Toymods » Tech & Conversions » Engine Light
sicsx
Engine Light Tue, 19 November 2002 06:46 Go to next message
Hey Guys..
Just a question in regards to my engine light coming on.. Basiclly when my engine hits a certain tempreture (about half on the Temp gauge) my engine warning light comes on.. Would it have something to do with the temp or is it something else??
Sicsx
haggis
Re: Engine Light Tue, 19 November 2002 08:41 Go to previous messageGo to next message
More info needed.
What car and what year?
Craig.
juzzo84
Hornsby, N.S.W
Re: Engine Light Tue, 19 November 2002 10:27 Go to previous messageGo to next message
if it is a sx corolla you are reffering to, then i may be able to help you, but as the previous said, more info required.
CHEERS
JUZZO
sicsx
Re: Engine Light Tue, 19 November 2002 22:42 Go to previous messageGo to next message
Sorry guys i forgot the most important bit.. its a AE92 SX rolla but with a 4agze transplant...
Sicsx
sicsx
Re: Engine Light Tue, 19 November 2002 22:43 Go to previous messageGo to next message
ooppss
[Updated on: Tue, 19 November 2002 22:44]
haggis
Re: Engine Light Tue, 19 November 2002 22:52 Go to previous messageGo to next message
Ah ha!
Now as it is a GZE implant, i assume you are running the computer for that engine. If the engine light has come on, the engine computer may have logged an error code. Do a search both here and on the web in general, and you should be able to get the info you need to read an error code from the computer and thus find what the problem is.
Mind u, i am assuming a few things with this, so if id doesnt sound right, let us know a few more details about the set up of the engine and wiring loom.
Hope that helps!
Craig.
sicsx
Re: Engine Light Wed, 20 November 2002 01:07 Go to previous messageGo to next message
Thanks Craig
Yea i have a standard GZE computer.. and all normal loom
Sicsx
sicsx
Re: Engine Light Wed, 20 November 2002 22:38 Go to previous messageGo to next message
Ok guys i've done the test and engine codes 4 - Water temp sensor came up.. which is now sorted as i found my thermo fan was spinning the wrong way and making it heat up and now runs nice and cool.., and 43 - Starter signal, no starter signal until engine speed exeeds 800RPM, but i have no solution for this one any idea's??
Sicsx
haggis
Re: Engine Light Thu, 21 November 2002 02:54 Go to previous messageGo to next message
Odd, seeing as the car obviously starts....
Clear the error codes, and see if that code appears again. Some times errors are triggered due to another error in that there is only a problem at point B if there is a problem at point A. Fix A and B will no longer happen.
*shrug* at least if you can get the error code to reappear, you know it is a seperate issue.
Craig.
sicsx
Re: Engine Light Thu, 21 November 2002 04:00 Go to previous message
Hey Craig
Yea i did this last night... it reset the water temp one.. but then that one came back.. i'll try again.. leave the battery off for a while longer
Chris
[Updated on: Thu, 21 November 2002 04:01]
Previous Topic:Engine mounts in a AE93
Next Topic:Attention: Lucan B.
Current Time: Wed Nov 11 17:40:45 UTC 2026
Total time taken to generate the page: 0.015794038772583 seconds
