Toymods » Tech & Conversions » wiring problems (ae86)
Ko Ko
icon5.gif  wiring problems (ae86) Sat, 30 April 2005 15:20 Go to next message
Hey all,
Today a friend of mine was trying to do something with my car since my reverse lights didnt work. He was playing wiring of the car a bit too see what was the problem and also with the fuse box in the engine bay.
Now when I turn my car on, the tachometer doesn't work either does the oil and temperature. However the speedo and fuel works..
I have looked through the car and cant seem to find any problem.... but on the other than I dont know shit about cars. Could anyone give me some advice on how to find the problem and fix it It would be much appreciated.
Eddy
FKN16V
NSW, East Coast
Re: wiring problems (ae86) Sun, 01 May 2005 00:42 Go to previous messageGo to next message
If your reverse lights arent workin there's a chance your globes blown or your reverse light connectors on the gearbox have fallen off.
Get under the drivers side and you'll see 2 connectors that should be connected.
Steve
chrisellis
Re: wiring problems (ae86) Sun, 01 May 2005 00:51 Go to previous messageGo to next message
note: those 2 little wires steve is talking about are on the side/top of the gearbox, u will be able to get to them from under the car.... but i thought it was the passenger side Rolling Eyes check both.
Ko Ko
Re: wiring problems (ae86) Sun, 01 May 2005 01:07 Go to previous messageGo to next message
Oh thanks guys,
Ill check under the gearbox... How about the tacho meter I was trying to find it and check the wires but nothing seems wrong? Anywhere to look at
Ko Ko
Re: wiring problems (ae86) Sun, 01 May 2005 01:24 Go to previous messageGo to next message
Fellows,
I check the gearbox and all and its on the passenger side.. Both reverse light connectors are wired up and all. Thought that this would be the problem since i just got my gearbox rebuilt but it doesnt seem to be.
My rear light bulbs arnt blown either. Anywhere i shouldlook?
d-shiznit
W.A
Re: wiring problems (ae86) Sun, 01 May 2005 15:51 Go to previous message
Find the wire coming out of the gearbox, this will be the reverse selector switch.
Locate the plug, should be 2-wires.
Disconnect it, and short out the wires on the loom side (not gbox side) Easiest to just stuff a bit of wire into one terminal, bend and stuff the other end into the adjacent terminal.
Turn ignition ON
Now your reverse lights should be lit!
If they are not, then the problem is in the wiring/bulbs.
If they are, then the problem is in the gearbox.
Hope this helps!
Previous Topic:Corolla swaybar? y/n
Next Topic:The Best Lock Nuts?
Current Time: Mon Nov 23 02:18:41 UTC 2026
Total time taken to generate the page: 0.0062730312347412 seconds
