Toymods » Tech & Conversions » Availability of progressive 65mm springs
Sam_Q
S.E suberbs, Vic
Availability of progressive 65mm springs Thu, 28 April 2005 21:00 Go to next message
people I am interested in replacing my coil-over springs and I was wondering if any of the companies sell a progresive rate coil-over 65mm I.D spring? I wouldn't mind the car to be a little nicer around town without losing to much of my cornering or am I doing the wrong thing by looking at a progressive setup?
Joshstix
Toymods Vice President
Re: Availability of progressive 65mm springs Fri, 29 April 2005 11:54 Go to previous messageGo to next message
Kings make dual taper springs where the wire at the top and bottom tapers down to reduce the spring rate. I asked about pricing when I was looking for coil over springs and the dude at Kings said I didn't want to know so I didn't pursue that one.
Sam_Q
S.E suberbs, Vic
Re: Availability of progressive 65mm springs Fri, 29 April 2005 16:12 Go to previous messageGo to next message
thats odd its not on their website
M.W.P.
Rocky Mountains, Canada
Re: Availability of progressive 65mm springs Fri, 29 April 2005 16:29 Go to previous messageGo to next message
Yes it is...
http://www.kingsprings.com/Prosport/prosport_singl e_end_tapered_wire_progress.htm
and
http://www.kingsprings.com/Prosport/prosport_doubl e_end_tapered_wire_progress.htm
The single end tapered are about twice as expensive as linear rate springs though. Not sure about the price of the double end tapered.
Much better to use a linear rate spring and a tender coil (i ordered these today) as youll then be able to change your spring rate for a lower cost if you need to.
If you are still looking at progressive, give them a call, and ask to be emailed the rate curve graphs for the springs you are interested in.
[Updated on: Fri, 29 April 2005 16:31]
Stefan
Hobart, Tas
Re: Availability of progressive 65mm springs Tue, 03 May 2005 14:26 Go to previous messageGo to next message
Another thing to keep in mind is that (at least with stock-replacement springs) many progressive springs are effectively linear when installed, and are merely progressive to keep the springs captive at full droop etc.
My front Kings lowering springs are like this.
Personally, I'd be going the option as suggested by M.W.P.
Sam_Q
S.E suberbs, Vic
Re: Availability of progressive 65mm springs Tue, 03 May 2005 14:40 Go to previous messageGo to next message
well I stand corrected, however they dont have a 275lb anyway so I am not interested. Is a tender spring the same as a helper spring because that doesnt effect the ride at all?
Re: Availability of progressive 65mm springs Tue, 03 May 2005 23:47 Go to previous messageGo to next message
Yeah I think tender/helper all the same. They only effect the ride height slightly, as when the weight of the car is on them they are totally compressed.
takai
Re: Availability of progressive 65mm springs Tue, 03 May 2005 23:57 Go to previous messageGo to next message
They shouldnt affect the ride height at all. You just have to compensate for the thickness of them when compressed.
Here is a pic of mine installed:
http://www.dysfunction.ws/albums/Sprinter/IMG_0434.jpg
The kings spring is the tender/helper spring (KF65S) and the eibach is my 450lbs main spring.
Re: Availability of progressive 65mm springs Wed, 04 May 2005 00:09 Go to previous messageGo to next message
Sorry thats what I meant, the ride height increase is just the thickness of the springs when bound together. I think mine was like 20mm or so.
takai
Re: Availability of progressive 65mm springs Wed, 04 May 2005 00:21 Go to previous message
Yeah? 20mm sounds very small. You using the little Eibach ones? The Kings ones are around 40mm thick i think.
Previous Topic:JZA70 to MA70 Conversion advice
Next Topic:Auto 3SGTE
Current Time: Wed Oct 28 00:04:59 UTC 2026
Total time taken to generate the page: 0.004539966583252 seconds
