Toymods » Tech & Conversions » 3T-GTEU into a KE70 Corolla
agp2002
Hobart
May 2005
3T-GTEU into a KE70 Corolla Mon, 02 May 2005 08:42 Go to next message
i hope i spelt it right, its the 1.8 litre turbo out of the jap spec celica. its meant to be a strong engine im told, how hard is it to fit this to the 1983 KE70 corolla??
If anyone has done it could the reply with tips or point me in the right direction. I got the front cut for a steal so i want to make use of it.
Iain
goonman86
deloraine tas
Re: 3T-GTEU into a KE70 Corolla Mon, 02 May 2005 09:02 Go to previous messageGo to next message
how did you get a 3tgte front cut? there hard to get now coz there so old ?????? was it from an import dealer
muaythaiman
Re: 3T-GTEU into a KE70 Corolla Mon, 02 May 2005 09:06 Go to previous messageGo to next message
wanna sell the half cut? It would be really really hard to install! Very Happy
jesseT18
Castle Hill, Sydney
Re: 3T-GTEU into a KE70 Corolla Mon, 02 May 2005 09:21 Go to previous messageGo to next message
it will bolt in.
but im you would want to find out what car it is
i dont think any celicas came with 3tgte's
if it is a celica, ta22? it didnt come with rack and pinion.
so you will need to welf the T series engine mounts onto your K series crossmsmber to retain the rack mounts, or weld rack mounts onto the t crossmsber
that on top of your usual fuel, wireing and exhuast mods you get with engine conversions
September_Squall
Melbourne, Australia
March 2005
Re: 3T-GTEU into a KE70 Corolla Mon, 02 May 2005 10:47 Go to previous messageGo to next message
I just installed a T series motor to my KE70. It's not hard.
Issues:
Crossmember:
T motor will not bolt to K crossmember.
Crossmember mounts are different angle, different spacing, etc.
TE72 crossmember and engine brackets fits motor and chassis together.
Need to tack the KE70 rack mounts onto the TE72 crossmember.
Steering rack fouls the driver side engine-to-gearbox bracket, I removed it with no problems.
For 3T-GT an additional issue may lie in passenger side
Transmission:Need to use TE72 T50.
This transmission has the correct bellhousing, input shaft, and output shaft for the application.
Cannot use T50 from TA22 or AE86.
Need the gearbox crossmember for #E7# Corolla, ie. TE72, AE71.
Tailshaft:
KE70 or AE71 manual tailshaft fits for standard differential.
TE72 tailshaft fits for TE72 T series differential.
Radiator:
TE72 radiator will bolt in and put the top hose in the correct location for the T motor thermostat housing outlet. Use the KE70 radiator with come creative hoses in a pinch.
Induction:
My carburettors clear the booster and master cylinder. Will the injection manifold?
[Updated on: Mon, 02 May 2005 11:23]
jesseT18
Castle Hill, Sydney
Re: 3T-GTEU into a KE70 Corolla Mon, 02 May 2005 10:53 Go to previous messageGo to next message
september, do you have much clearance between sump and drivers side rack bracket? mine is slightly touching, but thats a 3tc sump not a 3tgte, they may be diffferent?
September_Squall
March 2005
Re: 3T-GTEU into a KE70 Corolla Mon, 02 May 2005 11:25 Go to previous messageGo to next message
I've got some clearance. I'll try to get some photos. It's a 2T-G, and a standard sump I think. If you want one, I've got a couple spare.
jesseT18
Castle Hill, Sydney
Re: 3T-GTEU into a KE70 Corolla Mon, 02 May 2005 12:36 Go to previous messageGo to next message
hmmm maybe 2tg sump is different than? im using 3tc, im just going to bash in the sump with a hammer tomorrow but im going to weld in baffles to a different sump soon and swop em over, might use a 2tg one if it clears the rack
pheonix83
Devonport Tasmania
Re: 3T-GTEU into a KE70 Corolla Mon, 02 May 2005 23:48 Go to previous messageGo to next message
First problem.
Changing the crossmember from a t18.
Second problem.
Steering Clearances with the sump.
Third problem.
Diff will die very quick, VERY QUICK
Fourth Problem.
Need to make a new tailshaft up.
Fifth problem.
Brakes will need to be upgraded to be roadworthy and safe, not just for you, but other drivers on the road.
Sixth Problem.
Complete fuel system upgrade reqd.
New Bigger fuel lines, a return line installed.
Surge Tank, or baffled Original Tank.
High and low Pressure fuel pumps.
Seventh Problem.
Convert car to hydraulic Cluth.
Potential Eighth Problem.
Depending on which gearbox it came with, you may need to cut a new shifter hole in your floor.
This gives u a little idea whats involved, if u cant do most of this in your own or a mates garage, then it will be an expensive and probably silly venture.
Im doing the same setup into a KE35 coupe, so i do know what im talking about.
Also Are u sure its a 3tgte and not a 3sgte, cause the 3tgte didnt come out in celicas, Carinas it did.
If it has 8 spark plugs then its a 3tgte.
September_Squall
March 2005
Re: 3T-GTEU into a KE70 Corolla Tue, 03 May 2005 02:50 Go to previous messageGo to next message
Concur with phoenix83 on most points. If using a
TE72 T50 the shifter will emerge in the correct location. 3T-GTEU did come out in Celicas; TA6# to be specific.
pheonix83
Devonport Tasmania
Re: 3T-GTEU into a KE70 Corolla Tue, 03 May 2005 06:12 Go to previous messageGo to next message
ok, there u go, didnt know they came out in celicas, i stand corrected.
Re: 3T-GTEU into a KE70 Corolla Tue, 03 May 2005 06:21 Go to previous message
Yeah my 3tgte frontcut was a TA63 Celica.
Previous Topic:Info about 1uz-fe
Next Topic:turbo charging a 3sge
Current Time: Wed Oct 14 06:37:47 UTC 2026
Total time taken to generate the page: 0.11748695373535 seconds
