Toymods » Tech & Conversions » SA63 - T Series to F Series Swap Over
ZZT231
melbourne.vic.au
SA63 - T Series to F Series Swap Over Sat, 30 April 2005 03:02 Go to next message
Hey All,
I got myself an F Series Diff, Does anyone know if the Subframe has to be changed for the F Series to slide up into place where the T Series used to live? Has anyone done it before etc?
Cheers.
Mookie
Tassie
Re: SA63 - T Series to F Series Swap Over Sat, 30 April 2005 04:41 Go to previous messageGo to next message
I'm looking at doing it myself.
I made a thread alittle while back about it and i was told that the cradle thing on top of this diff has to be changed but that's all.
go find the thread as i my memory is really REALLY bad
ZZT231
melbourne.vic.au
Re: SA63 - T Series to F Series Swap Over Sat, 30 April 2005 07:40 Go to previous messageGo to next message
So it wouldn't fit using the T Series Carrier Subframe holder Sad
Looks like I have to go back to the drawing board Sad
Cheers.
Mookie
Tassie
Re: SA63 - T Series to F Series Swap Over Sat, 30 April 2005 07:58 Go to previous messageGo to next message
no
i'm pretty sure it's just the thing that is bolted to the top of the diff.
it looks like a handle
Re: SA63 - T Series to F Series Swap Over Sat, 30 April 2005 10:01 Go to previous messageGo to next message
Finding a subframe will be easy enough Tim.
We are going to change over Franks T-series diff this coming week some time, so when we do we'll take some pics along the way.
See exactly what is different.
ZZT231
melbourne.vic.au
Re: SA63 - T Series to F Series Swap Over Sat, 30 April 2005 11:52 Go to previous messageGo to next message
CrUZsida wrote on Sat, 30 April 2005 20:01
Please do!, At Pick A part there is 2 F series Subframes but they are a bugger to remove! It was hard enough trying to track down a F Series Diff... Though First, I need to find a replacement intermediate drive shaft as well Nod
Cheers.
ZZT231
melbourne.vic.au
Re: SA63 - T Series to F Series Swap Over Sat, 30 April 2005 12:33 Go to previous messageGo to next message
Also can I use the SA63 drive shafts or do I have to change it to the MA61 drive shafts?
Cheers.
Stefan
Hobart, Tas
Re: SA63 - T Series to F Series Swap Over Sat, 30 April 2005 13:24 Go to previous messageGo to next message
Maybee ask some of the guys in the US at celicaGTS or the old celcia club. IIRC the early GTSs have T-series IRS rear ends which commonly get swapped for F-series ones, so they should know all the interchangeabiluty details.
(FWIW I'm looking for some disc rear swingarms to convert my RA65, though I already have an F-series diff Razz)
ZZT231
melbourne.vic.au
Re: SA63 - T Series to F Series Swap Over Sat, 30 April 2005 22:16 Go to previous messageGo to next message
I'm just too lazy and don't want to spend the money converting the SA63 to disc as it may be taken off the road in the next year or so... I just want to bolt on stuff so I can get to and from work as the MA61 is worse the porcelain doll sitting on a truck motor...
Cheers.
setsuna
Re: SA63 - T Series to F Series Swap Over Sun, 01 May 2005 12:25 Go to previous messageGo to next message
also with the back suspension..
wheels have mega camber
this is celica suspension on the supra diff.
not sure if longer springs would help..
not looked into it much yet Smiley =
I can take some pictures of this mod if you like.
Stefan
Hobart, Tas
Re: SA63 - T Series to F Series Swap Over Sun, 01 May 2005 12:27 Go to previous messageGo to next message
setsuna wrote on Sun, 01 May 2005 22:25
Shouldn't make any difference - xA6x supra and xA6x IRS celica are essentially the saem from firewall back.
ZZT231
melbourne.vic.au
Re: SA63 - T Series to F Series Swap Over Sun, 01 May 2005 12:36 Go to previous messageGo to next message
The MA61 intermediate tailshaft is shorter then the SA63 Mad
Do i need to change the propeller shaft from the center bearing to the back of the car? Or is it OK when bolting up the F Series Diff?
Cheers.
Mookie
Tassie
Re: SA63 - T Series to F Series Swap Over Sun, 01 May 2005 16:26 Go to previous messageGo to next message
I'd assume they would both be the same ?
Re: SA63 - T Series to F Series Swap Over Mon, 02 May 2005 00:12 Go to previous message
It's quite possible the T series diff has a shorter pinion than the F series. If this is the case you will need to swap the rear section of the tailshaft.
FWIW I'm selling a pair of MA61 trailing arms with brakes etc, so if anyone wants em to upgrade a Celica let me know. Note they're heavy bastards so shipping interstate probably isn't an option.
Previous Topic:[AE86] DIY exhaust system (not really, more of a pick it yourself)
Next Topic:2tg questions
Current Time: Thu Oct 29 13:51:36 UTC 2026
Total time taken to generate the page: 0.041722059249878 seconds
