Classifieds » Miscellaneous » 7.1 surround sound home theatre-will seperate
tempest
mona vale,northern beache...
7.1 surround sound home theatre-will seperate Fri, 29 April 2005 23:37 Go to next message
WILL SEPERATE.IF SOMEONE WOULD RATHER JUST THE TOWERS OR THE 5.1 WILL DO EITHER FOR $900
fleetwood 7.1 surround sound home theatre.
still in box.brand new
comes with on board amp.5 satellites.10 inch sub.2 towers.
the specs for the 5.1:
6100 Series
CENTER CHANNEL
Shielded dual woofers combine with a high efficiency tweeter to position dialog at center stage. This effect is true Home Theater...can also be used in full range applications.
http://www.fleetwoodaudio.com.au/welcome/images/speaker_01.jpg
SATELLITES
Front and Rear satellite speakers utilize a two way design to maximize accurate delivery of theater information including Special Effects. Units can be wall or ceiling mounted with swivel brackets (included).
http://www.fleetwoodaudio.com.au/welcome/images/speaker_02.jpg
POWERED SUB WOOFER
The 5.1 system is reinforced with a dynamic 10inch Sub Woofer and powered by a dual voltage amplifier creating thunderous base. The electronic crossover is accurately blended with the satellites to deliver a seamless theatre effect.
http://www.fleetwoodaudio.com.au/welcome/images/speaker_03.jpg
Total System:
Frequency response 35Hz-22kHz
Impedance 4-6ohm
Power rating 150 Watts for the sub
(music) 80 Watts per channel for front and rear
100 Watts for the center channel
Sub Woofer:
Frequency response 35Hz-200Hz 90dB/W-m
Impedance 6ohm
Power rating 150 Watts (music power)
Component 10" - 6ohm woofer in ported, down-fired, vinyl wrap cabinet.
Crossover 35Hz-150Hz adjustable
Built-in Amp Inverse Phase Selector, Hi/Low Inputs, Volume Control 115V/230V Dual Voltage, Auto Power On/Off
Front & Rear Channel: (satellites)
Frequency response 95Hz-22KHz, 88 dB/W-m
Impedance 4ohm
Component Shielded 4" Woofer with a 1/2" Dome Tweeter
Crossover 6dB/Octave 2-Way
Center Channel:
Frequency response 100Hz-2KHz, 90 dB/W-m
Impedance 4ohm
Component Dual Shielded 4" Woofers with a shielded 1/2" Dome Tweeter
Crossover 6dB / Octave 2-Way
[Updated on: Thu, 12 May 2005 10:09]
tempest
Re: 7.1 surround sound home theatre Fri, 29 April 2005 23:41 Go to previous messageGo to next message
these are the towers that make it a 7.1
Tweeter: 1in. soft dome with ferro fluid
Mid-Bass Woofers: Dual 51/4 in. "High Modulus" fiberglass cone, butyl rubber surround; 1 in. diameter 4 layer hi-temp coil.
15oz. high strength shielded ceramic magnet.
Sub-woofer: Dual 8 in. high strength shielded ceramic magnet woofers, 3 in.diameter hi-temp Kapton voice coil.
Port: Flared 4th order Butterworth tuning
Network: Gold plated terminals with bi-amp feature
http://www.fleetwoodaudio.com.au/welcome/images/SR3216.jpg
Power: 250 Watts RMS, 500 Watts Peak
Sensitivity: 90db 1W/1M
Frequency Response: 36-23,000Hz(+/-3dB)
Crossover Frequency: 800, 5kHz
Nominal Impedance: 8 ohm
Cabinet Design: Precision crafted lock miter construction with separate internal acoustic chambers
Wood-grained vinyl finish
High dispersion aluminum baffle
tempest
Re: 7.1 surround sound home theatre Fri, 29 April 2005 23:46 Go to previous messageGo to next message
im after $2000 ono.
if u aint interested or have any negative comments DONT POST THEM HERE.
tempest
Re: 7.1 surround sound home theatre Sat, 07 May 2005 00:53 Go to previous messageGo to next message
bump
price drop $1800
heres the link with RRP. pricing www.fleetwoodaudio.com.au you will notice the prices are in US dolaars
forgot to mention this system is hi-definition not hi-fi
[Updated on: Sat, 07 May 2005 06:03]
tempest
Re: 7.1 surround sound home theatre-will seperate Sun, 15 May 2005 01:48 Go to previous messageGo to next message
bump
JiM?
March 2005
Re: 7.1 surround sound home theatre-will seperate Sun, 15 May 2005 10:11 Go to previous messageGo to next message
hey mate really looking to upgrade my HT setup
do they come with wiring
how much did you pay for them and where did you get them from cause there are no links to distributers on thier website.
tempest
Re: 7.1 surround sound home theatre-will seperate Tue, 17 May 2005 10:42 Go to previous message
pm sent
Previous Topic:For Sale: 80KPH 70cc Pocket Bike
Next Topic:MA/JZA 70 stuff that has to go. Now with more!!
Current Time: Fri Oct 23 12:44:04 UTC 2026
Total time taken to generate the page: 0.0053379535675049 seconds
