Toymods » Tech & Conversions » 1jz head on a 2jz block
DECPTN
Auckland NZ
1jz head on a 2jz block Tue, 19 November 2002 03:26 Go to next message
Hey,
Has anyone tried/measured this yet, I no it is quite common in japan they call the result a 1.5j but would be interested to know if someone has given it ago does anything have to be retapped/modified, and will the 1jz 5spd bolt onto the back of the 2jz block? Because I have a built short block 2jz sitting in my garage and it would make an interesting conversion into my jzx100 chaser
James
Re: 1jz head on a 2jz block Tue, 19 November 2002 04:37 Go to previous messageGo to next message
Interesting? Yes.
Functional? Maybe.
The head itself will physically bolt on, but I can't specifically comment on all the ancillaries.
I suppose you have to ask whether the 1JZ head will actually flow as well as the 2JZ head. I am wondering why it is done and what advantage is gained.
Cheers Dave.
Re: 1jz head on a 2jz block Tue, 19 November 2002 05:07 Go to previous messageGo to next message
The "1.5JZ" is quite common in Japan now, but you have to understand why they do it. There are plenty of JZA70 owners with worn out 1JZ's, and it turns out that a brand new 2JZ bottom end is cheaper than rebuilding the 1JZ bottom end - so they simply swap in the new 2JZ core and leave everything else as is. The result is a fresh engine with the extra benefit of another 500cc.
I haven't heard of anyone with a 2JZ-GTE who replaced the head with a 1JZ-GTE item - I can't think of any reason this would be an improvement.
DECPTN
Auckland NZ
Re: 1jz head on a 2jz block Tue, 19 November 2002 06:17 Go to previous messageGo to next message
Thanks for the info, it comes down to the fact that I have a reasonably strong 2jz shortblock (Rebuilt, factory rods/JE Pistons) that has no head or ancillaries, and a complete late model 1jz VVt-i in my car now, so instead of rebuilding the 1j I thought it would be easier to convert to the 2j block use the 1j head (easier form an intergration point of view shouldn't have to change sensors etc) and gain the benifit of an added 500cc which in a car as heavy as the JZX100 should be quite benificial, but keep the suggestions comeing
James
P.S The 1j head in my car also has topfeed injectors so Im not limited to $1800 sidefeed sard upgrade's
[Updated on: Tue, 19 November 2002 06:27]
Remedy
Southern Sydney
Re: 1jz head on a 2jz block Tue, 19 November 2002 06:24 Go to previous messageGo to next message
It was my understanding that the 1jz head was the one designed by Yamaha and so was a technically supperior design then the 2jz which was designed in house at toyota.
However, the 2jz head is sure to have a larger flow capacity and therefore be better suited to a High HP engine?
streetknight
boston mass usa
Re: 1jz head on a 2jz block Tue, 19 November 2002 08:14 Go to previous messageGo to next message
well a few ppl have dont it here in the states but i personally dont see the benifits of it really all the main diff. the 1j is a .02 head shave. the 2j has bigger ports intake and exhaust, also the 2j is alot better for air flow. but as said in jp its use full because of the price here in the states there are more 2jz then 1jz hanging around
DECPTN
Auckland NZ
Re: 1jz head on a 2jz block Tue, 19 November 2002 08:37 Go to previous messageGo to next message
Hey,
Thats cool I appreciate all the feedback I understand that the 1j head might not flow as much as a 2j but my car runs the VVT-i head which from what I can decifer in the jap sites is better than the earlier model. Secondly does the R154 box fit on the back of the 2jz (I think they used this box on the NA 2JZ??)
James
Re: 1jz head on a 2jz block Tue, 19 November 2002 09:12 Go to previous messageGo to next message
The R154 will bolt up behind the 2JZ, provided you have the correct bellhousing etc. These are found behind 1JZGTEs. They used the W58 behind the GE.
I think I have worked it out now....you want to put the 2JZ bottom end in your Chaser with the VVTi head on top?
If so, you need an oil supply to the VVTi. Also you may want to flow your head just to make sure it's up to the job of the bottom end, and possibly look into 2JZGTE VVTi cams (at least get the specs so you can compare with yours).
celicamad
newcastle
Re: 1jz head on a 2jz block Tue, 19 November 2002 09:13 Go to previous messageGo to next message
Just a point of interest have you had the 1jz vvti on a dyno or g tech im interested in how much power can be squeezed from these
DECPTN
Auckland NZ
Re: 1jz head on a 2jz block Tue, 19 November 2002 19:58 Go to previous messageGo to next message
Haven't yet had it on the dyno, but should have within the next week or so, will post the results if interested. But have pulled a 13.4@101mph down the quarter, with 3inch TRD Exhaust, and TRD air filter and computer being the only mods.
celicamad
newcastle
Re: 1jz head on a 2jz block Wed, 20 November 2002 08:55 Go to previous messageGo to next message
13.4 's not bad how much boost do you run and how much will this turbo take ??
what computer mods have you run .will the engine still run vvti
Biggus Dickus
Re: 1jz head on a 2jz block Thu, 21 November 2002 12:03 Go to previous messageGo to next message
And what tyres were you using?
DECPTN
Auckland NZ
Re: 1jz head on a 2jz block Sun, 15 December 2002 09:31 Go to previous message
Running 1.1 bar boost, which is pretty much the limit of the whole thing, as for tyres nothing special just some bridgestone's on the factory 17in TRD wheels
Previous Topic:Intercoolers and lag
Next Topic:4age 88kw blue top +$1500
Current Time: Sat Oct 31 03:09:07 UTC 2026
Total time taken to generate the page: 0.039820909500122 seconds
