Toymods » Tech & Conversions » Amp trouble
Stefan
Hobart, Tas
icon9.gif  Amp trouble Tue, 19 November 2002 03:11 Go to next message
Hi all. I currently have a 25wx4 amp running through an active crossover, which works fine. Bought an Alpine 3555 (50w x 4) off ebay a month ago to upgrade it, finally got around to wiring it up today.
It sounds very hissy/distorted/quiet Sad. I can't figure it out. I took out the fuse on my hot line from the battery before connecting it up, so I don't see how I could have hurt it, and the old amp still works when i swap it back in.
Just wondering if anyone with a bit of amp knowledge has any ideas. Hope I didn't buy a dud Sad
juzzo84
Hornsby, N.S.W
icon13.gif  Re: Amp trouble Tue, 19 November 2002 10:40 Go to previous messageGo to next message
i have never seen this sort of thing before, except with an amo that was completly skrewed. i have spend a fair amount of time around car audio equipment and this is a bad sounding situation.
sorry i cant really help, good luck
JUZZO
Stefan
Hobart, Tas
Re: Amp trouble Tue, 19 November 2002 13:39 Go to previous messageGo to next message
thanks for replying. I wish i'd tested it straight away when i got it, but the way I had my amp installed meant I couldn't test out the next one without rewiring. Will have another look at it tommorow - hopefully an just ground point is broken or something.
juzzo84
Hornsby, N.S.W
icon12.gif  Re: Amp trouble Tue, 19 November 2002 20:03 Go to previous messageGo to next message
you may also wanna check that you did not cross the RCA leads and the power leads, as this eill create distortion in the amplifier due to the energy field radiated by the power cable that effects the low power rca signals. but in how you explained it, it sounds a bit worse than just this, but give it a go and see what happens.
BEST OF LUCK
JUZZO
Re: Amp trouble Tue, 19 November 2002 23:27 Go to previous messageGo to next message
Put the amp on the bench, hook it up to a car battery, CD player and some speakers, see wha it sounds like... if it still sounds horrible, then its time to pull the lid off and have a play/give it to someone that knows how to do so...
Stefan
Hobart, Tas
Re: Amp trouble Wed, 20 November 2002 04:36 Go to previous message
Thanks all for your help. I think it's fixed!!!
I took the lid off, couldn't see anything suss, ao decided to wire it up in the car again. This time i took out the crossover and went straight from headunit --> amp. Worked beautifully. I have no idea what the problem was before - perhaps somehting funny is happening with the crossover that one amp doesn't care about and the other one does (+/- out of phase??)
I will tell you what happens when I connect up the crossover again, but for now i am happy my amp is not stuffed! thanks again
Previous Topic:KE25 Brake upgrade
Next Topic:best place for suspension mods for a JZA80
Current Time: Thu Oct 29 12:56:53 UTC 2026
Total time taken to generate the page: 0.0044629573822021 seconds
