Toymods » Tech & Conversions » sr20det fwd into ae92 rolla is it possible ????
RAN-ROLLA
April 2005
icon5.gif  sr20det fwd into ae92 rolla is it possible ???? Thu, 28 April 2005 02:57 Go to next message
just asking before i go out and try i have searched and found little to nothing on the subject any advice or knowlege on this topic is appreciated
Hilux_1j
April 2005
Re: sr20det fwd into ae92 rolla is it possible ???? Thu, 28 April 2005 03:03 Go to previous messageGo to next message
to be honest I would just go with a 4AGZE.. and then turbo it if that's what you want.. I think this would be less trouble!!
Corona RT142
Campbelltown
Re: sr20det fwd into ae92 rolla is it possible ???? Thu, 28 April 2005 03:05 Go to previous messageGo to next message
and if you wanted a two litre you'd probably use the 3sgte anyway
EldarO
Perth, WA
Re: sr20det fwd into ae92 rolla is it possible ???? Thu, 28 April 2005 03:09 Go to previous messageGo to next message
it would be possible using the pulsar sss 5 speed gearbox.
although everything you do would have to be custom
and it would be a pain in the ass..
but if your dead set, go for it.
good luck.
Eldar.O.
4agte
Toronto, Downtown
Re: sr20det fwd into ae92 rolla is it possible ???? Thu, 28 April 2005 04:01 Go to previous messageGo to next message
if my mate can fit a 3sgte into ae82 then you should be able to put them into a ae92. The sr20 would be a killer conversion as being an alloy block it should be lighter than a 3sgte.
anyways best way to see if it will fit is to start measuring your available space and then measure the engine gearbo so see if it will fit. Work out what parts you will need to carry over and where you plan to fit them. Also consult an engineer to find out if the conversion will be legal or what you ill need to make it legal.
Good luck if you decide to do this conversion
Re: sr20det fwd into ae92 rolla is it possible ???? Thu, 28 April 2005 04:15 Go to previous messageGo to next message
Dont expect the all alloy SR20DET to be super light.
Its heavier than its cast iron sister the CA18DET
Re: sr20det fwd into ae92 rolla is it possible ???? Thu, 28 April 2005 04:21 Go to previous messageGo to next message
agreed, the SR20 is a hefty sonofabitch.. as is the 3SGTE... the 4A is much lighter base to work with, and esp for FWD, would help you retain some sort of cornering ability..
then again, the extra 50kg or so will give you a bit more traction perhaps?
as long as you can make engine mounts to fit, AND get driveshafts that will fit both the box and the hubs, then why not? it would certainly be an individual setup, but for a FWD, is all that power potential a good thing? heh heh, be unltra different and fit an SC14 to the SR20 for the pinnacle of hybrid weirdness Wink
RAN-ROLLA
April 2005
Re: sr20det fwd into ae92 rolla is it possible ???? Thu, 28 April 2005 06:22 Go to previous messageGo to next message
thanx guy just one more question does any one know who i should talk to in sydney to get this done cash i can get time i cant
JFAllen
Adelaide, South Australia
March 2005
Re: sr20det fwd into ae92 rolla is it possible ???? Thu, 28 April 2005 07:54 Go to previous messageGo to next message
SR20DET = compromise of a compact motor with agressive valve angles = rocker ARMS!
don't bastardise your corolla, If your dead set on a 2.0L conversion, look to a 3S-GTE or for a powerfull NA solution look to a 2ZZ-GE or 4A-GE
Jordan
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: sr20det fwd into ae92 rolla is it possible ???? Thu, 28 April 2005 07:56 Go to previous messageGo to next message
go 2zz-ge turbo, that would be mad.
Re: sr20det fwd into ae92 rolla is it possible ???? Thu, 28 April 2005 07:59 Go to previous messageGo to next message
ViPeR_NiPPleX wrote on Thu, 28 April 2005 15:56
11.5:1 + turbo = not smart.
nightdevil
Wollongong
Re: sr20det fwd into ae92 rolla is it possible ???? Thu, 28 April 2005 08:00 Go to previous messageGo to next message
i think for the sr20det fwd conversion its best to import one from a bluebird sss altessa or n14 gti-r
JFAllen
March 2005
Re: sr20det fwd into ae92 rolla is it possible ???? Thu, 28 April 2005 13:07 Go to previous messageGo to next message
CrUZsida wrote on Thu, 28 April 2005 17:29
I believe it has been done, though only runnig modest boost eg, less than 10psi.
Jordan
ROLLA GTi
Re: sr20det fwd into ae92 rolla is it possible ???? Thu, 28 April 2005 14:11 Go to previous messageGo to next message
Buy a SSS Pulsar, the money you save from custom parts and a painfull conversion you will be able to make the pulsar quicker
and dont EVER put a nissan motor in a toyora Razz
ROLLA GTi
Re: sr20det fwd into ae92 rolla is it possible ???? Thu, 28 April 2005 14:12 Go to previous messageGo to next message
nightdevil wrote on Thu, 28 April 2005 18:00
Yep U13 Bluebird SSS or RNN14 GTiR
the gtir motors make more power, has quads and revs better though Smile
wagonist
Toymods Club Treasurer
Re: sr20det fwd into ae92 rolla is it possible ???? Fri, 29 April 2005 12:39 Go to previous messageGo to next message
Or alternatively, put in a 4A-GZE, sell the supercharger & install a turbo.
The money saved on the custom mounts & subframes (which you would need in a FWD conversion) you rebuild the motor with bigger turbo, custom manifolds, forged pistons, replace the head with a 20v, etc.
I know of 200+kW at the wheels versions of these.
Also, you have to remember that FWD engine bays are generally built around the engine.
Toyota FWD engines (with the exeption of the V6s where Camries have a removable subframe) have an engine mount on the end of the motor (where the belts are), & then one on the end of the gearbox. The other 2 are on the side either on the engine bell housing or the gearbox bellhousing.
Adapting another engine is a lot more difficult than a rwd, especially from another manufacturer.
4agte
Toronto, Downtown
Re: sr20det fwd into ae92 rolla is it possible ???? Fri, 29 April 2005 12:57 Go to previous messageGo to next message
CrUZsida wrote on Thu, 28 April 2005 17:59
we have 98 ron petrol i sydney with a well thought out application it is entirley possible has been done with much success on standard s2000 motors 11:1 comp.
Re: sr20det fwd into ae92 rolla is it possible ???? Fri, 29 April 2005 14:15 Go to previous messageGo to next message
Why? It seems that people I know who I might have given credit for intelligence in some areas so readily go SR mad over other seemingly more logical options.
4agte
Toronto, Downtown
Re: sr20det fwd into ae92 rolla is it possible ???? Fri, 29 April 2005 14:54 Go to previous messageGo to next message
i think people try to be different and try something illogical to make something out of this world. If there wasnt people like this arround willing to think outside the square and willing to take on something difficult instead of taking the easy rout all the time wher would the human race be. Something to think about befor people start baggin others for trying to be original.
Re: sr20det fwd into ae92 rolla is it possible ???? Fri, 29 April 2005 15:03 Go to previous messageGo to next message
Nobody loves the underdog project more than me (watch this space over the next couple of weeks, I'll stick some pics up), but to me, the underdog project is something you do yourself for the fun of doing it, not something you pay someone else to do. Generally, if you're paying someone to do your car for you, it's better to stick with a 'better known' route.
Also, there are more original ideas around - people seem to think the SR is the only 4 potter ever made, and tend to ask about putting them in everything...
bayka
perth
Re: sr20det fwd into ae92 rolla is it possible ???? Sat, 30 April 2005 10:32 Go to previous message
I agree.
If your going to try most of the work yourself i think thats an awesome project Smile
However I still think a 3sgte (toyotas under-rated sr20) would be a great choice too!
If in doubt....race tape....anything that doesn't fit properly....race tape Surprised
Previous Topic:Replacing camshaft seals?
Next Topic:Sydney backyard mechanic wanted (for easy job, pays beer or $$$)
Current Time: Fri Nov 20 23:00:12 UTC 2026
Total time taken to generate the page: 0.0076589584350586 seconds
