Toymods » Tech & Conversions » Replacing camshaft seals?
HighRolla
Replacing camshaft seals? Sat, 30 April 2005 10:09 Go to next message
Do you have to take off the rocker cover for this? To undo the camshaft bolt and retorque it etc do you need to secure it by taking off the rocker cover so you can get to a section of the camshaft you can grip.
Its for a nissan motor that has a bit of plumbing over the top that I was hoping I wouldn't have to touch at the moment so it would be one less thing I have to do when changing the timing belt etc.
STR8 2.8
Re: Replacing camshaft seals? Sat, 30 April 2005 11:52 Go to previous message
yes you will need to remove the rocker cover.
you might as well do the timing belt at the same time.
Previous Topic:CA18DET+AE86 help!
Next Topic:sr20det fwd into ae92 rolla is it possible ????
Current Time: Fri Nov 20 23:12:05 UTC 2026
Total time taken to generate the page: 0.031499862670898 seconds
