Toymods » Tech & Conversions » Info about 1uz-fe
joebloggs1987
Somewhere
May 2005
icon4.gif  Info about 1uz-fe Tue, 03 May 2005 02:55 Go to next message
Hey im new to the forum, this is my first post.
I was just wondering if anyone can give me some info on the 1uz-fe.
Ive always known what these motors were, but not until recently did i realise the potential that they have.
I allready know all the basic things like stock power output, and things about the motor, but i was interested in the following...
1. Peak power without pulling the engine apart (NA)
2. Peak power without pulling the engine apart (turbo)
3. Peak power without touching the bottom end (turbo)
4. Peak revs standard
5. Peak revs with upgrades (what upgrades are involved, cams etc.)
6. How much does the engine weigh?
7. Would you reccomend this motor over a 2jz-gte?
Thanks for your time.
I hope to learn a lot from this forum.
P.S. Sorry for not doing a search, i am a newbie Embarassed .
setsuna
Re: Info about 1uz-fe Tue, 03 May 2005 03:25 Go to previous messageGo to next message
1UZ-FE - stock engines
year, HP, torque
89-95+, 256@5400, 261@4600
89-96, 250@5600, 261@4400
89-95+, 242@5400, 261@4400
95-97+, 265@5400, 269@4600
97-, 300@6000, 315@4000
also look on http://www.1uzfe.com/
joebloggs1987
Somewhere
May 2005
Re: Info about 1uz-fe Tue, 03 May 2005 03:34 Go to previous messageGo to next message
I allready said that i knew the stock power outputs.
Sorry if i had confused you in any way, but i thought the post was fairly straight forward.
I shall take a look at the link you gave me.
JustenGT4
Re: Info about 1uz-fe Tue, 03 May 2005 03:35 Go to previous messageGo to next message
Limits are always a bit like asking how long is a piece of string...too many variable to answer with any accuracy.
To give you an idea though my turbo 1UZ is internally stock and to date has laid down 270rwkw on 10psi. Currently running 13psi but no dyno result at that boost
Re: Info about 1uz-fe Tue, 03 May 2005 04:01 Go to previous messageGo to next message
1. ITB's, Extractors, aftermarket ECU, will net you about 240-250rwhp. (I presume you don't mean cams)
2. NFI
3. For longetivity, probably 600-800hp on a good tune. for hp hero, or you don't car, well over 1000hp.
4. Standard ecu, rev cut 6500, power drops off after 5500 on stock cams
5. Around 9-10k with decent valvetrain, but upgrade the sump before you race the car, they have a habit of oil starvation with lots of corner g's
6. About the 175kg mark.
7. Depends what you want.
joebloggs1987
Somewhere
May 2005
Re: Info about 1uz-fe Tue, 03 May 2005 04:24 Go to previous messageGo to next message
Thanks CrUZsida.
More opinions are appreciated though.
Re: Info about 1uz-fe Tue, 03 May 2005 04:30 Go to previous messageGo to next message
Do you actually even have the EH ute you plan to put this into?
Seriously dude, I note you are 17 and it shows. Do a search, potter about the multitude links that have been provided, ring an engine importer near you for a realistic halfcut price and come back and ask the pertinent questions when you are clued up. Smile
joebloggs1987
Somewhere
May 2005
Re: Info about 1uz-fe Tue, 03 May 2005 04:37 Go to previous messageGo to next message
Actually, i have 4 of them.
I know it wont be cheap, but i have most of the parts.
Considering i can do everything myself, and i have most of the parts, i think to say $10,000+ is a bit over the top.
But sure i see that it wouldnt be cheap.
Even though i have everything to do it, i can still see it costing a good $5,000 or more.
[Updated on: Tue, 03 May 2005 04:38]
Re: Info about 1uz-fe Tue, 03 May 2005 05:03 Go to previous messageGo to next message
It's common knowledge that an engine conversion costs the price of a half cut plus a tank of fuel. So you should be fine wiht your $5k budget.
http://members.optusnet.com.au/norbee/bushtu.jpg
Re: Info about 1uz-fe Tue, 03 May 2005 05:08 Go to previous messageGo to next message
With 5K, you'd be best buying a 2JZGTE. At least that way you'll lose less when you sell your incomplete project.
ed_ma61
Lost in the K hole
Re: Info about 1uz-fe Tue, 03 May 2005 06:30 Go to previous message
eat lead noob.... Laughing
http://www.legalforensics.co.uk/images/m60.gif
[Updated on: Tue, 03 May 2005 06:34]
Previous Topic:1ggte Rb25 bb Turbo conversion
Next Topic:3T-GTEU into a KE70 Corolla
Current Time: Thu Jun 18 01:39:07 UTC 2026
Total time taken to generate the page: 0.0063068866729736 seconds
