Toymods » Tech & Conversions » anyone with running rich probs
sideshow
anyone with running rich probs Mon, 02 May 2005 11:06 Go to next message
just to let everyone know
i had to go fix a car today
fukin checked everything on the ecu
nothin was faulty but car ran like shit
what i eventually found was hose goin form turbo to intake had popped off due to shit load of oil around house and hose was perished badly
this cause the engine to run rich and not idle etc
i think half the probs of peoples cars runnin rich is due to this
mind u the hose was not easy to see
it was a 7m gte in a soarer
so underneath its hard to see
but if anyone ever has rich problemns check for vac leaks
im goin to invest in a smoke machine to help me diagnose these problems easier
its best to double and tripple check yr hoses properly
[Updated on: Mon, 02 May 2005 11:08]
Fr3aK
Wollongong
January 2005
Re: anyone with running rich probs Mon, 02 May 2005 11:53 Go to previous messageGo to next message
yeah, i think the hose came off my turbo too. Crying or Very Sad
http://img.photobucket.com/albums/v705/fr_3_ak/Extractorsondyno.jpg
Kyosho
Wollongong
Re: anyone with running rich probs Tue, 03 May 2005 08:30 Go to previous messageGo to next message
If that dyno graph is of a 3SGTE, I'd be assuming it's coming on boost at the 90km/h mark (I prefer it when they put it against RPM!)
To really see what the AFR is like though, you really need to have a MAP comparison too...
It actually looks pretty good at the "lean" end if it's off boost, but is way too rich later on.. Should only really hit a 11.5AFR at worst (With a stock tune) and most aftermarket tuners tune to around 12 for safety, and 12.5 for full on performance (On a turbo car that is)
HyDrA
Adelaide, SA
Re: anyone with running rich probs Tue, 03 May 2005 09:28 Go to previous messageGo to next message
Hmmm I should really visit a dyno... I need to find out what my A/F ratios are up to!
HyDrA
Adelaide, SA
Re: anyone with running rich probs Tue, 03 May 2005 09:34 Go to previous messageGo to next message
HyDrA
Adelaide, SA
Sorry, forum error made a doulbe post!!
sideshow
Re: anyone with running rich probs Tue, 03 May 2005 11:49 Go to previous message
10 to 1 air fuel is normal at wide open throttle for a std ecu
both nissan and toyota do this for safety
my 1uz hits 10 to 1 anytime the tps sees over about 90%
it is called wide open throttle mode
u will find when fittin a unichip or safc taking fuel out up hi makes power
Previous Topic:increases in track width -good / bad?
Next Topic:lsd center for corona diff.
Current Time: Thu Oct 29 23:04:06 UTC 2026
Total time taken to generate the page: 0.02196216583252 seconds
