seconds
