Toymods » Tech & Conversions » RSM installation on st184
agent_felix
bendigo, VIC
RSM installation on st184 Sun, 01 May 2005 11:13 Go to next message
has anyone done this and can anyone tell me how i can install mine??
i know theres a wiring diagram and that but i dont know which cable is which....
-==L=a=N=c=E==-
Brisbane, Queensland
Re: RSM installation on st184 Sun, 01 May 2005 11:41 Go to previous messageGo to next message
http://www.apexi.com/pdfInstallation/14.pdf
download, read, understand.
All the info you need is there.
agent_felix
bendigo, VIC
Re: RSM installation on st184 Mon, 02 May 2005 03:40 Go to previous messageGo to next message
only for 3sgte and 3sge... not 5sfe in a 184...
and i was also asking how i can get to the ecu as its like behind the console...
-==L=a=N=c=E==-
Re: RSM installation on st184 Mon, 02 May 2005 03:50 Go to previous messageGo to next message
The ecu can be unbolted from behind the console, crawl under the passenger side dash, and u'll find the ecu sticking up behind there. 2 10mm bolts hold it in. You shouldn't need to remove it, you only need to play with the engine loom.
As for wires, there are only 3 the RSM needs (from memory)
Power, Ground and Speed.
http://www.mr2-tech.com/bgb/electrical/volume1/ele ctrical_wiring_diagrams/7.htm
Have a look at that, thats a 5sfe diagram (a bit small)
Have a look and u'll find the speed wire sensor.
(hint, its pin 12 on plug A)
[Updated on: Mon, 02 May 2005 21:07]
agent_felix
bendigo, VIC
Re: RSM installation on st184 Mon, 02 May 2005 13:32 Go to previous messageGo to next message
i gotta attach the rev as well, does anyone know if the 5sfe ecu actually gives live data so it will work? or only the 3sgte... although the mr2's are listed in there...
-==L=a=N=c=E==-
Re: RSM installation on st184 Mon, 02 May 2005 21:08 Go to previous messageGo to next message
agent_felix wrote on Mon, 02 May 2005 23:32
the MR2 5SFE is the same as the ST184 5SFE wiring wise.
agent_felix
bendigo, VIC
Re: RSM installation on st184 Tue, 03 May 2005 09:23 Go to previous messageGo to next message
ok, the diagram was for a 3sgte, now i have found an ecu map for a 5sfe and it has no tacho wire... as it needs the rev part;-...
Toobs
Re: RSM installation on st184 Tue, 03 May 2005 11:40 Go to previous messageGo to next message
Tacho = IGT.
Its there... seriously.
agent_felix
bendigo, VIC
Re: RSM installation on st184 Tue, 03 May 2005 13:20 Go to previous messageGo to next message
i know im an uber noob at this type of thing... i have never played with this part before... only the audio type which, compared, is piss easy.
-==L=a=N=c=E==-
Re: RSM installation on st184 Tue, 03 May 2005 21:31 Go to previous messageGo to next message
Mate all you have to do is look at the diagram, i know its crap but you can still make out what pin and plug its on.
Plug B Pin 6.
dirk_diggler
May 2005
Re: RSM installation on st184 Mon, 30 May 2005 10:56 Go to previous message
Hey, im so glad i stumbled accross this. i just bought an rsm y'day and too needed the wiring diagram for a st184. just to confirm, speed was plug A pin 12 and revs was plug B pin 6?
Also. where is the ECU? under passenger dash/ behind glovebox?? and do i take off where the clear/yellowy plastic cover is?
hope u understand.. hope u can help.
Previous Topic:W50 or W58
Next Topic:Idle gone crazy!
Current Time: Thu Oct 22 10:52:36 UTC 2026
Total time taken to generate the page: 0.009009838104248 seconds
