Toymods » Tech & Conversions » Main seal in 4age
sonwill
Lara, Vic
February 2005
Main seal in 4age Mon, 02 May 2005 07:12 Go to next message
Hi I have got the 4age in my AE82 finally. It is going great! it is using a fair bit of oil and I am not sure where it is going!
Have done a comp check, and it passed with flying colours, it doesn't put it out the exhaust at start up or after idle and it isn't dripping on the ground.
All I can think is that it is the main seal behind the flywheel. What do you think? how hard is the main seal to replace, (pull off the sump and main bearing or does it just go around the output shaft??) also the clutch shudders on take off, that is why I am thinking it is the seal.
4agte
Toronto, Downtown
Re: Main seal in 4age Mon, 02 May 2005 07:16 Go to previous messageGo to next message
i know the front main seal is easy to replace. The main seals are a common place for the twinkies to leak
TerryOBeirne
Redbank Plains,near Ipswi...
Re: Main seal in 4age Mon, 02 May 2005 08:22 Go to previous messageGo to next message
you dont have to remove the sump or the main cap. just remove the flywheel and hey-presto, there is the seal. the housing has 6 bolts. a juddering clutch usually indactes its warped from overheating. get the flywheeel machined when off.
sonwill
Lara, Vic
February 2005
Re: Main seal in 4age Mon, 02 May 2005 22:35 Go to previous messageGo to next message
Thanks heaps. How difficult is it to drop the box whilst it is in the car? anything I should look out for when I am undoing bolts.
parrot
Re: Main seal in 4age Tue, 03 May 2005 03:38 Go to previous message
Easy, get the car up as high as you can and bear in mind it's a bit heavy. Don't drop it on the driveshafts.
Previous Topic:AE101 box VS AE92 box (differences in dimensions, flywheel etc)
Next Topic:3S FE front engine seal?
Current Time: Thu Nov 19 10:03:09 UTC 2026
Total time taken to generate the page: 0.0068330764770508 seconds
