Toymods » Tech & Conversions » Supercharged 4A-C!!!!
.:AE86 Nut:.
Sydney, Australia
Supercharged 4A-C!!!! Wed, 27 April 2005 11:40 Go to next message
Hey all,
thinking of throwing a 4a-GZE supercharger on my 4A-C powered AE82 sedan. I know this will seem stupid as its a 4A-C, but im doing this just to learn a thing or two, as i will soon upgrade to a 4a-GE anyways. Just some questions for the guru's out there...
Q1.) Becoz my engine is a high compression motor, will the stock boost (8PSI im lead to believe) be too much for my engine?
Q2.) Once the Charger is bolted to the block and a pulley is run, if i run the piping from the charger to the intercooler, and then to the top of the Carby, will i need something such as a BOV to release the pressure once i back off, or will the pressure not be a problem as its belt driven anyway?
Q3.) Once the charger is setup, would it be possible to just run a uni filter to the charger using some piping with the filter fitted in the front bar, or will the charger require other bits?
Q4.) With the piping coming from the cooler to the BOV, and then to the carby, if this system is all sealed, will i make much gains in regards to power?
cri_ag
northern beaches
Re: Supercharged 4A-C!!!! Wed, 27 April 2005 12:17 Go to previous messageGo to next message
dont know how much the stock carby is going to like being used in a
blow-through application(supercharger-carby-engine), as opposed to a suck-through setup(carby-supercharger-engine).
StockAE86
Outer Sth East burbs, VIC
Re: Supercharged 4A-C!!!! Wed, 27 April 2005 12:59 Go to previous messageGo to next message
Im just about to start a project doing the same thing, have acquired a sc-14, im thinkin of usin an su carby before the supercharger though.
Will be interesting to hear some comments
EDIT: I spell gooderer
[Updated on: Wed, 27 April 2005 13:01]
mr2gze
Re: Supercharged 4A-C!!!! Wed, 27 April 2005 14:45 Go to previous messageGo to next message
There is a post about someone doing this to there 4ac in a ae70 or similar in the General Car Talk section (i think), with a link to carsales.com with a few pictures. That might give you a few ideas.
StockAE86
Re: Supercharged 4A-C!!!! Wed, 27 April 2005 23:34 Go to previous messageGo to next message
Here is the link to that thread
http://forums.toymods.org.au/index.php?t=msg&t h=66076&start=0&rid=6493&S=9cc4ed31a62 a2176b0e4a374b140d6a9
drift86levin
brisvegas
Re: Supercharged 4A-C!!!! Thu, 28 April 2005 00:50 Go to previous messageGo to next message
i really would suggest a suck through setup..running 8psi providing you get the pully dimensions right..shouldn't be a problem if the motor is in alright nick..i think you will be suprised at the torque increase! becuase your compressing air and fuel in the supercharger, it will actually work as in intercooler effect, the fuel will cool the air a bit, but you won;t be able to run a IC if you have a suck through..if your doing a suck through..i might be inclined to suggest a carby off a 1.8 or a 2.0 litre (eg 18R)..just so it gives it a bit more fuel, chuck a new set of points in the dizzy, cos it will proberbly want to rev past 6 with a bit of boost in her lungs! good luck with it..i might try it for a bit of fun myself..i think it would be best if you swaped all your pullys over to the GE/ZE ones.. (ribbed) the GE crank pully will only give you 5-6psi max..the ze one (bigger) will give any where up to 9psi..i would keep the S/C on a switch of something similar..not permanently on..it will burn it out real good
tankrolla
cranbourne
April 2005
Re: Supercharged 4A-C!!!! Sun, 01 May 2005 04:51 Go to previous messageGo to next message
if i was u i would not bother the cost of setting it all up u could do what i did ,took my old 4a-c out of my ae82 and bolted the 4agze strait in the half cut was $2500 and it was worth it,it dose keep up with a vn 5lt
tankrolla
cranbourne
April 2005
Re: Supercharged 4A-C!!!! Sun, 01 May 2005 04:53 Go to previous messageGo to next message
StockAE86
Re: Supercharged 4A-C!!!! Sun, 01 May 2005 12:26 Go to previous messageGo to next message
If i have to spend more than $100 i aint doin it. Laughing
I have a su carb and a s/c lined up for nothing so far, all i need now is pipeing, maybe an electric fuel pump and prolly a few 4age pulleys
inertia
Re: Supercharged 4A-C!!!! Tue, 03 May 2005 12:38 Go to previous messageGo to next message
$2500 plus the rest Evil or Very Mad
Lachie
Re: Supercharged 4A-C!!!! Wed, 04 May 2005 02:43 Go to previous messageGo to next message
You mentioned your going to go for a 4A-GE eventually anyone. Personally, I wouln't waste my time with supercharging the 4A-C, I just go for a 4A-GZE, especially if your going to all the hassle of doing an engine conversion.
brodiepearce
Ipswich
February 2005
Re: Supercharged 4A-C!!!! Wed, 04 May 2005 02:54 Go to previous messageGo to next message
yeah, id suggest what Lachie just said, theres no point charging the 4ac if your going to put a 4AGE in anyway, but you did say you wanted to learn a thing or to, i guess if it stuffs up its better to blow a 4AC than a 4AG, haha, rhyme
[Updated on: Wed, 04 May 2005 02:56]
.:AE86 Nut:.
Sydney, Australia
icon14.gif  Re: Supercharged 4A-C!!!! Fri, 06 May 2005 23:51 Go to previous messageGo to next message
Hey again,
Thanks for all your replies. I am currently gathering the much needed information to pull this conversion off. I've decided to build up a new 4A-C (remember, this is all just for learning!!) and plonk it all in when it all seems good! Smile with a Suck thru setup. I have sourced a Carby off an old RA60 Celica 4 $50 (sounds okay to me) which i am going to get rebuilt. I am also trying to find a donor engine in which i can start this project. Anyone got a 4A-C from an AE82 they wanna sell me? Rolling Eyes will be getting the head ported and polished aswell... will i need to run a BOV or i/c with this setup as its suck thru? if i do will it spit fuel and air in the engine bay? any other advice would be greatly appreciated!!
jesseT18
Castle Hill, Sydney
Re: Supercharged 4A-C!!!! Sat, 07 May 2005 03:08 Go to previous messageGo to next message
there is a 4ac in my driveway you are welcome to have, its out of a sprinter
sonwill
Lara, Vic
February 2005
Re: Supercharged 4A-C!!!! Sun, 08 May 2005 02:55 Go to previous messageGo to next message
PM sent
causinmayhem
Re: Supercharged 4A-C!!!! Sun, 08 May 2005 08:02 Go to previous messageGo to next message
with a suck-through system the question is not do you "need" an intercooler - but would you really want one. think about fuel going through it (the fuel being fed by the carby into the supercharger)... if this now atomised (misty) fuel goes thru said intercooler then the mixture will at least partially condense. you now have fuel in your intercooler. if the car now backfires your intercooler will turn into a small explosive device Surprised - rather amusing in a controlled experiment but not the best thing to have happen!!!
now - blow-off valve. used primarily as a noise-maker and said to prevent air pumps (turbo's/supercharge...maybe) from coming off boost during gear changes and letting off the throttle by venting the boost that is restricted (usually by the throttle butterfly in an efi system). since the way you are setting up your system is not gonna be like this then a bov would be seemingly a waste of money (not to mention that similarly to your intercooler it would vent atomised petrol into H O T engine bay possibly causing spot fires to break out... Laughing
probably not what you really want hey? Smile
my advice would be to go through with the suck-through set up using the carb -> supercharger -> pipework/manifold as my mechanic is doing on a ke30 'rolla!!! Laughing
if you do that and run low boost then as long as you have enough fuel getting in (ie make sure the person rebuilding your carby knows what its intended application is so that they can at least approximate a decent jet size as you won't want it running lean.
good luck chief Very Happy
converted1
Eastern Suburbs, Sydney
March 2005
Re: Supercharged 4A-C!!!! Tue, 10 May 2005 09:31 Go to previous messageGo to next message
I know u said this was a budget build. And you were just going to have your carby re-built and re-jetted.
But if you could find one for a cheap price, can I suggest you use a Holley 450 double pumper. It would do the job.
.:AE86 Nut:.
Sydney, Australia
Re: Supercharged 4A-C!!!! Wed, 11 May 2005 11:04 Go to previous messageGo to next message
Thanks for all your help guys. Well, the disk brake conversion is being done this weekend, sourced the new setup of a twin cam seca for $200 which sounds reasonable Smile once that is fitted with the dba slotted rotors and new pads, i will be straight into building the new engine. ive gotten quotes for a port and polish job, with a reground cam aswell for $550 from a place at Windsor. Does anyone know of any carburettor or EFI specialist which will help with the tuning and or jetting of the new carby? i have contacted 2 places, both of which want nothing to do with the project as the oldies think too much trouble is involved. JesseT18 thanks for the offer. You hav a PM, CausingMayhem, thanks for your help aswell! What do you suggest i do with the outlet of the SC where i can mount a BOV? should i block all of the outlets except inlet/outlet, and only run the 12V? Im going to take some photo's of the unit, and ask for information on some bits and pieces. seeing as though i have the stock IC i will be selling this for $40 if anyone wants it.
Cheers, Jarrad
Re: Supercharged 4A-C!!!! Wed, 11 May 2005 11:14 Go to previous message
for budget build, get a megasquirt and a TBI injection unit off a falcon, piss easy and none of that shitty carby crap Wink
Previous Topic:20v heater
Next Topic:Backing PLate for T50
Current Time: Sat Oct 24 07:50:15 UTC 2026
Total time taken to generate the page: 0.0067241191864014 seconds
