Toymods » Tech & Conversions » Auto 3SGTE
JustenGT4
Auto 3SGTE Fri, 29 April 2005 03:24 Go to next message
Yes i know there is no such thing but in RWD guise is there a 1S or 2S auto available that would do the job for me?
I'm not inclined to answer "why" at present so don't bother asking Smile
Lets try and keep this to whether there's a tranny available and what model i'd be pulling it from please...
TA22-3SGTE
MACKAY
Re: Auto 3SGTE Fri, 29 April 2005 11:35 Go to previous messageGo to next message
What about auto from a IS200
Trevor
Joshstix
Toymods Vice President
Re: Auto 3SGTE Fri, 29 April 2005 11:38 Go to previous messageGo to next message
Yep the RS200 came with a five speed auto behind the 3S. It don't think it will take to kindly to the torque of a 3S-GTE but then again I don't think a 1S or 2S one woukd either.
._T_.
Re: Auto 3SGTE Fri, 29 April 2005 22:53 Go to previous messageGo to next message
auto behind some versions of 2wd hiluxe will be adaptable - & they wil be strong enough! ratios will not be too hot though
T
JustenGT4
Re: Auto 3SGTE Sun, 01 May 2005 23:27 Go to previous messageGo to next message
Thanks guys,
The tranny would need some tweeking i dare say but good to know here are some options. I think the IS200 option is gonna be hard to find and a bit pricey. The Lolux trannies sound interesting though, got any details on a potential model or year range you reckon might do the job?
Meat_rack
East Maitland NSW
Re: Auto 3SGTE Mon, 02 May 2005 08:41 Go to previous messageGo to next message
To be honest there arnt many toyota auto's that id recommend. They don't have a a long enough ratio and they tend to burn out quiet quickly compared to other boxes....
Have fun tracking down a wiring harness that will link the two together.
Tweaking one isnt worth you while, you can change ratios and they don't take to shift kits very well ie.. you can up the pressure all you want and make it shift real hard but the harder i shifts is directly proportional the the life of your particular box.. My opinion Manual for strength but maybe a better option would be to find a bell housing of a BW35 or a trimatic these are real cheap to build and can take quiet a good flogging if build well, and this is coming from a auto transmission mechanic
Stay classy...
Cheers.
Andrew
ralfross
On Probation
April 2005
Re: Auto 3SGTE Mon, 02 May 2005 12:10 Go to previous messageGo to next message
caldina. thats auto.
Meat_rack
East Maitland NSW
Re: Auto 3SGTE Mon, 02 May 2005 12:25 Go to previous messageGo to next message
Caldina?
ralfross
On Probation
April 2005
Re: Auto 3SGTE Mon, 02 May 2005 12:37 Go to previous messageGo to next message
Caldina GT-Four
Model Code : ST246
Full time AWD
1480kg Vehicle Weight
1755kg Gross Vehicle Weight
4 Speed Automatic Transmission
http://www.alltrac.net/caldina/2.jpg
[Updated on: Mon, 02 May 2005 12:40]
ralfross
On Probation
April 2005
Re: Auto 3SGTE Mon, 02 May 2005 12:38 Go to previous messageGo to next message
I didnt really read the post. Just saw 3sgte auto and thought 'caldina.'
I know where one is being wrecked. 260hp engine and auto box
JustenGT4
Re: Auto 3SGTE Mon, 02 May 2005 22:58 Go to previous messageGo to next message
RWD Ralfo...sheesh
Thanks for the tips Andrew. Slushboxes have never been my thing but for what i'm looking at they seemed to be the easy route. Still sussing alternatives so all good info, ta.
ralfross
On Probation
April 2005
Re: Auto 3SGTE Mon, 02 May 2005 23:27 Go to previous messageGo to next message
Like I said i didnt read the post. no need to get agro.
[Updated on: Mon, 02 May 2005 23:29]
JustenGT4
Re: Auto 3SGTE Mon, 02 May 2005 23:28 Go to previous messageGo to next message
No Message Body
spectral
Re: Auto 3SGTE Tue, 03 May 2005 00:52 Go to previous messageGo to next message
Justen: Another option is the 3CT Turbo diesel 4-speed Auto box, they came in the Toyota Estima.... www.justjap.com.au list an Estima Emina/Lucida as a halfcut "coming soon"...
The 3CT uses the same bellhousing as a S series I believe.
EDIT: Actually the Estima may be 4WD only, not too sure. The JDM Liteace had the 2C-T and 3C-T (in later models) as well, most of them are RWD.
[Updated on: Tue, 03 May 2005 01:05]
JustenGT4
Re: Auto 3SGTE Tue, 03 May 2005 00:55 Go to previous messageGo to next message
Thanks Spectral. Looks like a number of options there...more homework to sort out the best way to go Smile
Meat_rack
East Maitland NSW
Re: Auto 3SGTE Tue, 03 May 2005 07:21 Go to previous messageGo to next message
Well when you reckon you find a well suited box give me a yell and ill try to give you as mcuh info on it.
Ie. strenght, durability etc
Andrew..
JustenGT4
Re: Auto 3SGTE Tue, 03 May 2005 23:27 Go to previous message
Thanks Andrew, i'll no doubt be in touch.
Previous Topic:Availability of progressive 65mm springs
Next Topic:1JZ Fuel Pump Relay Wiring
Current Time: Tue Oct 27 13:04:02 UTC 2026
Total time taken to generate the page: 0.022006988525391 seconds
