Classifieds » Engines, Accessories and other Mechanicals » 300/288 cams for 4age (dyno graph uploaded)
AE86 Levin Melbourne
300/288 cams for 4age (dyno graph uploaded) Fri, 29 April 2005 01:25 Go to next message
Cams out of my engine
when I was using these cams with my quad set up, it pulled 100kw at the rear wheels
anyway:
They are Tighe cams
profile 1144C for Inlet:
Duration 288 and .302"valve Lift (which is around 7.7 in mm)
Profile 1155c for Exhaust
Duration 300 and .324"valve lift (which is around 8.3 in mm)
Before every one ask, They are new billets and not reground. They still run the factory shims over but you may need an aftermarket computer to run it. Reason why I am selling is because I am looking at some different coversion for my car so this is no use to me anymore.
I am looking for around $550 for the pair
[Updated on: Tue, 30 August 2005 07:20]
Re: 300/288 cams for 4age Tue, 14 June 2005 02:51 Go to previous messageGo to next message
pics up..bump price drop now $450
http://forums.toymods.org.au/index.php?t=getfile&id=12525
Attachment: cams.jpg
(Size: 42.36KB, Downloaded 1243 time(s))
TRD-GTI
Elwood, Melbourne
May 2005
Re: 300/288 cams for 4age Wed, 15 June 2005 12:06 Go to previous messageGo to next message
you say "may need aftermarket ecu"- were you running one? if so what sort please?
I guess a standard ecu would struggle to get adequate sensor readings to run them? Confused
also, what sort of power band did you have? were they torquey or realy peaky? I have read that using an exh. profile a step or so down from the inlet gives a wide band of "useable" torque. so Im guessing that being the opposite, these are possibly quite a narrow band?
cheers heaps Wink
Re: 300/288 cams for 4age Thu, 16 June 2005 01:50 Go to previous messageGo to next message
hi there,
I was running an Autronic SMC with these cams
it's not the sensor, it's that u need to adjust the ignition timing on the computer to make these cams idle and runs perfect.
I was going to upload a dyno graph for these cams but I forgot to bring it with me today...i will try to post it tmr. power band is from around 4500-8000rpm
TRD-GTI
Elwood, Melbourne
May 2005
Re: 300/288 cams for 4age Thu, 16 June 2005 07:31 Go to previous messageGo to next message
sweet, cheers dude.
so they wont work at all without aftermarket ecu?- I may have to push forward my plans to buy one then Razz
Re: 300/288 cams for 4age Thu, 16 June 2005 11:00 Go to previous messageGo to next message
Are you any more negotiable on price? - i see you've already dropped it but thought it's worth asking. As just out of my price range at the moment.
Joel
Lachie
Re: 300/288 cams for 4age Fri, 24 June 2005 05:29 Go to previous messageGo to next message
AE86 Levin Melbourne wrote on Thu, 16 June 2005 11:20
hi there,
I understand that you have to run an afetrmarket computer cause you can't get a big enough manifold vaccum reading for them to work. Anything bigger then about 264 degrees and you'll start having problems.
So I guess your right TRD-GTI, but I also suspect running these with stock ignition settings would not be good...
AE86Trader
Central Coast
January 2005
Re: 300/288 cams for 4age Sat, 25 June 2005 01:24 Go to previous messageGo to next message
I have personally installed some camshafts successfully into a 4AGZE which had a standard ECU AFM version. The Cams were 288degree 7.5mm lift and the only problem we had was the spark was weaker because the faster higher intake of air was blowing out the spark of the plugs. (fix) 0.65 plug gap instead of 0.8.
The only problem people have with cams is between their ears. Why would a 264 cam be the limit and a 272 or 288 be bad.
psychofox
Wollongong, NSW
Re: 300/288 cams for 4age Sat, 25 June 2005 02:02 Go to previous messageGo to next message
GZE AFM computer is somewhat different to the GE MAP computer....for one, Air Flow Meters ars more tolerant to low manifold vaccumm (in fact they don't care) than MAP Sensors.
Question, why are these cams one step bigger on the Exhaust than the Inlet? Most of the big tuners (TODA, TRD, HKS, etc.) generally recommend going the other way? Did you choose this cam setup yourself or did your engine builder? What was the idle like?
TRD-GTI
Elwood, Melbourne
May 2005
Re: 300/288 cams for 4age Sun, 26 June 2005 15:19 Go to previous messageGo to next message
that was the othr point i was wondering about...
although I believe it can be altered to suit application. one way gives a narrower powerband the other alot wider. they also perform better at different scales of the rpm range
Lachie
Re: 300/288 cams for 4age Mon, 27 June 2005 13:03 Go to previous messageGo to next message
I'm still new to 4A-GE's but 18R-G's used to get built with cams like this (I was so close to buying very similar cams for an 18R-G)
I have no idea of the reason - I've never really thought about it...
b1gb3n
south Melbourne/KL
Re: 300/288 cams for 4age Mon, 27 June 2005 15:23 Go to previous messageGo to next message
Lachie wrote on Fri, 24 June 2005 15:29
hi there,
i run 267 degree cams and dont have vacuum problem. idles perfectly with adjustable cam gears. however, somehow the stock ecu runs really rich at idle. have S-AFC to sort that out
Lachie
Re: 300/288 cams for 4age Tue, 28 June 2005 06:04 Go to previous messageGo to next message
Are u running a MAP or AFM sensor? AFM will fair better then MAP sensed engines with bigger cams. 267 is only a little bigger then what the stock computers with MAP will start running into problems.
I think they'll run, just not too well.
b1gb3n
south Melbourne/KL
Re: 300/288 cams for 4age Tue, 28 June 2005 07:08 Go to previous messageGo to next message
Lachie wrote on Tue, 28 June 2005 16:04
mine's MAP. runs perfectly now
psychofox
Wollongong, NSW
Re: 300/288 cams for 4age Tue, 28 June 2005 08:14 Go to previous messageGo to next message
Given you had to run a S-AFC and Cam Gears on it to get the idle right it's hardly what you call plug and play for the factory ECU....
Hybrid_86
Re: 300/288 cams for 4age Thu, 28 July 2005 09:37 Go to previous messageGo to next message
presuming these have sold?
Re: 300/288 cams for 4age Fri, 29 July 2005 01:05 Go to previous messageGo to next message
not yet..I still have them
adamaw11
February 2005
Re: 300/288 cams for 4age Fri, 29 July 2005 01:29 Go to previous messageGo to next message
I take it these cams would not go into the 20v would they?
Would they fit in any 16v 4age or 4agze?
Where did you buy them from?
rxbenny
Perth WA
Re: 300/288 cams for 4age Mon, 01 August 2005 13:28 Go to previous messageGo to next message
pm sent
boog
campbelltown
April 2005
Re: 300/288 cams for 4age Tue, 02 August 2005 01:54 Go to previous messageGo to next message
hi, very interested in these cams have you any idea what it would cost for shipping to sydney ???????
kojak
sidoonie
Re: 300/288 cams for 4age Fri, 05 August 2005 03:23 Go to previous messageGo to next message
are they sold yet?!?! price?!?!
Re: 300/288 cams for 4age Tue, 30 August 2005 07:19 Go to previous messageGo to next message
This is the graph b4 fine tunning..I lost the one after fine tune, anyway, this will give u a general idea on what power this cams made:
http://forums.toymods.org.au/index.php?t=getfile&id=14498
Attachment: die2.gif
(Size: 60.55KB, Downloaded 455 time(s))
Re: 300/288 cams for 4age (dyno graph uploaded) Tue, 30 August 2005 07:45 Go to previous messageGo to next message
dodgiest dyno graph eva Razz
TRD-ST162
Re: 300/288 cams for 4age (dyno graph uploaded) Tue, 30 August 2005 08:06 Go to previous messageGo to next message
Look at the kick of power at 5500rpm... This would kick damn hard in a 4age with some small tuning to get the idle right, if these were 3sge cams i would have snapped em up in a second!
Re: 300/288 cams for 4age (dyno graph uploaded) Tue, 30 August 2005 08:30 Go to previous messageGo to next message
Draven can you please tell me why this would be the dodgiest dyno graph? do you have a "proper" dyno graph to show?
GTV AE86
June 2005
Re: 300/288 cams for 4age (dyno graph uploaded) Tue, 30 August 2005 10:54 Go to previous messageGo to next message
How long have you had these cams in you car? IT says on the dyno that its date 14-4-03. So I am guessing that these cams are over 2 years old.
How worn are these cams?
As I am very interested, I just need the peace of mind when buying such items.
I also sent you a pm
rxbenny
Perth WA
Re: 300/288 cams for 4age (dyno graph uploaded) Mon, 03 October 2005 16:56 Go to previous messageGo to next message
still for sale?
AE86Trader
Central Coast
January 2005
Re: 300/288 cams for 4age (dyno graph uploaded) Mon, 03 October 2005 21:07 Go to previous messageGo to next message
Ive seen worse dyno graphs but its pretty bad. (no offense) Who eva buys these cams will get good power. It just looks like someone has put too much advance on the top end or something cause of the wavey power up top. also the resounant at around 5000RPM THIS IS NORMAL! but can be fixed quite easily. Im hoping that wasnt your final run on the dyno or your engine tuner didnt know what he was doing.
BTW most big companies TODA HKS etc recommand miss matched cams because the average Joe who buys them (and also far too many tuners) dont know how to tune them properly so miss matched cams would be a bit better then same cams for both In and EX. also its 'MENT' to be better for turbos
ancullen
Darwin, NT
October 2005
Re: 300/288 cams for 4age (dyno graph uploaded) Tue, 04 October 2005 00:05 Go to previous messageGo to next message
Are these cams still for sale, and if so, how much?
Stretch
Sydney,Hurstville
Re: 300/288 cams for 4age (dyno graph uploaded) Tue, 04 October 2005 11:03 Go to previous messageGo to next message
you have a pm.
mattyae71
newcastle
July 2005
Re: 300/288 cams for 4age (dyno graph uploaded) Fri, 07 October 2005 21:48 Go to previous message
hey man, the cams still there?? let me know if you will take $350 for them and ill buy them today.ph. 0408224270 matt.
Previous Topic:2JZ-GTE 440cc Injectors
Next Topic:GZ20 Soarer G Series Diff Centre
Current Time: Wed Nov 18 14:50:50 UTC 2026
Total time taken to generate the page: 0.010203838348389 seconds
