Toymods » Tech & Conversions » 1G turbos
Helmann
Ipswich
1G turbos Mon, 18 November 2002 14:27 Go to next message
Are the turbos on a 1g sequential or do they run together. Just finished my transplant and it feels like they are sequential and i dont have a boost gauge yet to tell me the whole story. A friend said that they run together but i not sure now.
Also does anyone know if you can get a electric to mechanical speedo converter. Autometer make a mechanical to electrical but cant find one the other way round.
Re: 1G turbos Mon, 18 November 2002 23:31 Go to previous messageGo to next message
No, only the 2JZ-GTE has sequential turbos. The 1G-GTE has conventional parallel twins.
As for your speedo, just replace the electronic sensor on the gearbox with a speedo cable from an earlier box (I assume W58) - they are interchangeable.
Helmann
Ipswich
Re: 1G turbos Tue, 19 November 2002 02:26 Go to previous messageGo to next message
I have an auto box so can i still replace it???
Also my mechanic thinks that the turbos are running sequentially. I am not sure tho. There is definately 2 power surges. The first one just after i here the turbos spool and the second surge of power about 1500-2500 grand later.
Feels wierd. could there be some sorta problem?
gold28
Madrid - Spain
Re: 1G turbos Tue, 19 November 2002 02:49 Go to previous messageGo to next message
As far as I know (which isn't a lot), the 1g's never came with sequential turbo's, so unless you are running an aftermarket computer with this capability, I find it hard to believe.
You may have a problem with one of your waste gate actuators.
Re: 1G turbos Tue, 19 November 2002 07:20 Go to previous messageGo to next message
They are definetly not sequential...there is no WAY near enough plumbing as in a sequential setup. They will be running parallel, often engines seem to have a couple of surges...
Helmann
Ipswich
Re: 1G turbos Wed, 20 November 2002 01:49 Go to previous messageGo to next message
How does one check to see if wastegates are working properly? Mind u i have only just finished the conversion so there might be some other factors influencing it. Any ideas?
stradlater
Arthurs Creek, Victoria
Re: 1G turbos Wed, 20 November 2002 04:53 Go to previous messageGo to next message
I got the proper solution.
Rip off the smaller turbos
and Bung on one big one,
even a ct26 off a 7m-gte would be good..
Re: 1G turbos Wed, 20 November 2002 08:43 Go to previous messageGo to next message
Just find out what wrong with it! Don't need to resort to new turbos if its not necessary! Razz
stradlater
Re: 1G turbos Thu, 21 November 2002 04:52 Go to previous messageGo to next message
Of course you need a new turbo. A new turbo ALWAYS is the solution to a problem. A new LARGER turbo always fixes things....
Very Happy Very Happy Very Happy
Helmann
Ipswich
Re: 1G turbos Thu, 21 November 2002 06:05 Go to previous messageGo to next message
Hmmmm bigger tourbo already sounds very yummy but where am i going to get the money for one???
still have to pay off a large bit of money for the conversion!!!!
stradlater
Re: 1G turbos Thu, 21 November 2002 08:16 Go to previous messageGo to next message
just get a ct26, get the manifold made up for that, then later you can get the ct26 high flowed, and it'll pump heaps more.
Fattony
Re: 1G turbos Fri, 22 November 2002 11:30 Go to previous message
Yeah why not go the ct26
I got i which is goin on a 1g, has been high flowed with a to4e front wheel and the back wheels blades have been cut back for better top end eficiency due to less drag, which is at the expense of low rpm response but hey its up to where we have the most fun anyway.
Previous Topic:4a-fc is twincam possible??..or not
Next Topic:5K turbo??
Current Time: Mon Oct 26 07:35:14 UTC 2026
Total time taken to generate the page: 0.086143016815186 seconds
