Toymods » Tech & Conversions » Undoing crank pulley bolt??
HighRolla
Undoing crank pulley bolt?? Sat, 30 April 2005 13:04 Go to next message
IS the method of putting it in gear (5th) and putting the handbrake on (RWD car) a good method of undoing this bolt? Is it possible to stuff your gearbox, i.e. if the crank spins while it is in gear.
I know you can use the crank starter for split second but would rather try the 1st method...but don't want to hurt anything
LAA.80E
The realist ghetto area P...
April 2005
Re: Undoing crank pulley bolt?? Sat, 30 April 2005 13:10 Go to previous messageGo to next message
best way mate keep the car level on the ground all four wheel use5th and grab a rattle gun and rattle it out .. if you dont have one go down to your local mechanic ask him to loosen it with his gun but not to much so you can drive it home and finish it off with th rachet. but good luck pulling the harmonic off afta the bolt comes out!
[Updated on: Sat, 30 April 2005 13:11]
shinybluesteel
melbourne
Re: Undoing crank pulley bolt?? Sat, 30 April 2005 13:22 Go to previous messageGo to next message
do not drive your car home with a loose main pulley, lucky for you your local mechanic will just laugh at you if you ask him to do this, and then not do it.
i'd use the starter, after ensuring it will spin the right way, or by kicking a breaker bar in the method you mention.
there is no way it will damage your gearbox, as at the worst you will get clutch slip, which you get all the time anyway.
Re: Undoing crank pulley bolt?? Sat, 30 April 2005 13:24 Go to previous messageGo to next message
heh heh the number of times i've undone my pulley accidentally after leaving a spanner on it.... sheesh..
i'd go breaker bar and socket, with a few fast taps with lump hammer (ie get some inertia going)...
LAA.80E
April 2005
Re: Undoing crank pulley bolt?? Sat, 30 April 2005 13:29 Go to previous messageGo to next message
dont get my wrong i aint saying pull the bolt loose all the way just enough you could use a rachet and sum elbow grease to pull it off aint gunna harm nothing dun it million times wen i had no rattle gun no problems wat so ever just drive like a 60year old
LAA.80E
April 2005
Re: Undoing crank pulley bolt?? Sat, 30 April 2005 13:32 Go to previous messageGo to next message
using your starter is a bit of a butcher job mate, think bout it starter loosening a pulley bolt??!!! doesnt sink in my head at all would want the starter get stuck afta that or having problems....
HighRolla
Re: Undoing crank pulley bolt?? Sat, 30 April 2005 13:33 Go to previous messageGo to next message
Would the clutch slip before it broke the gearbox? So no chance of damage using 1st technique
So oldcorollas would you recommend putting it in gear and handbrake on then try and get it with long breaker bar...??
Thanks guys
[Updated on: Sat, 30 April 2005 13:34]
shinybluesteel
melbourne
Re: Undoing crank pulley bolt?? Sat, 30 April 2005 13:36 Go to previous messageGo to next message
of sourse it would, how many times have you broken a gearbox while driving? not many? thought so.
just buy a two dollar air compressor and a two dollar rattle gun from supercheap, they should last long enough to undo one bolt.
cri_ag
northern beaches
Re: Undoing crank pulley bolt?? Sun, 01 May 2005 01:22 Go to previous messageGo to next message
hmm i cracked mine the other night (engine out for rebuild, shove timber block inbetween block and crank was my solution) and then tried to remove the pulley. a mecaninic mate said to "just hit it" with a hammer but after a few taps i decided i wasent to keen on that idea. i suppose i need a puller of some description? (engine is 4age)
[Updated on: Sun, 01 May 2005 01:25]
boog
campbelltown
April 2005
Re: Undoing crank pulley bolt?? Sun, 01 May 2005 02:08 Go to previous messageGo to next message
just get a socket and crack bar put it against the body and crank it it will come loose i have done it millions of times in my workshop and never had any problems at all....... even when a rattle gun doesnt work this is what i do so you deside....
cri_ag
northern beaches
Re: Undoing crank pulley bolt?? Sun, 01 May 2005 02:20 Go to previous message
hmmm i was able to crack mine with a ratchet handle, about 250mm long! Rolling Eyes
Previous Topic:4agze problem
Next Topic:oil in t50 box
Current Time: Sat Nov 21 05:01:57 UTC 2026
Total time taken to generate the page: 0.0059189796447754 seconds
