Toymods » Tech & Conversions » 4agze to 4agte
tankrolla
cranbourne
April 2005
4agze to 4agte Sun, 01 May 2005 09:08 Go to next message
i have just bourght a 4agze and i think it gose good but not that good if i was to change it to a turbo would the computer be able to handel it, how much cost and would the power increse be that much more.ill be able to do it a bit cheaper because im a bolier maker so i can make my own manifold maybe.is the power increse worth it or do i just change the pully to a blitz i was told they will increse it to about 12-13psi and the motor will be fine with that has anyone done the conversion?
Sprinter
Re: 4agze to 4agte Sun, 01 May 2005 10:26 Go to previous messageGo to next message
Before somebody says "Have you tried using search?" ...
Try using some punctuation and the Enter key.
Yes the factory ecu will work with a 4AGTE safely up to 12-13psi (mine has done 12.5).
I had a cusco pulley with the ZE and put down 106rwkw. I am expecting to put down at least 120rwkw with the TE on less boost.
Cost is a it depends answer - plan it properly and work out how much you can do yourself. Use search, here and google.
Research the turbo manifold designs if you can make your own. There are a lot pictures available on the web. I recommend reading through the posts on here - http://www.mr2oc.com
Having done the conversion from ZE to TE I think its a worthwhile conversion but keep an eye on the costs.
Oh - and have you tried using search yet? Smile
Denis
Lucid
Toymods Club Secretary
Re: 4agze to 4agte Sun, 01 May 2005 22:58 Go to previous messageGo to next message
First of all, go to www.toymods.org.au click on Articles on the left hand side, and scroll down to 4A-GTE.
Then try going to the FAQ's :: Please Check Here Before Posting thread at the top of this Tech Section, and reading through the info there on 4A turbo conversions.
Once you've read and learned everything that you can, if you still have questions then this is the place for them Smile
fatmr2
Re: 4agze to 4agte Mon, 02 May 2005 01:09 Go to previous messageGo to next message
Ive just recently done a gte and mine goes alright. All depends on how much you want to spend and how fast you want to go....?
.wolfwood
Gold Coast
February 2005
Re: 4agze to 4agte Mon, 02 May 2005 02:20 Go to previous message
just a question, for the better ecu is the microtech MT-8 good or is better to spend the extra money to and get the microtech LT-8?
im in the same situation as posted above, i have 4agze into 4agte. any help would be a great help, thanks ben
Previous Topic:grippier clutch disc for E58 gearbox - low cost or wont work?
Next Topic:[AE86] DIY exhaust system (not really, more of a pick it yourself)
Current Time: Wed Oct 28 17:04:55 UTC 2026
Total time taken to generate the page: 0.0096790790557861 seconds
