Toymods » Tech & Conversions » 4AGE Cranks, but does not run.
Matt-AE86
4AGE Cranks, but does not run. Fri, 29 April 2005 23:04 Go to next message
Ok, did a conversion in my AE86 to AE82 16v 4AGE. Its all been loomed up etc. Have power to ECU on B+, B1+ and BATT on IGN ON and START. Tested ignitor, all leads make spark. Fuel is pumping threw into the rail niceley etc. So turn the key, it will just stay cranking.
Im thinking its got to be something to do with the injectors. Has anyone heard of this problem before? I found a thread on Club4ag that it was happening to a phew people. http://forums.club4ag.com/topic.asp?TOPIC_ID=90305
Thanks. All help appreciated.
takai
Re: 4AGE Cranks, but does not run. Sat, 30 April 2005 02:04 Go to previous messageGo to next message
What injectors are you using. Stupid question i nkow, but square plug injectors are low impedence, and the round 100kw (green) type are high impedence.
shinybluesteel
melbourne
Re: 4AGE Cranks, but does not run. Sat, 30 April 2005 02:12 Go to previous messageGo to next message
have you got the timing set right?
this is the problem i had, get the timing right first.
while you are stting the timing and have the dizzy out of the head, turn the rotor around by hand with the ignition on, you should be able to hear the injectors "ticking" which will tell you if they are opening, but not if they are clogged up.
SPRINTAH!
Re: 4AGE Cranks, but does not run. Sat, 30 April 2005 02:23 Go to previous messageGo to next message
i'd take the plugs out and hook a timing light up. just to make sure that the timing is about right.
If the timing is right then i'd say its an injector problem,
if the timing is way out then you might have the dizzy 1 or 2 teeth out.
are the plugs wet when you take them out??
79rollaboy
NSW Engadine
Re: 4AGE Cranks, but does not run. Sat, 30 April 2005 02:37 Go to previous messageGo to next message
Same thing happened to mine...
Make sure the power feed for the injectors is connected...
I know the JAP RWD 4AGE needs a separate power feed...
From memory the wire is yellow...
sideshow
Re: 4AGE Cranks, but does not run. Sat, 30 April 2005 06:00 Go to previous messageGo to next message
it could be a million things
spray aerostart down air cleaner if it runs then its fuel problem
if it doesnt then its something else
did u do cam belt
if yr not mechanically minded i have had people do belts on these and totaslly fuck em up cause the dowels are opposite to each other
if mechanically its ok and u have spark then there ios no reason that it wont start on aerostart
Matt-AE86
Re: 4AGE Cranks, but does not run. Sat, 30 April 2005 06:14 Go to previous messageGo to next message
heh aerostart, i thought, yer ill see if its that, so got the aerostart out spray abit in there, turn, crank, ran for a tick, ok so it is injectors, probs clogged.. wait, spray some in there, connect pump, and turn key... omg runs.
but now its all over the place.. ill keep you intouch with whats happening, mate is coming around "qualified toyota mechanic"..
79rollaboy
NSW Engadine
Re: 4AGE Cranks, but does not run. Sat, 30 April 2005 23:35 Go to previous messageGo to next message
Did you make sure the power feed for the injectors is connected???
Your not going anywhere without power to the injectors buddy...
takai
Re: 4AGE Cranks, but does not run. Sun, 01 May 2005 03:26 Go to previous messageGo to next message
79rollaboy wrote on Sun, 01 May 2005 09:35
Pssst. it runs now
79rollaboy
NSW Engadine
Re: 4AGE Cranks, but does not run. Sun, 01 May 2005 04:07 Go to previous messageGo to next message
takai wrote on Sun, 01 May 2005 13:26
Pssst. it runs now
I knew that Rolling Eyes
Matt-AE86
Re: 4AGE Cranks, but does not run. Sun, 01 May 2005 23:51 Go to previous message
I had the car running the same day a phew hours after i posted. I think injectors were glogged or something, cause spraying in the aerostart and trying that got it running, runs now but VERY DIRTY SPEC. Needs a tune. Thanks for the advice though.
http://forums.toymods.org.au/index.php?t=msg&t h=32447&rid=3968&S=31d4ab87f0586cbe3e51eba 4153a9888&pl_view=&start=60#msg_627703
You can read the fun i had Razz
Previous Topic:OIL CATCH CAN --- WHAT SHOULD I USE AS FILTER
Next Topic:z21 cruise control
Current Time: Wed Oct 28 20:16:36 UTC 2026
Total time taken to generate the page: 0.016610860824585 seconds
