Toymods » Tech & Conversions » quad throttles on 4agze
sc_rolla
fremantle
quad throttles on 4agze Mon, 02 May 2005 09:28 Go to next message
I wanna know has anyone put on quad throttles on 4agze
can it be done and is it worth it wat is the approx power gain
EVOSTi
cambo
      no
Re: quad throttles on 4agze Mon, 02 May 2005 10:11 Go to previous messageGo to next message
no it cant really be done easily, dont bother.
sc_rolla
fremantle
Re: quad throttles on 4agze Mon, 02 May 2005 11:53 Go to previous messageGo to next message
thx for that, guess i ll just save up for a turbo
bayka
perth
Re: quad throttles on 4agze Mon, 02 May 2005 16:04 Go to previous messageGo to next message
quad throttle 4AGZE does have a nice ring to it though Smile
Wouldn't it be completely ineffective because each cylinder is receiving air at higher than atmosphere pressure anyway?
Like you definatley couldn't have the individual thottle butterflies "after" the air has been pressurized...
bayka
perth
Re: quad throttles on 4agze Mon, 02 May 2005 16:05 Go to previous messageGo to next message
sorry im just a retard, the pulsar GTIR does it...anyone know how it works in a forced induction environment?
smitty1
Re: quad throttles on 4agze Mon, 02 May 2005 19:54 Go to previous messageGo to next message
There was the yellow ke26 wagon with the 4agte with water to air intercooler on top of the rocker covers running into quad throttles. It is on boostedperformance.co.nz
Ian
ra_28
Re: quad throttles on 4agze Mon, 02 May 2005 23:45 Go to previous messageGo to next message
Having forced induction through quad throttles is possible i have been looking in to it for the 18rgetu.
ed_ma61
Lost in the K hole
Re: quad throttles on 4agze Mon, 02 May 2005 23:52 Go to previous messageGo to next message
you chumps Laughing
practically all turbo engines have a throttle body on the pressurised side of an intake system... wtf difference does that make?
4 throttle plates only gives throttle response and midrange, has SFA to do with peak power output (infact will likely decrease it)
as for any famous multi throtle turbo engine, errrmm, hows about the rb26 ??
nick.parker
January 2005
Re: quad throttles on 4agze Tue, 03 May 2005 00:53 Go to previous messageGo to next message
I guess the short answer is 'you can do it', BUT you'll need a decent size bypass valve, and it'll be a fuel waster due to the extra 'drag' on the engine of pumping air out of the bypass most of the time - it'll probably be continually noisey (read on).
Consider that even at idle the ZE supercharger system is capable of making boost, so if the throttle was after the SC youd have to be continually venting HEAPS of air - what an inefficient use of engine power! Consider everyday driving, with the engine at 4000rpm, just before a shift or the engine at high revs, with a big pulley too the SC is pumping enough air to make 12 psi or something...thats got to be noisey having that air pumped out continuously through a bypass valve!
On the bright side if you like jet planes, I guess your car might sound like one.
Nick
'87 SC
drift86levin
brisvegas
Re: quad throttles on 4agze Tue, 03 May 2005 00:57 Go to previous message
you would have to work backwards..no tb on the supercharger, and all 4 of them hanging off the head..then you have to work out how to do the bypass valve.. Sad
with a turbo set up, i think it would be good Smile but more of a wank factor than anything..
Previous Topic:Intake Plenum Conversion on 3s-ge
Next Topic:Identifying this turbocharger
Current Time: Thu Nov 19 07:42:21 UTC 2026
Total time taken to generate the page: 0.0077030658721924 seconds
