Toymods » Tech & Conversions » differences in CT20b
Switch to threaded view of this topic Create a new topic
SXY184
differences in CT20b Sun, 01 May 2005 06:12 Go to next message
Hey all, jus a quick question, would the turbo (CT20b ) on a ST205 be the same as the one on the diesel surf engine the 2L. there both got CT20b on them , but the diesel one looks smaller,
i hav from memory a two or three at work , and jus wanna know if there the same or whats the differences?
Thanks !
YelloRolla
On your mum!
Re: differences in CT20b Sun, 01 May 2005 08:22 Go to previous messageGo to next message
count on them being different (a 2.0L diesel will not have the exhaust or intake volume of the ST205)
-==L=a=N=c=E==-
Brisbane, Queensland
Re: differences in CT20b Sun, 01 May 2005 09:20 Go to previous messageGo to next message
There is no such thing as a CT20B, its a internet nickname given to the 3rd revision CT26 available on the 3rd gen 3S-GTE.
It is by no means related to the CT20.
Hunty
Re: differences in CT20b Sun, 01 May 2005 10:29 Go to previous messageGo to next message
SXY184 wrote on Sun, 01 May 2005 15:42
so theres no such thing as a ct20b? curious, coz ive never heard of it being called anything else. the st185's/sw20 mr2 had the ct26 and the upgrade for the st205 and the 3rd gen mr2 sw20 was a new turbo with increased standard boost, i think it was uped from like 10 to 13 on the mr2's not sure bout the sillycars. Or i culd be completely wrong....
davedave
Re: differences in CT20b Sun, 01 May 2005 20:07 Go to previous messageGo to next message
What lance says is correct, it's just an internet nickname and bares no relation to the CT20.
As you can see in the following two pictures, the first is a clearly labelled gen2 CT26. And the second is the 'CT20B' which only has Toyota marked on it.
http://home.swiftdsl.com.au/~mk15/index.php?image= IMGP1253_ 800.jpg
http://home.swiftdsl.com.au/~mk15/index.php?image= IMGP1719_ edit.jpg
[Updated on: Mon, 02 May 2005 06:41]
ralfross
On Probation
April 2005
Re: differences in CT20b Sun, 01 May 2005 21:12 Go to previous messageGo to next message
ct20 is the name of the turbo. No 'b' after. If you go to toyota they can look uo the ct20 on their computer sustem.
Ct20 is a beter turbo for a near stamdard gen 2 3sgte.
I has a larger exhust housing and is slightly larger. It can compress more air and hold hihger boost far more efficiently.
Re: differences in CT20b Mon, 02 May 2005 00:09 Go to previous messageGo to next message
Toyota seems to have about a dozen turbos called CT20 which are totally different to each other. Even my 2JZ-GTE has CT20A turbos, and they look nothing like the CT20's on 3T-GTE's or old diesels.
JustenGT4
Re: differences in CT20b Mon, 02 May 2005 03:03 Go to previous messageGo to next message
There is a lot of confusion about the turbo on the Gen III 3SGTE but i have only ever heard of it referred to as the CT20B and we are talking from a long time ago now.....8-10 years.
As long as everyone knows what you are referring to then that's all that really matters...particularly as there doesn't appear to be any other designation for this turbo.
As for it being a different beast to the Surf turbo, most definitely.
YelloRolla
On your mum!
Re: differences in CT20b Mon, 02 May 2005 03:14 Go to previous messageGo to next message
ralfross wrote on Mon, 02 May 2005 07:12
I think that you are on your own with this statement.
As JustenGT4 has pointed out; there needs to be clear differences in the naming of the turbos.
If you go into a wrecking yard and ask for a CT20 turbo, then what you will get is not guaranteed.
JustenGT4
Re: differences in CT20b Mon, 02 May 2005 03:55 Go to previous messageGo to next message
I don't know where Ralfross gets his "info" but i can safely say that he's usually so far off the money that it's almost better to do the opposite of any of his advice Smile
As most of you know the CT20 is a boat anchor masquarading as a turbo Smile
As for the CT20B it has a SMALLER a/r turbine housing than the CT26. It has a large compressor wheel inside what effectively amounts to a machined out CT26 front cover.
A great combo turbo using toyota bits is to use the CT26 turbine housing and bearing section and have a CT20B comp wheel bored out to bolt onto the larger CT26 shaft. You also need to machine the CT26 backplate slightly. The CT20B front cover just goes straight on with no mods. This "hybrid" turbo gives you the best of both worlds when it comes to toyota turbos and has been proven to be good for 350+ flywheel HP.
I had a hybrid made up for my GrpA and was happy with the results on 19psi. If i hadn't done the HG at Wakefield Park and gone crazy in the rebuild i would have just stayed with that turbo.
ralfross
On Probation
April 2005
Re: differences in CT20b Mon, 02 May 2005 12:23 Go to previous messageGo to next message
I call it the ct20b too. For reference reasons.
It is a beter turbo than a ct26 stock for stock.
I am correct about the ct20 having a larger exhaust housing and compressor wheel.
Ct26: 1.574"
ct20b: 1.88"
http://www.alltrac.net/tuning/turbo.html
[Updated on: Mon, 02 May 2005 12:27]
JustenGT4
Re: differences in CT20b Mon, 02 May 2005 23:07 Go to previous messageGo to next message
Once again Ralfo you are totally off the mark...do you even know one end of a turbo from the other???
Those numbers are for the comp wheel NOT the turbine wheel. The comp wheel is larger as i said....the turbine wheel is so close in size not to make any difference but it is more heavily shrouded in the name of faster spool up time and from what i could measure (a difficult task) is a smaller a/r. The CT26 definitely has a better flowing hot side.
ralfross
On Probation
April 2005
Re: differences in CT20b Mon, 02 May 2005 23:20 Go to previous messageGo to next message
only tried to help.
Dont see where im wrong though. IMO the ct26 is not beter than the ct20b unless it is high flowed. My ct26 has bee modified slightly so it can hold more boost. I have had garret put a loarger compressor wheel in.
Now. The Ct26 has a smaller compressor to the ct20b on the 3sgte anyway.
by the way im not talking about the turbine wheel.
[Updated on: Mon, 02 May 2005 23:24]
JustenGT4
Re: differences in CT20b Mon, 02 May 2005 23:24 Go to previous messageGo to next message
You can think whatever you like. You are getting info 2nd hand off the web and on top of that you are interpreting it incorrectly.
I have had the 2 turbos side by side on my bench, pulled them both down and put together a Hybrid using the best bits of both.
ralfross
On Probation
April 2005
Re: differences in CT20b Mon, 02 May 2005 23:34 Go to previous messageGo to next message
www.gt4oc.com These guys know what they are talking about.
I will almost only listen to them.
Joshstix
Toymods Vice President
Re: differences in CT20b Tue, 03 May 2005 03:38 Go to previous messageGo to next message
Please if you only plan to listen to them then only spout their rubbish on their forum. Here we are far more interested in reality than rubbish theories that are never proven.
The problem is that you have no actual knowledge you just repeat what you are reading. This is where the misinformation comes from. What makes you think that the peoplc on gt4oc actually know about the topic and aren't just repreating incorrect information the same way that you have been ever since you signed up for this forum?
If you have legitimate information not just stuff you read on the net or heard off a mate then feel free to share it. If however you talk rubbish and then try and defend that rubbish as being correct then expect to get shot down.
Re: differences in CT20b Tue, 03 May 2005 04:58 Go to previous messageGo to next message
JustenGT4 wrote on Tue, 03 May 2005 09:24
ralfross wrote on Tue, 03 May 2005 09:34
Rolling Eyes Rolling Eyes Rolling Eyes
JustenGT4
Re: differences in CT20b Tue, 03 May 2005 05:10 Go to previous messageGo to next message
That might be just a bit too subtle to sink in Norbie Wink
Your thread seems to have been hijacked a tad SXY184...happy enough that your orig question been answered ?
SXY184
Re: differences in CT20b Tue, 03 May 2005 09:02 Go to previous messageGo to next message
Hey Hey, is all good JustenGT4...hey that means i get to PM u for info .. Cool Hope that is ok , everyone has there opinions and they look like they tend to vary from peeps being shot down and grilled to the guys who actually know what doing ...they say experience is the best teacher...and if u dont know (like i didnt when i started this post) then jus ask!! thanks to all that replyed, oh and Ralfross, plz man u seem cool in person , jus dont believe everything u read,im not sayin your source of info is wrong , but im not sayin it right either !!
Cheers ~Richie~
CLG
Perth, Western Australia
Re: differences in CT20b Wed, 04 May 2005 05:40 Go to previous messageGo to next message
JustenGT4 wrote on Tue, 03 May 2005 13:10
Heheheheheheeee!
I'm currently putting a mongelised CT26 together for my ST185, I'll fully list all mods and power output in a new thread once it's done - I'd suggest everyone else with 3SGTE's/GT4's does too - we can then a have a good representative look at cause and effects with various mods.
ralfross
On Probation
April 2005
Re: differences in CT20b Wed, 04 May 2005 11:44 Go to previous messageGo to next message
You wont listen to me becuase me reputation is fucked. But for what it is worth dont go too nuts on high flowing the ct26.
GCG turbos did my 2nd turbo after it blew and made it too big. I wasnt expecting them to repair it like they did. I was really disapointed with its performance. It was useless untill nearly 5000RPM.
I took it off and replaced it with the current, slightly modified turbo and i am v happy with it. Garret put it together for me using their internals. They only reused my housing.
If you want to me to get its specs i will (if you listen to me, which i doubt.)
OK NOW EVERYONE CAN SHOOT ME DOWN!
[Updated on: Wed, 04 May 2005 11:45]
CLG
Re: differences in CT20b Wed, 04 May 2005 12:04 Go to previous messageGo to next message
Thanks for your offer, but I'm listening to my turbo builder, and one or two select individuals that I've met personally, both here in Perth, and over east too. Fortunately for us Perthites, the car culture is completely different over here, and a turbo that doesn't spool till 5000rpm, is a very very rare beast on the street!
ralfross
On Probation
April 2005
Re: differences in CT20b Wed, 04 May 2005 12:38 Go to previous messageGo to next message
yeah it was no good. GCG did a good job a fixing it but no good at matching the application.
Would of be good for a drag celica.
On the other hand garet couldnt of done a beter job.
Anyway good luck with it.
[Updated on: Wed, 04 May 2005 12:40]
ed_ma61
Lost in the K hole
Re: differences in CT20b Wed, 04 May 2005 12:43 Go to previous message
ok, that seems like a nice place t end this Nod
folks might want to take a look at this:
http://forums.toymods.org.au/index.php?t=msg&t h=28502&start=0&rid=92&S=27ae3290af05a 5aa40370c72e8457f23
* PLEASE do not simply regurgitate what you've overheard or read somewhere else, and call it your 'expert' contribution to a thread. Posts like this simply propagate misinformation. If you think you can refer someone to relevant web resources, by all means do so, but please do not make an independent 'statement of fact' about an issue unless you can substantiate it.
Previous Topic:2tg builders in Melbourne
Next Topic:1JZ auto, manual shifting
Current Time: Sat Oct 24 08:30:38 UTC 2026
Total time taken to generate the page: 0.008375883102417 seconds
