Toymods » General Car Talk » prepping a car for long term storage ???
prepping a car for long term storage ??? Sat, 30 April 2005 11:47 Go to next message
so.. cars are going under the house for a couple of years..
plan is to try and preserve them a bit.
fishoil.. in sills, seams etc? what brands are good? aerosol or tin?
give car a good clean (remove dirt mud etc) and then just polish? any other surface treatments?
ae86drift
sydney.au
Re: prepping a car for long term storage ??? Sat, 30 April 2005 11:52 Go to previous messageGo to next message
fish oil
wash polish and was twice
close aircon vents and tape em up if you got bugs around
carcover
park on runoff concrete if possible
Re: prepping a car for long term storage ??? Sat, 30 April 2005 11:55 Go to previous messageGo to next message
air con? whats aircon Wink Razz
car will be inside a garage, so no bugs or car cover... mostly just trying to prevent corrosion etc..
monkeymajik
Re: prepping a car for long term storage ??? Sat, 30 April 2005 14:18 Go to previous messageGo to next message
Maybe drain out the brake fluid.
SIMDOG
Bayside Melbourne.
Re: prepping a car for long term storage ??? Sat, 30 April 2005 14:32 Go to previous messageGo to next message
monkeymajik wrote on Sun, 01 May 2005 00:18
And leave a little note on the steering wheel to remind you in a couple of years time that you had done that so you don't go driving with no brakes. Wink
[Updated on: Sat, 30 April 2005 14:33]
Re: prepping a car for long term storage ??? Sat, 30 April 2005 15:42 Go to previous messageGo to next message
LOL Laughing cars will be rebuilt mechanically before use, so it's more body oriented....
hmmm...might be good to remove DRUM brakes anyway Wink more of an incentive to change them later...
anyone have any suggestions as to brands? or are they all much of a muchness?
Toobs
Re: prepping a car for long term storage ??? Sun, 01 May 2005 02:12 Go to previous messageGo to next message
Put a trickle charger on the battery and leave the battery connected.
Maybe leave your interior light on or something so that there is still power running through the body.
If you take the battery out the car will rust 10 times as fast as the battery and current passing through the chassis helps to slow down the rusting process.
JoELMaN
March 2005
Re: prepping a car for long term storage ??? Sun, 01 May 2005 08:33 Go to previous messageGo to next message
fish oils the go, make sure ya cars dry and clean though or you'll trap the water and dirt in
my dad puts it on his mg midget every few years, god it stinks!Razz
unforgiven
February 2005
Re: prepping a car for long term storage ??? Sun, 01 May 2005 08:48 Go to previous messageGo to next message
Why are you puttin the cars under the house for a couple of years?
Lucid
Toymods Club Secretary
Re: prepping a car for long term storage ??? Sun, 01 May 2005 09:06 Go to previous messageGo to next message
unforgiven wrote on Sun, 01 May 2005 18:48
What.. You've never done it?
Hey Stuart, have a bit of a search around the forums. I think Gold28 was asking similar questions a little while ago, and there may be some other good replies in there.
There has been at least one other thread about this that I remember seeing before, but can't remember who posted that one sorry..
brett_celicacoupe
townsville NQLD
Re: prepping a car for long term storage ??? Sun, 01 May 2005 11:02 Go to previous messageGo to next message
lanolin based oil
from a spray pack is good, ie. lanox, lanoguard etc
it is very good stuff for preventing corrosion
commonly used to prevent bores, crank etc, rusting
Re: prepping a car for long term storage ??? Sun, 01 May 2005 11:04 Go to previous messageGo to next message
it might pay to ask the RACQ (NRMA in NSW?) how they do their long-term storage as they have it down to a fine art...
this is what i know to do...
-clean car thoroughly, borrow a cheap pressure spray to get rid of all dirt-n-shit - repair any paint removal before moving to step b Wink
-car on blocks to keep weight of tyres/suspension parts
-fuel tank near full
-coolant system flushed and coolant replaced with anti-corrosion coolant
-dont know about oil??
-i thought RACQ removed the battery, kept it on trickle then started the car with it once a month - but Toobs suggestion is at odds with that
-run the car once a month to keep oil/coolent in circulation and to prevent belts/hoses from going brittle - rotate tyres as well if able otherwise excess rust will build up
-cockroach and insect baits thru-out car, tape up air inlets/outlets
-if under the house, then wrap with a car cover (with some stand-offs to keep material off the paint) then cover that with a tarp, either way you need it to breath to allow moisture to escape but prevent excess dust/moisture finding its way in - a car-shade things might make this easy using it like an indoor tent
-make any cover easy to remove and not prone to flapping about in heavy winds
-replace brake/clutch fluids before storage and have persons looking after car work the pedals when doing the monthly 'turn-over' of the engine
-drain the windscreen sprayer bottle and any attached lines, cover all openings
-fisholene and lanoguard come in spray cans - helps with getting up in to sills, behind bumper bars, under battery shelf, etc
-inox (spell?) have a lubricant/grease spray that stays workable in extreme environments - spary over suspension and drivetrain parts that have a join to a wearing face (e.g. uni joints, ball joints)
-if not intending to rotate tyres, then also cover brake parts in some kind of lube/grease spray
-spray hoses/piping in the engine bay with some kind of silicon protector to help stop hoses perishing or going brittle
-see above point for window/door rubbers and dashboard
shcao
Re: prepping a car for long term storage ??? Sun, 01 May 2005 12:56 Go to previous messageGo to next message
The delorean on Back to the future didn't need these things done when it was kept in storage.
hmmm
jackel
Re: prepping a car for long term storage ??? Mon, 02 May 2005 14:56 Go to previous messageGo to next message
what about that stuff used in shoes to soak up moisture. Put around the inside of car. Would that do any good Confused
xolent
Re: prepping a car for long term storage ??? Mon, 02 May 2005 15:33 Go to previous messageGo to next message
jackel wrote on Tue, 03 May 2005 00:56
in that case, fill up your car with tampons and pads! Razz
SIMDOG
Bayside Melbourne.
Re: prepping a car for long term storage ??? Mon, 02 May 2005 16:49 Go to previous messageGo to next message
xolent wrote on Tue, 03 May 2005 01:33
Those stretchy ones they've been advertising recently could be used to stick over the aircon vents. Razz
jackel
Re: prepping a car for long term storage ??? Tue, 03 May 2005 04:37 Go to previous messageGo to next message
SIMDOG wrote on Tue, 03 May 2005 00:49
haha Razz Very Happy
Re: prepping a car for long term storage ??? Tue, 03 May 2005 05:22 Go to previous message
shcao wrote on Sun, 01 May 2005 20:56
hmmm
Thats because Deloreans don't rust.
Theres your answer Stu.
Rebuild the car in Stainless.
Previous Topic:hot one for ed
Next Topic:who bought a 4agze ae86 on tuesday?
Current Time: Sat Oct 17 12:01:23 UTC 2026
Total time taken to generate the page: 0.13016295433044 seconds
